Tip & How-To about Computers & Internet
Internet Explorer 8 takes longer than expected to start.
Symptom:
When launching Internet Explorer, you may notice that Internet Explorer takes longer than expected to start.
Cause:
This issue can be caused if there are damaged or incompatibilities with installed Internet Explorer add-ons. This behavior may be more visible in Internet Explorer 8 due to changes in the way that Internet Explorer 8 handles the internet zones list.
This issue can also be caused if using Spybot and the Spybot immunization feature is enabled.
Resolution:
To resolve this issue, troubleshoot the Add-ons to determine which Add-on may be causing the issue and then disable or uninstall the Add-on and then contact the manufacturer of the Add-on for support with that Add-on.
To do this, follow the steps listed below starting with Step 1.
Note: If you currently have Spybot installed with the immunization feature enabled, you will need to disable that feature until that issue is resolved. If you’re not sure how to disable the immunization feature, contact the vendor for more help.
Step 1: Run Internet Explorer 8 in "No Add-ons" mode to determine if the issue is Add-On related.
loadTOCNode(2, 'resolution'); Internet Explorer 8 add-ons, such as ActiveX controls and browser toolbars, are used by some Web sites to provide an enhanced browsing experience. An error may occur if an add-on is damaged or if an add-on conflicts with Internet Explorer 8.
To determine whether the error is caused by an add-on, run Internet Explorer 8 in "No Add-ons" mode. To do this, follow these steps:
  1. Click Start, and then type Internet Explorer in the Start Search box.
  2. Click Internet Explorer (No Add-ons). Internet Explorer 8 opens without add-ons, toolbars, or plug-ins.
  3. Test Internet Explorer to verify that it works correctly. If issues still occur, try Step 3.
If no errors occur, the problem is caused by one of the add-ons that typically load together with Internet Explorer 8. In this case, continue to Step 2 to determine what Add-on is causing the issue.
Step 2: Use the Manage Add-ons tool to determine which add-on is causing the issue
loadTOCNode(2, 'resolution'); Use the Manage Add-ons tool in Internet Explorer 8 to individually disable each add-on to determine which add-on is causing errors. To do this, follow these steps:
  1. Open Internet Explorer 8.
  2. Click Tools, point to Manage Add-ons , and then click Enable or Disable Add-ons.
  3. In the Show box, select Add-ons that have been used by Internet Explorer to display all add-ons that are installed on the computer.
  4. For each item in this list, select the add-on, and then click Disable under Settings.
  5. When you have disabled all the items in this list, click OK.
  6. Exit and then restart Internet Explorer 8.
  7. If issues do not occur, repeat steps 1 through 3.
  8. Click Enable for a single add-on.
  9. Repeat steps 6 through 8 until you determine which add-on causes errors to occur.
After you have used this process to determine which add-on is causing errors, you can disable that add-on. Or, you can uninstall the software that installs the add-on. We also recommend that you contact the software vendor that provided the add-on for additional troubleshooting and support.
Step 3: Reset Internet Explorer 8 settings
loadTOCNode(2, 'resolution'); To determine whether a performance issue or an error message is caused by configuration settings, reset Internet Explorer 8 to its default configuration. This step will also disable any add-ons, plug-ins, or toolbars that are installed. Although this solution is quick, it also means that, if you want to use any of those add-ons in the future, they must be reinstalled.
  2. Click Tools, and then click Internet Options.
  3. Click the Advanced tab.
  4. Under Reset Internet Explorer Settings, click Reset.
The information in this article applies to:
  • Windows Internet Explorer 8
Keywords: MS Article ID 969938
Computers & Internet Logo
internet explorer crashes
If Internet Explorer is crashing , your dilema likely lies with a buggy browser add-on. However, Internet Explorer crashes can have a alot of other causes, including incompatibilities with hardware rendering and possible malware.
crashes are often cause by buggy add ons. you can check to see if that is the problem by running internet explorer with out add ons
To do so, open the Start menu and launch the All Programs > Accessories > System Tools > Internet Explorer (No Add-Ons) shortcut.
If running Internet Explorer with no browser add-ons fixed your problem, you can disable the add-ons one by one to identify the one causing the problem. Click the gear menu and select Manage add-ons to open the Manage Add-ons window.
Select an add-on in the Toolbars and Extensions category and click the Disable button to disable it. Disable add-ons one by one - or disable them all and enable them one by one - until you identify the add-on causing the problem.
malware can often be a problem with applications crashing especially for an browser like IE. so scan your system with antivirus software for sure.
