Tip & How-To about Computers & Internet
How to use PPT supersede PDF for presentations
Managers and Engineers usually need to present something using PPT, but there are many files are designed as PDF format, so they just use PDF file for presentation by maximazing PDF format, Firstly it is not as vivid as PPT and secondly, if one page of PDF is too long, audience could not see the lower contents in one screen.
Actually, there exists an application named PDF to PowerPoint Converter by which you can convert PDF to PowerPoint for presentations. All the elements will be prefectly reserved. Here are the steps:
Step1: download the program and then install it.
Step2: Launch the program and input the file, or directly drag them into the panel.
Step3: Customize the path and then clike convert. work will be done in seconds.
Notes: You can batch,partial amd right-click convert PDF to PowerPoint, and it also supports encrypted PDF conversion.
Computers & Internet Logo
Fix corrupt powerpoint file
Use PowerPoint Repair Toolbox is efficient PPTX corrupted repair solution for damaged presentations in corresponding format so you may open these documents anytime and regardless the reason of file damage.
For more: https://www.pptxrepairtoolbox.com/
Sep 06, 2015 | Microsoft PowerPoint for PC
how do i fix ppt file? Please help
Hello. There are different methods available to recover corrupted PowerPoint files.
Open presentation in MS Word document
and follow this steps:
- Open MS Word.
- Click on Open button of File menu.
- Select Files of type box and navigate to your corrupt file, Open it.
Also you can try Recovery Toolbox for PowerPoint https://powerpoint.recoverytoolbox.com/
More information see here: http://www.filerepairforum.com/forum/microsoft/microsoft-aa/powerpoint/677-how-to-recover-powerpoint-file
Feb 05, 2015 | Microsoft PowerPoint for PC
I want to open powerpoint presentation.
then, go to format -> slide design, choose to show all documents, and choose the corrupt powerpoint file. now, go to insert -> slides from file, and select the corrupt powerpoint file. make sure you are set to insert all slides, and then import. if that works, great! i suspect, however, that you might crash at that point. if so, try repeating the process, inserting specific slides one by one until you find the problem one. after that, save the file, making sure that fast saves are off (in preferences / save).
if you are unable to open your powerpoint files then try pptx viewer tool. this utility recovers your corrupt and damaged powerpoint presentations (.ppt, .pot, .pps, pptx and ppsx formats) from ms powerpoint files. http://www.pptx.viewertool.com/
visit:- http://www.filerepairforum.com/forum/microsoft/microsoft-aa/powerpoint/1128-how-do-i-recover-a-corrupt-p-point
http://www.pptx.viewertool.com/ http://www.filerepairforum.com/forum/microsoft/microsoft-aa/powerpoint/1128-how-do-i-recover-a-corrupt-p-point
Jan 19, 2015 | Microsoft PowerPoint Computers & Internet
ppt is not open and ppt convert pptx that ppt file not opan
In case the PPT file is corrupted, you could not open it until you repair it using some software. Previously when I too faced the similar situation, I was able to repair corrupted PPT file using Repair PPT software. For more details you can visit the below mentioned website.
http://www.repairppt.net/2010.html
Oct 02, 2010 | Microsoft Office Professional 2007 Full...
216 people viewed this tip
David Payne
David Payne
