Tip & How-To about Audio Players & Recorders
MP3 SCREEN GETS WHITE AND FREEZES
LEAVE ON THE PLAYER UNTIL THE BATTERY DIES, TURN ON AND FULL CHARGE SYSTEM, CONNECT SYSTEM TO A COMPUTER AND CHECK FOR VIRUS, THEN SYSTEM SHOULD BE WORKING AGAIN
How do I fix my tablet that won't fully charge?
Your tablet may need its battery calibrating. To do this run your tablet until it turns itself off, this will ensure that there is no charge left in the battery. Then leave it on charge until the battery is full. Normal battery use on modern devices like tablets and phones should be between 25-75%, with a calibration once every 3-6 months to ensure a good battery lifespan. If this solution does not work you may need to replace the battery.
Jul 07, 2014 | Visual Land Connect 9" Android Tablet...
my player turns on and displays the pearl icon and no longer moves
Hi
Try removing the device's battery.
Leave the player in the frozen state until the battery dies.
Connect the mp3 to a computer and turn the computer on.
Leave it charging for 15minutes an then try playing music while its still charging.
Feb 28, 2012 | Audio Players & Recorders
hello how come my rca mp3 player doesnt charge when i plug it in my computer
You most likely have not turned the player off. Connect to your USB port, switch on the player using the slide switch on the side. The screen will light up. To make the battery charge, turn off the player by holding down the 'play' button until you get the bye-bye message. A couple of seconds later the screen will go black and the battery will start charging. Leave overnight if the battery is dead flat.
Mar 17, 2010 | RCA Audio Players & Recorders
Battery
Uhm.. Do you plug it up to your computer to charge? Mine is old and dies after about two hours.. I know I need to replace. But in it's old age I guess (Bought from ebay) it won't charge connect to my computer.. So, maybe if you haven't tried already, to try that. Though, sounds like it's getting old like mine and will need a new battery soon.
Oct 12, 2007 | Philips HDD1630 MP3 Player
Battery dies quickly/ device shuts off randomly
ok maybe you have defective battery replace a new one!! and or you have virus inserted to your memory from your loader or loading station.
Sep 14, 2007 | Philips HDD1630 MP3 Player
148 people viewed this tip
 Grubhead
Grubhead
