Tip & How-To about Computers & Internet
A blank Web page is displayed when you start Internet Explorer 7.
Symptom:
loadTOCNode(1, 'symptoms'); When you start Windows Internet Explorer 7, your home page does not open. Instead, a blank Web page is displayed.
Additionally, you may receive an error message that resembles the following:
Line 56
Char:2
Error: Element not found
Code: 0
URL:http://runonce.msn.com/runonce2aspx
This problem typically occurs after you install Internet Explorer 7, after you install Windows, or after you reset Internet Explorer settings. This problem may occur only for certain users.
To have us fix this problem for you, go to the “Fix it for me” section. If you would rather fix this problem yourself, go to the “Let me fix it myself” section.
Cause:
This problem occurs if the Customize Your Settings Web page in Internet Explorer 7 is not loaded correctly or if the Customize Your Settings Web page opens with restricted security settings.
Fix it for me
To fix this problem automatically, click the Fix this problem link. Then click Run in the File Download dialog box, and follow the steps in this wizard.
Fix this problem
Microsoft Fix it 50065
Note: This wizard is temporarily in English only. However, the automatic fix also works for other language versions of Windows.
Note: If you are not on the computer that has the problem, you can save the automatic fix to a flash drive or to a CD, and then you can run it on the computer that has the problem.
To resolve this problem, create and run a Skiprunonce.reg file for each user account that experiences the problem. If you would rather modify the registry directly, see the "Advanced users" section.
To do this, follow these steps:
  1. Start a text editor, such as Notepad.
  2. Copy the following information, paste it into the text editor, and then save the file as Skiprunonce.reg:
    Windows Registry Editor Version 5.00
    [HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main]
    "RunOnceHasShown"=dword:00000001
    "RunOnceComplete"=dword:00000001
  3. Exit the text editor.
  4. Double-click the Skiprunonce.reg file that you created in step 2.
    When you run the Skiprunonce.reg file, you will receive the following message:
    Are you sure you want to add the information in path of .reg file to the registry?
    Click Yes. Then you will receive the following message:
    Information in path of .reg file has been successfully entered into the registry.
Notes:
  • In Windows Vista, when non-administrator users try to run SkipRunOnce.reg they are prompted for an administrator password.
  • To run SkipRunOnce.reg for all users at the same time, modify SkipRunOnce.reg by replacing [HKEY_LOCAL_MACHINE\Software\Microsoft\Internet Explorer\Main] with [HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main] and then running it as an administrator.
Similar problems and resolutions
To troubleshoot similar problems, self-help steps for beginning to intermediate computer users are available at the following Microsoft Web site:
Troubleshoot problems in which Windows Internet Explorer stops responding or crashes
Note: This Guided Help content may not be available in all languages.
The information in this article applies to:
  • Windows Internet Explorer 7
  • Windows Internet Explorer 8
Keywords: MS Article ID 945385
Computers & Internet Logo
how do i remove web search as my home page
  1. Start Internet Explorer.
  2. On the Tools menu, click Internet Options.
  3. Click the General tab.
  4. In the Address box, type the Web page address that you want for your home page.
    NOTE: If you want the page that you are currently viewing in Internet Explorer to be your home page, click Use Current.
  5. Click OK.
FOR FIRE FOX
  • At the top of the Firefox windowOn the menu bar, click on the ToolsFirefox menu (Tools menu in Windows XP), and then click OptionsFirefoxEdit menu, and select Options...Preferences...
  • Select the General panel (Main panel in Firefox 3.5).
    • In the Startup box click the drop-down menu next to "When Firefox starts:" and select what Firefox should display when it starts up.
    • Show my home page - Displays the home page (or home pages of course).
  • Show a blank page - Displays a blank page (this loads fast - no waiting for lots of tabs to load).
  • Show my windows and tabs from last time - Opens the pages you were visiting the last time you used Firefox so you can continue right where you left off. Click OK to close the Options windowClick Close to close the Preferences windowClose the Preferences window .
kindly rate this solution
thanks and regards
Feb 14, 2011 | Computers & Internet
AppHangXProcB1
Step 1: Open a blank page in Internet Explorer loadTOCNode(2, 'resolution'); Test Internet Explorer by opening a blank page. To do this, follow these steps:
  1. Click Start, click Run, type iexplore about:blank in the Open box, and then click OK.
  2. If Internet Explorer does not start, go to "Step 3: Start Internet Explorer in 'No Add-ons' mode." If Internet Explorer starts correctly, follow these steps to use a blank page as your home page:
