Tip & How-To about Coby MP-610 MP3 Player
COBY MP-610 File System Error
COBY MP-610 Digital Media Player File System Error Solution
Replacing the firmware of your Coby 610 MP3 Player will unfreeze it and help it act normally again. This will also fix the 'File System Error' that has been popping up with some Coby 610 players. You can find it at the cobyusa.com website by choosing 'Mp3 & Portable', then 'Mp3 & Mp4 Players', then your model 'MP610', from the support page. Or, here is the direct link to the file from Coby's servers.
Unpacking the archive from the Coby Website will give you a PDF file with instructions, and a program file to run.
Your music will be erased when you run this firmware update. The instructions suggest that even if your mp3 player won't startup properly, if you plug it into your computer you should be able to access it as a removable disk, and copy all your music to a temporary folder on your computer.
Here are the steps:
  1. Plug your MP610 into your computer.
  2. Copy all your music to a temporary folder.
  3. Disconnect your MP610 from your computer.
  4. Disconnect as many USB devices as possible from your computer (to simplify identifying the MP610 at a later step, and avoid damaging other devices by trying to load the MP610 firmware into them by mistake.)
  5. Run the Firmware Update program 'MP610 T LCD Firmware Update for file sys err.exe'
  6. You will see a screen with up to 24 numbered, empty boxes.
  7. Connect the MP610 to your computer. It will show up in one of the boxes.
  8. Once the MP3 player shows up, click on the Firmware Feature icon to start the firmware upgrade.
  9. After the firmware update is complete, you will receive a checkmark in the firmware box.
  10. Disconnect the MP610.
  11. Close the firmware update software.
  12. Turn on the 610 to confirm it starts up and the display reads 'COBY'.
  13. Plug it back into your computer and copy your music back on to it.
Coby MP-610  MP3 Player Logo
Coby 610 MP3
I can help you with you Coby 610 mp3 player.
Replacing the firmware in your mp3 player will unfreeze it.
Please try these steps to fix your Coby MP-610 MP3 Player.
I hope that helps.
Apr 23, 2010 | Coby MP-610 MP3 Player
can't my mp3 player on my computer to down load
Replacing the firmware in your mp3 player will allow your computer to see it, & have it working like new again.
I hope that helps.
___________________________
Unfreeze Coby 610
Apr 01, 2010 | Coby MP-610 MP3 Player
my coby mp3 does not turn on
Replacing the firmware in your mp3 player should have it working like new again.
I hope that helps.
Unfreeze Coby 610
Mar 22, 2010 | Coby MP-610 MP3 Player
Videos and Mistake Format
Replacing the firmware in your mp3 player will fix the file system error & have it working like new again.
I hope that helps.
Unfreeze Coby 610
Aug 05, 2009 | Coby MP-610 MP3 Player
coby mp610 says file sys err
Replacing the firmware in your mp3 player will correct your 'file sys err' message and have it working like new again.
I hope that helps.
Unfreeze Coby 610
Jun 22, 2009 | Coby MP-610 MP3 Player
1,803 people viewed this tip
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
