Tip & How-To about NetGear WIRELESS-G WGR614 802.11G WIRELESS ROUTER ($20.00 M.I.RebateTill 06/30/2004) (NETWGR614)
Forcing Card
Windows XP:
1. Click on the Start Menu, and then click on the Run option.
2. When the DOS window opens, then input control ncpa.cpl into the Run field, then click on the OK button.
3. Either the Network Connections or Network and Dial-up Connections screen will then appear.
4. On this window, please right click on the Local Area Connection that controls the Ethernet Adapter (normally the one without a number if there are multiple Local Area Connections) and click on the Properties option from the menu that comes up after right clicking on the icon.
5. When the Local Area Connection Properties window appears, click on Configure.
6. When the Adapter Properties window appears, click on the Advanced tab.
7. After the Advanced section loads, look under the Properties section for Connection Type, Media Type, Connection Speed, or Link Speed/Duplex Mode.
8. After selecting one of the options above, change the Value from Auto to 10 Base-T, 10 half mode, 10 half duplex, or something similar.
9. After changing the mode, click on the OK button. Please click on also the OK or Close button on the Local Area Connection Properties window. The Network Adapters speed will then be 10 Mbps Half Duplex.
NetGear WIRELESS-G WGR614 802.11G WIRELESS ROUTER ($20.00 M.I.RebateTill 06/30/2004) (NETWGR614) Logo
it showing that it connected but web page can open
1.Powercycle your equipment ( Unplug then plug back in) this means your Modem and your Router.
wait 15 seconds then plug back in.
2.Open Network Connections. Xp:Start/Run/Type ncpa.cpl then hit ok
Vista/7:Start/Search bar type ncpa.cpl then hit enter.
3.Right click on the connection your using and hit properties, Uncheck Internet Protocol Version 6
Click on Internet Protocol Version 4 and hit properties.
4.Ensure obtain ip address automatically and obtain DNS server automatically is checked if not check both boxes.
5.Disable all firewalls, Xp:Start/Control Panel/Switch to classic view/Windows Firewall/Turn Off
Vista/7 Start/Control Panel/Security/Change Windows firewall settings
6.Disable Antivirus Software.
7.Renew Ipaddress XP:Start/Run/Type cmd hit ok
Vista/7: Start/All Programs/Accessories/Right Click on Command Prompt click run as administrator. Hit continue
8.In Command Prompt type the following: netsh int ip reset reset.log Hit Enter
netsh int ip delete arpcache Hit Enter
netsh winsock reset Hit Enter
ipconfig /flushdns Hit Enter
9.Restart Computer
10.If still unable to connect run antivirus and check for errors refer to your ISP Internet Service Provider
Dec 05, 2010 | D-Link DIR-600 Router
wount stay connected when i click on the net it goes off
1.Powercycle your equipment (Unplug the power for 15 seconds then plug back in)
2.Ensure Ethernet cords are plugged in tight.
3.Open Network Connections XP:Start/Run/Type ncpa.cpl hit ok
Vista/7 Start/Search Bar/Type ncpa.cpl
4.Right click on Wireless connection (Router) hit properties
5.Uncheck Internet Protocol Version 6 /Click on Internet Protocol Version 4 and hit Properties.
6.Ensure obtain ip address is marked as Automatic
Ensure obtain DNS servic is marked as Automatic if not check both boxes and close out
7.Disable Firewalls XP:Start/Control Panel/Switch to classic view/Windows Firewall/Turn off
you can access the firewall through control panel with Vista/7
8.Open Command Prompt Windows XP:Start/Run/Type cmd hit ok
Vista/7 Start/All Programs/Accessories/Right click on Command Prompt and hit Run as Administrator.
9.Type: netsh int ip reset reset.log Hit Enter after each Command
Type: netsh int ip delete arpcache
Type: netsh winsock reset
Type: ipconfig /flushdns
10.Restart the computer if this does not work update the Firmware on your router to do so:
Open Browser in address bar type 192.168.2.1 this will bring you to your routers configuration bottom left hand side (Update Filmware) if you are still having issues with it disconnecting refer to Manufactorer
Nov 23, 2010 | Belkin Basic Wireless Router
How to set a static IP address in Windows behind a Linksys Router
Windows 2000/XP 1. Click on the Start menu, and then click on the Run option. 2. When the ?Run? window appears, input control ncpa.cpl into the ?Open? field. 3. After the ?Network and Dial up Connections? or ?Network Connections? window opens, right click on the Local Area Connection or Wireless Network Connection which controls the connection to the router. 4. After the ?Local Area Connection Properties? or the ?Windows Network Connection Properties? window appears, click on Internet Protocol (TCP/IP) then click on the Properties button. 5. Once the ?Internet Protocol (TCP/IP) Properties? window opens, change the option from ?Obtain an IP address automatically? to Use the following IP address. Set the options under ?Use the following IP address? and ?Use the following DNS server addresses? to the following: * IP: 192.168.1.20 (If there are multiple computers being setup with static IP's, then the next computer would be .25, and next would be .30, etc) * Subnet Mask: 255.255.255.0 * Default Gateway: 192.168.1.1 * Preferred DNS server: 192.168.1.1 6. Click OK then OK or Close. Windows 98/ME 1. Click on the Start menu, and then click on the Run option. 2. When the ?Run? window opens, input control netcpl.cpl into the ?Open? field, then click on the OK button. 3. When the ?Network? window opens, locate the TCP/IP for the Wireless or Ethernet adapter in the PC, and click on it. Once it?s highlighted, click on the Properties button. 4. Change option from Obtain Automatically to Specify and input: * IP: 192.168.1.20 (If there are multiple computers being setup with static IP's, then the next computer would be .25, and next would be .30, etc) * Subnet Mask: 255.255.255.0 5. Click on the Gateway tab, and input 192.168.1.1 into the ?Default Gateway? field and click the Add button. 6. Click on the DNS Configuration tab, then go to the ?Host Name? field and input Computer, then go to the ?DNS Server Search Order? field and input 192.168.1.1 then click the Add button. 7. Click OK then OK once more, then windows will prompt for a restart.
Feb 16, 2006 | Linksys EtherFast Cable/DSL Router
Sorry mate but you have kinda lost me here, if you need a static IP address for the internet you need to contact you isp and they will provide you one, if you want to set your machine to set IP Address just go into properties for local network connection and use somthing like 192.168.1.1 255.255.255.0 and leave the dns to obtain. but you wont be able to set a internet static ip address by doing this, only way is to contact your isp.. All the best John
Feb 16, 2006 | Linksys BEFSX41 Router (DHBEFSX41)
How to set a static IP address in Windows behind a WRT55AG Router
Feb 16, 2006 | Linksys WRT55AG Router
1,599 people viewed this tip
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