    1. On the toolbar, click Tools, and then click Internet Options.
    2. On the General tab, note the address that is listed in the Home page area. This address may cause the problem.
    3. Click Use Blank, and then click OK.
    4. Close Internet Explorer. Then, start Internet Explorer again.
uparrow.gifBack to the top Step 2: Remove temporary Internet files, browsing history data, and Web form data loadTOCNode(2, 'resolution'); To remove temporary Internet files, browsing history data, and Web form data, follow these steps:
  2. On the toolbar, click Tools, and then click Internet Options.
  3. On the General tab, click Delete in the Browsing history area.
  4. In the Delete Browsing History dialog box, click to clear all of the check boxes except for the following check boxes:
    • Cookies
    • History
    • Form Data
  5. Click Delete.
  6. Click OK to close the Internet Options dialog box.
  4. In the Delete Browsing History dialog box, click Delete files, and then click Yes in the Delete Files dialog box.
  5. Click Delete cookies, and then click Yes in the Delete Cookies dialog box.
  6. Click Delete history, and then click Yes in the Delete History dialog box.
  7. Click Delete forms and then click Yes in the Delete Form Data dialog box.
  8. Click Close, and then click OK.
Test Internet Explorer to verify that it works correctly. If problems still occur, go to the next step. uparrow.gifBack to the top Step 3: Start Internet Explorer in "No Add-ons" mode loadTOCNode(2, 'resolution'); To start Internet Explorer in "No Add-ons" mode, click Start, point to All Programs, point to Accessories, point to System Tools, and then click Internet Explorer (No Add-ons). To continue to your home page, click the Home button.
If the problem does not occur after you use this method, use Manage Add-ons to determine which add-ons are causing the problem. To do this, follow these steps:
  1. Click Tools on the Internet Explorer toolbar, and then click Manage Add-ons.
  2. Click the name of the add-on at the top of the Toolbars and Extensions list, and then click Disable.
  3. Click Close, and then test Internet Explorer.
  4. If the problem still occurs, open Manage Add-ons, enable the add-on that you disabled in step 2, and then repeat steps 1 through 3 for the next add-on in the Toolbars and Extensions list.
  5. Repeat steps 1 through 3 until the problem is resolved or until all the add-ons have been tested.
  1. Click Tools on the Internet Explorer toolbar, point to Manage Add-ons, and then click Enable or Disable Add-ons.
  2. Click the name of the add-on at the top of the Enabled list, and then click Disable in the Settings area.
  3. Click OK, and then test Internet Explorer.
  4. If the problem still occurs, open Manage Add-ons, enable the add-on that you disabled in step 2, and then repeat steps 1 to 3 for the next add-on in the Enabled list.
  5. Repeat steps 1 to 3 until the problem is resolved or until all the add-ons have been tested.
uparrow.gifBack to the top Step 4: Use another user name to log on to Windows loadTOCNode(2, 'resolution'); Using a different user name and password to log on to Windows can help determine whether this problem occurs only when you use a particular user account. After you log on, test Internet Explorer to see whether the problem still occurs. uparrow.gifBack to the top Step 5: Reset Internet Explorer settings loadTOCNode(2, 'resolution'); To reset Internet Explorer settings, follow these steps:
  2. Click Tools on the toolbar, and then click Internet Options.
  3. On the Advanced tab, follow one of these steps:
    • In Internet Explorer 8, click Reset, click Reset in the Reset Internet Explorer Settings dialog box, and then click Close.
    • In Internet Explorer 7, click Reset, and then click OK.
  4. Test Internet Explorer to determine whether the problem is resolved.
Nov 26, 2009 | Acer Aspire 5315 Notebook
display on Internet expolrer 7
Use mozilla firefox.
Uninstall IE7, it sucks...
Feb 19, 2009 | Microsoft Internet Explorer 7
yahoo chat
  1. The Web Page that you are trying to reach might be out of service. Try visiting different Web sites to see if this message still displays from other sites. If visiting other sites also cause the message, continue using these steps.
  2. If you are using IE 7, reset Internet Explorer 7 settings and try again. If the page display problems persist, continue.
  3. In Windows Vista, click Start c00866085.gif , and then enter the following into the Start Search field: regsvr32 softpub.dll In Windows XP , click Start , and then Run enter the following into the open field: regsvr32 softpub.dll
  4. In Windows Vista, click Start c00866085.gif , and then enter the following into the Start Search field: regsvr32 urlmon.dll In Windows XP, click Start , and then Run enter the following into the open field: regsvr32 urlmon.dll
  5. Restart the computer and then try browsing the Internet again. If the page display problems persist, continue.
  6. Open Internet Explorer and click Tools , and then Internet Options .
  7. Click the Programs tab, and then click Reset Web Settings .
Sep 23, 2007 | Computers & Internet
193 people viewed this tip
David Payne
David Payne
