Tip & How-To about Audio Players & Recorders
How to watch commercial DVDs on your wide screen TV via WD TV Mini Media Player
WD TV Mini Media Player provides an easy and affordable way to play back your digital media on your wide screen TV.  It serves as a conduit between your TV set and USB drive storage, no matter it is a camcorder, a humble flash drive, or an external HDD. Simply connect WD TV Mini to your TV, plug a USB-connected storage into the player and you are ready to enjoy all your digital media in DVD quality playback.
WD TV Mini Media Player supported media formats:
Videos:
AVI (Xvid, AVC, MPEG4), MPG/MPEG, VOB/ISO, MP4/MOV (MPEG4), RM or RMVB 8/9/10
Audios:
MP3, WAV/PCM/LPCM, WMA, AAC, FLAC, MKA, OGG, APE
From the above list we can see that VOB is a playable format for WD TV Mini Media Player, does it mean that WD TV Mini can play all kinds of DVDs – whether home made DVDs or commercial DVDs? The answer is WD TV can not decrypt copy protected commercial DVDs, so you have to rip them. This tutorial aims to show you how to make it possible for you to watch commercial DVDs on your wide screen TV via WD TV Mini Media Player. What you will need is Pavtube DVD Ripper, it not only rips, but it encodes too. Following is the detailed operating steps:
Step 1: Click "DVD Rom", "DVD Folder" or "IFO/ISO" to load DVD files into this program.
Step 2: Select subtitle and audio track
Click on the pull down menu of "Subtitle" and "Audio" respectively to select your needed subtitle and audio language.
Step 3: Select output format for WD TV Mini Media Player
Click on the drop-down list at the end of "Format" to choose an output format for WD TV Mini Media Player. Your selection should be in the range of AVI (Xvid, AVC, MPEG4), MPG/MPEG, VOB/ISO, MP4/MOV (MPEG4), RM or RMVB 8/9/10. Here I select "Xvid AVI" as an example:
Step 4: Click "Settings" button to adjust video and audio parameters
The user manual tells us that when playback .avi (Xvid) video files, WD TV Mini supports up to 720*576 30fps or 720*480 30fps, so we need to follow the manual while ripping a DVD.
Step 5: Click "Convert" button to start DVD ripping
Once finished, you can get the generated files for WD TV Mini via clicking on "Open" button with ease. Afterwards, just copy the output files to My Passport portable hard drive or other USB drive, and then connect WD TV Mini to your TV, plug your USB drive into the player and you are ready to enjoy the movies ripped from your commercial DVDs.
For more: http://www.pavtube.com/dvd_ripper
WD HD TV Media Player doesn't play AVI
avi is a container format, u can try some other codec
Jan 05, 2010 | Western Digital TV HD Media Player USB...
Enjoy/watch Blu-ray movies on HDTV via WD TV Want to find a solution to playback Blu-ray movies on your widescreen TV via WD HD Media Player? As a matter of fact, WD TV HD Media Player promises to play just about any video format you throw at it, including high definition video up to 1080p. You put the videos on any USB mass storage device, like an external hard drive or a thumb drive, and plug it into the device, WD TV HD Media Player will recognize the files on the drive and play any video, audio, or photo files it finds. However, according to the feedback provided by some users, WD TV HD Media Player does play m2ts selectively only, some are, and some are not. In purpose of solving this problem, this post will talk about how to rip Blu-ray movies to USB for playback on TV via WD TV HD Media Player. WD TV HD Media Player supported file formats: Video: MPEG1/2/4, WMV9, AVI (MPEG4, Xvid, AVC), H.264, MKV, MOV (MPEG4, H.264), Subtitle SRT (UTF-8) Audio: MP3, WMA, OGG, WAV/PCM/LPCM, AAC, FLAC, Dolby Digital, AIF/AIFF, MKA Playlist PLS, M3U, WPL Photo: JPEG, GIF, TIF/TIFF, BMP, PNG Now let?s have a look at its operation steps. Choose MKV format, how to rip Blu-ray to MKV? Step 1 Download, install and run this Blu-ray ripping software After launched it, you will see the following interface at once. There are three ways provided to import Blu-ray files, namely through clicking on "DVD Rom", "DVD Folder", and "IFO/ISO". Step 2 Load the Blu-ray disc. Click on the ?DVD Rom? button to import Blu-ray movie from the disc, or click on ?DVD Folder? button and browse to your target files. It takes a few seconds to load the whole movie, so be patient. A view log will pop up when loading process completes, you can simply click "OK" to confirm or press Ctrl+O to close it. Now all the M2TS files in file list are checked, right-click and choose "Uncheck All". What you need is