Mar 23, 2014 | Google Toolbar
hang up internet explorer not responding
If you use Internet Explorer you may experience issues where the browser freezes, hangs up and stops responding.
Although many things can cause the browser to stop responding, if the problem persists there are a few troubleshooting techniques that you can use to fix the problem.
Troubleshooting Internet Explorer may require you to perform a few steps or several, depending on the cause of the problem.
Click "Start," choose "All Programs" and click on the "Windows Update" option.
A new window will appear.
Click the "Check for updates" link on the left side of the window.
Windows will connect to the internet and search for updates for your system.
Click the "Install updates" button on the right side of the window.
Windows will automatically download and install any updates it finds.
Restart your computer, if prompted.
Delete Temporary Internet Files
Click "Start" and select "Control Panel."
Click the "Network and Internet" selection then click on "Internet Options."
The Internet Properties dialog box will appear.
Click the "Delete" button beneath the "Browsing history" section.
Place a check-mark next to "Temporary Internet files" and click "Delete."
Allow the computer to delete the temporary internet files then close the Internet Properties dialog box.
Remove Problematic Add Ons
Click "Start" and enter "Internet Explorer" into the Windows search bar.
Click on "Internet Explorer (No Add-ons)" when it appears in the list.
Internet Explorer will launch with no add-ons running.
Click "Tools" on the right side of the browser and select "Manage Add ons."
A pop up window will appear.
Click on "Toolbars and Extensions" beneath the "Add on Types" section on the left side of the window.
A list of add ons will appear on the right side of the window.
Scroll through the list of installed add-ons and locate third party add ons that you've recently installed.
Note that you can look at the "File date" for a date of when you installed the add on.
Look for add ons that you installed at approximately the same time you began experiencing issues with Internet Explorer not responding.
Click on any suspected problematic add-ons and click the "Disable" button at the bottom of the window. Close "Internet Explorer (No Add ons)" and restart the browser normally.
Verify that disabling the add-on fixes the problem.
If not, repeat this section and disable another recently installed add on until you fix the problem.
Hope this helps.
Nov 19, 2012 | Computers & Internet
I recive message on start the computer "Internet explorer 6 security prihibit runing ActiveX controls" and i do not view the filles, any filles!
cause:
This issue occurs if the Internet Explorer Enhanced Security Configuration feature is enabled. By default, the Internet Explorer Enhanced Security Configuration feature is enabled in Internet Explorer on Windows Server 2003-based computers.
This enhanced level of security may prevent certain Web sites from displaying as expected in Internet Explorer. For example, programs that require the Web browser may not work as expected because scripts, ActiveX controls, and downloads are disabled.
Resolution:
To resolve this issue, add the following Macromedia Web sites
  • http://www.macromedia.com
  • http://fpdownload.macromedia.com
  • http://sdc.shockwave.com
to the Trusted sites zone in Internet Explorer. To do so, follow these steps:
  1. Start Internet Explorer (if it is not already running).
  2. On the Tools menu, click Internet Options.
  3. Click the Security tab.
  4. Under Select a Web content zone to specify its security settings, click Trusted sites, and then click Sites.
  5. In the Add this Web site to the zone box, type http://www.macromedia.com, and then click Add, type http://fpdownload.macromedia.com.
  6. Click Add, type http://sdc.shockwave.com, and then click Add.
    The Macromedia Web sites are displayed in the Web sites list.
  7. Click Close, and then click OK.
Good to know information:
The Internet Explorer Enhanced Security Configuration feature configures several security settings that define how you access Internet and intranet Web sites. The configuration also reduces the exposure of your server to Web sites that may pose a security risk. To log on to a Web site that requires Internet Explorer functionality that is disabled by the Internet Explorer Enhanced Security Configuration feature, add that Web site to the Trusted sites zone in Internet Explorer.
For more information about Internet Explorer Enhanced Security Configuration, see the Internet Explorer "Enhanced Security Configuration" Help topic. To do so (on a computer that is running Windows Server 2003), start Internet Explorer, and then on the Help menu, click Enhanced Security Configuration.
Dec 24, 2010 | Computers & Internet
not signing in
check your internet connection
Jan 06, 2010 | Yahoo Messenger
Internet Explorer will not load
hi, this is the general issue with the IE.Please go to control panel and in add or remove programs and remove this from there then again run the setupthis will solve the issue.
Jun 12, 2009 | Microsoft Internet Explorer 8
169 people viewed this tip
David Payne
David Payne
