Tip & How-To about Cameras
Cleaning your system
When cleaning your system use a can of compressed air
Cameras Logo
Mercedes-Benz 350 4matic 6 cylinder engine will crank but won't start why
Engine needs fuel, air, compression, and spark to run. You will need to trouble shoot the ignition, and fuel delivery systems after confirming that you have engine compression and clean air filter.
Dec 23, 2016 | Mercedes-Benz Cars & Trucks
engen problem and missing
Sir, your question is not very clear, but I will still try to post a solution here. Engine missing could be due to any problem in fuel system, ignition system, engine or ECM as well.
LOW ENGINE IDLE SPEED (Poor idling):
-Throttle body (do the cleaning and idle speed learning)
-A /C signal circuit
-Fuel pump control circuit
-Fuel pump
-Intake system
-P C V valve (clogged or open) and hose
ROUGH IDLING:
-Cylinder Compression
-Ignition system (Igniters, spark plugs, wiring harness)
-Spark plug fouled, gap too wide or too short. (1.00-1.1 mm)
-Fuel injector circuit
-E C M power source circuit
-Fuel pump (required pressure 44 psi - 49 psi)
-Throttle body (cleaning)
-Intake system
-P C V valve and hose
-Air fuel ratio sensor
-Heated oxygen s ens or
-Mass air flow meter
-Idle hunting
-Throttle body
-Intake system
HESITATION/ POOR ACCELERATION:
-Fuel pump
-Spark plug
-Ignition system
-Throttle body (do cleaning)
-Intake system
-Valve timing
Jan 18, 2014 | 2008 Toyota Corolla
2002 jeep liberty heat only works at high rpm
Sounds like low flow issue. Flush and clean system, PROPERLY! Buy a flush kit, drain system, blow compressed air through, fill with cleaner/water mix, run for 30 min with heat on, drain system, blow out with compressed air, fill with water, run for 30 min, drain, blow out with compressed air, fill with 60% coolant mix.
Nov 26, 2013 | 2002 Jeep Liberty
kidde i12040 beeps
You need to replace the battery and/or clean the dust out of it (you can use a vacuum or a compressed air duster like this: http://www.discountofficeitems.com/technology/computer-accessories/cleaning-maintenance/air-dusters/dust-disposable-compressed-duster/p79223.html)
Nov 20, 2012 | First Alert SA302 Dual System Smoke...
How many gallons of compressed air will I need to clean 1 pair of headlights with 3M Pnuematic Headlight Restore System?
73 seankim,
You will need to get an Air Compressor. I assume it will take 100's (if not 1,000's) of gallons of compress air. Actual amount depends on how long you run the polishing tool.
May 30, 2009 | 3M ? Headlight Lens Restoration System #...
1,458 people viewed this tip
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