the main movie---the one with longest duration. Check it and leave unwanted M2TS files unchecked. You can rename the output file by clicking on the file name in Destination File column. Right below the file list you could find "Subtitle" and "Audio" droplist, where you can set output subtitles and dubbings to the languages you like. Step 3 Click on Format bar, select ?Common Video? from the format list and in submenu you could find MKV video format. If you would like to maintain best quality, just back to the format list and move down your mouse to point at ?HD Video?, here you can find ?MKV HD Video?. Check it and hit on the small folder icon to specify an output folder. Then click ?Settings? and customize advanced audio and video parameters. For instance, you may set Video to 1920*1080p (to fit for the wide screen), 25mbps, 30fps, and Audio to AC3/AAC codec, 192kbps, 5.1 channels. Click "OK" to confirm your settings. Step 4. Start conversion. Click on the ?Convert? button and the program will rip Blu-ray movies to MKV video format for you very soon. You could set auto shutdown in progress window (it pops up once you click Convert) or leave it there and come back later (the ripper will tell you how long it takes). Enjoy the converted MKV videos! Once finished, you can get the generated files for WD TV via clicking on "Open" button with ease. Afterwards, just copy the output files to My Passport portable hard drive or other USB drive, and then connect WD TV to your TV, plug your USB drive into the player and you are ready to enjoy the movies ripped from your Blu-rays. That's all, Enjoy it!
Apr 13, 2010 | Audio Players & Recorders
How to rip commercial DVDs on Mac - for playback on wide screen TV via WD TV Mini WD TV Mini Media Player supports up to 1080i resolution for crisp HD media playback, besides this feature, it will never limit the size of your media collection, and you just need add more drives as you like. However there is no luck with commercial DVDs, even though you need not consider about the storage space, because these DVDs have strict copy protections, which WD TV Mini is unable to decrypt. To rip commercial DVDs to a compatible format with WD TV Mini on your Mac, what you will need is Pavtube DVD Ripper for Mac only. Go to find a step-by-step instruction as below. First off, have a look at WD TV Mini Media Player supported media formats: Videos: AVI (Xvid, AVC, MPEG4), MPG/MPEG, VOB/ISO, MP4/MOV (MPEG4), RM or RMVB 8/9/10 Audios: MP3, WAV/PCM/LPCM, WMA, AAC, FLAC, MKA, OGG, APE You can free download Pavtube DVD Ripper for Mac here. Step 1: Launch Pavtube DVD Ripper for Mac, and load DVD files to it You can click "DVD folder" or "IFO file" to load DVD files directly from the DVD-Rom, DVD folder, or from an IFO image file. Step 2: Select an output format for WD TV Mini Media Player Click on the pull down menu of "Format" to a WD TV Mini Media Player supported format as output format. Here I select "Xvid AVI" as my choice. Step 3: Set advanced settings Click on "Settings" button, and you are allowed to adjust audio and video parameters on the popup window including codec, bit rate, frame rate, sample rate, aspect ratio, and audio channels. The user manual of WD TV Min tells us that when playback .avi (Xvid) video files, WD TV Mini supports up to 720*576 30fps or 720*480 30fps, so we need to follow the manual while ripping a DVD. Step 4: Set destination folder Click "Browse" button to specify where to export the output files to. Step 5: Click "Convert" button to start ripping DVD The following window will show you clearly about the ripping info, such as time elapse, estimated left time, generated file size, and estimated file size. In that way, you are able to manage your time and storage space in a proper way. Once ripping work is done, you can click "Open" button to get the output files for WD TV Mini effortlessly. Additional tips: 1. The ripping speed of this software is 1-2 times faster than the similar programs. Merge multiple files into one file is available. 2. Enable users to select specific subtitle and audio track to convert. 3. Guarantee audio-video in sync. 4. With exception of adding text as watermark, images, GIF animations, and videos can also be added as watermarks to realize the picture-in-picture effect. 5. You can use the "Trim" function to select certain DVD clips to convert. And you can also take advantage of the "Crop" function to remove black edges or change the screen size.
Apr 09, 2010 | Audio Players & Recorders
205 people viewed this tip
 Grubhead
Grubhead
