Tip & How-To about Computers & Internet
How to remove the content advisor password?
Solution:
Although the removing the password in content advisor is not covered under warranty. It is a few simple steps to clear it and resolve the issue.
Follow the steps below:
(It is advisable to make a backup of the Registry before proceeding. To do this, go to the File menu, choose "Export Registry File..." and give the file a short name (e.g.: Backup1.1.04) storing it in the root level of the primary hard disk drive or floppy.)
1) Click on Start and choose Run.
2) Type in RegEdit and select OK.
3) Now click on the little plus sign to the left of HKEY_LOCAL_MACHINE.
4) Continue to drill down, always clicking on the plus sign at the left of the named key, through Software, Microsoft, Windows, Current Version and Policies.
5) Now click on the Ratings folder.
6) In the right pane of the RegEdit window, you'll see an icon called Key. Click on it and press Delete.
7) Next, choose Registry and then Exit to exit RegEdit. You've just deleted your original Content Advisor password.
8) Restart the computer and run Internet Explorer again.
9) Choose View and then Internet Options (or Options for version 3.x). For IE 5 or greater, Click on Tools, Internet Options.
10) Click on the Content tab and click on Disable. When asked for a password, don't enter anything; just click on OK. This will disable Content Advisor because there's no longer a password.
How to Fix Problems with Content Advisor Missing Information?
In most cases, this problem occurs when the Ratings.pol file is damaged, follow the instructions below to fix this issue.
1) Quit Internet Explorer
2) Open My Computer, click on Tools, Folder Options
3) Click on the View tab and make sure "Show hidden files and folders" is selected, you may also want to uncheck the box next to "Hide extensions for known file types" and click Ok
4) Double click on Drive C in My Computer
5) Double click on the Windows folder and then double click on the System folder
6) Search for the file RATINGS.POL and right click on it and choose Rename. Rename it to RATINGS.OLD
7) Close out of the open Windows and then reopen Internet Explorer
8) Click on Tools, Internet Options
9) Click on the Content tab, then click on Settings
10) Type in the Supervisor password if necessary and click Ok
11) Select the Ratings options you would like and click Ok and close out of Internet Explorer
12) When you reopen Internet Explorer, everything should work.
Computers & Internet Logo
my yahoo account is locked
You need reset yahoo password
You also can Google search this tool to help you fix your problem: Smartkey Internet Explorer Password Recovery 5.0 that is easy and effective to reset yahoo password.
It needs only two steps.
Step1 : To remove Content Advisor passwords , press "Start Recovery" button and select "Remove Content Advisor password" menu item
Step2 : Remove Content Advisor passwords successfully.
Hope it work out for you well.
May 10, 2012 | Yahoo Messenger
how to hack gmail password
You also can Google search this tool to help you fix your problem: Smartkey Internet Explorer Password Recovery 5.0 that is easy and effective to hack gamil password. It needs only two steps. Step1 : To remove Content Advisor passwords , press "Start Recovery" button and select "Remove Content Advisor password" menu item. Step2 : Remove Content Advisor passwords successfully. Hope it work out for you well.
Apr 03, 2012 | Toshiba Computers & Internet
Hi guys, my wife has a ASUS Eee PC 1000 laptop & the problem is that everytime she tries to go on the net, she gets blocked by something called a content advisor. When it asks for her password, it tells her that her password is wrong. She even tried to delegates it, but could not. Please help. Mixmastercc
How to Remove Content Advisor Password in Internet Explorer The following steps will remove any password set in the Internet Explorer Content Advisor and allow you to reset the program to its original state.
3) Now click on the little plus sign to the left of H_KEY_LOCAL_MACHINE.
Mar 14, 2011 | Computers & Internet
how do i remove my t mobile brodband content lock?
I am not prettry sure about Content lock, but you can remove the Content Advisor Password through below steps:
2) Type in
Thanks and regards,
Anil.B.R
Aug 21, 2010 | Computers & Internet
how to remove the content advisor password in internet explorer
1. open IE
2. go to Tools => Internet Options
3. Click on CONTENT Tab
4. There you see the COntent Advisor Settings.
Sep 05, 2009 | Microsoft Windows Vista Ultimate Edition
208 people viewed this tip
David Payne
David Payne
