Tip & How-To about Microwave Ovens
How to change a Microwave Oven lamp.
All microwaves have their lamps positioned outside the heating cavity so as not to interfere with the microwave process and to avoid arcing. Some lamps are accessable by removing a small cover on the rear of the unit. If you do not see any doors on the rear of the unit you will have to remove the metal cover.
To access your lamp you will need to remove the outer cabinet which requires removing all the screws around the back lip. With all the screws out, the cabinet should slip off the unit. It should pull up and to the front to get it off. In some cases the cabinet may stick due to food spills which have dried, holding the cover, even after all screws have been removed. Be careful but persistent and the cover will come off.
Once the outside cover is off the lamp should be visible. If not you may have to remove another dust cover to access it. At this point the lamp can be removed and replaced.
Replacement lamps should be available at Lowes Home Depot or http://www.repairclinic.com .Be sure to replace the lamp with the exact same size/rating bulb and one which is designed to work in a microwave oven. These are specially designed lamps and therefore will cost more than a run of the mill lamp.
Installing a larger unit may cause overheating problems, melting or possibly even a fire. Reverse the procedure used to disassemble and your unit should be ready to go.
Thanks for using FixYa and for the great rating.
hardrock
Microwave Ovens Logo
I have a Sharp Carousel Microwave R-1460A. The disk on the ceiling, opposite the warming plate and about the same size, has severe burn marks (probably from food splatters). Any idea what that part is
see this indication and fix it. God bless you
  1. Waveguide coverSparking and arcing in a microwave can be caused by a damaged waveguide cover. Try removing the waveguide cover to see if the problem persists. Once removed, the waveguide cover can be inspected for burns, which will indicate if this is the issue. If the waveguide cover is burnt or will not stay in the proper spot it will need to be replaced.
  2. Cavity/Rack supportIf sparking or arcing in your microwave is near a rack support, any exposed metallic area can be covered with a microwave cavity support. It is also recommended to replace the rack supports in this situation to ensure the issue is resolved.
  3. Cavity paintIf sparking or arcing in the microwave is visible on the side walls, the paint covering the metallic areas could have worn off or chipped. This can possibly cause pitting in the side walls or ceiling. If this is the case, it can be repaired with microwave cavity pain
Nov 08, 2013 | Sharp R-1460 Microwave Oven
kenmore microwave is sparking when you it start and then goes to pause
see this steps and fix it. God bless you
If you see arcing or sparking inside a microwave, turn unit off immediately. Arcing can be caused by having something metal in the oven cavity touching a side, an oven shelf is touching the side of the cavity, an oven shelf support has broken, microwave waveguide, or bad magnetron.
If your microwave has a shelf in it, and you do not use it, keep it out. If one of the shelf supports breaks or comes out, the microwave will arc where the support was. You will have to sand the spot down, paint with appliance paint and re-install support. If the shelf shifts on the support and touches the side it will arc.
Your magnetron waveguide will either come out of the top, or side of the oven cavity. Some will have a stirrer in it(mostly top waveguides) with a panel over, or just a cardboard type cover over it. Over time, the stirrer cover can become warped from the heat which will expose the stirrer's metal shaft which will then cause sparking. These covers and stirrers come in a kit and can be replaced from inside the oven cavity.
Your cover over a side waveguide is coated with a substance on it, and overtime this coating can come off from the heat and moisture in the microwave. These waveguide covers are very easy to replace from inside the oven cavity. Touch up any paint that may have chipped or come off because of the arcing.
If your waveguide cover and/or stirrer are all OK, then the spark is coming from your magnetron. The antenna on your magnetrom has overheated and burned, sending the microwaves out at the wrong angle. If you catch this microwave oven repair early enough, you can usually get by with just replacing the magnetron. If the arcing has caused servere damage inside the waveguide, you will need a new microwave. Waveguides are not replaceable and most you can barely see into them, let alone sand and re-paint. In this case of microwave oven repair, when you remove the magnetron, you will see the burned antenna, or your magnetron will fail the test below.
see the guide for test the magenetron and another component.
Oct 03, 2012 | Kenmore Microwave Ovens
sparks when starting then goes to pause mode
see this next steps. God bless you
My LG/Dometic MICROWAVE sparks inside the cooking area when turned on
see the next steps and follow with common sense: God bless you
Microwave is arcing If you see arcing or sparking inside a microwave, turn unit off immediately. Arcing can be caused by having something metal in the oven cavity touching a side, an oven shelf is touching the side of the cavity, an oven shelf support has broken, microwave waveguide, or bad magnetron.
Jul 26, 2012 | Microwave Ovens
MAYTAG MICROWAVE OVEN ARCING FOOD ON PLATE, HEATS EXTREMLY FAST. PUT BABY FOOD (SWEET POTATOES ON A PLATE AND WITHIN 5 SECS THE FOODS BEGINGS TO ARC AND BURN
The magnetron is getting to hot and will eventually fail, especially when it is arcing, "a safety issue convern" the cause is the part mentioned above, or there is exposed metal on the inside cavity.
May 07, 2012 | Maytag 1.6 Cu. Ft. Over-the-Range...
384 people viewed this tip
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
