Tip & How-To about Coby MP-610 MP3 Player
COBY 610 File System Error
Fix the File System Error of Your
COBY 610
Replacing the firmware of your Coby 610 MP3 Player will unfreeze it and help it act normally again. This will also fix the 'File System Error' that has been popping up with some Coby 610 players. You can find it at the cobyusa.com website by choosing 'Mp3 & Portable', then 'Mp3 & Mp4 Players', then your model 'MP610', from the support page. Or, here is the direct link to the file from Coby's servers.
Unpacking the zipfile from the Coby Website will give you a pdf file with instructions, and a program file to run.
Your music will be erased when you run this firmware update. The instructions suggest that even if your mp3 player won't startup properly, if you plug it into your computer you should be able to access it as a removable disk, and copy all your music to a temporary folder on your computer.
Here are the steps:
  1. Plug your MP610 into your computer.
  2. Copy all your music to a temporary folder.
  3. Disconnect your MP610 from your computer.
  4. Disconnect as many USB devices as possible from your computer (to simplify identifying the MP610 at a later step, and avoid damaging other devices by trying to load the MP610 firmware into them by mistake.)
  5. Run the Firmware Update program 'MP610 T LCD Firmware Update for file sys err.exe'
  6. You will see a screen with up to 24 numbered, empty boxes.
  7. Connect the MP610 to your computer. It will show up in one of the boxes.
  8. Once the MP3 player shows up, click on the Firmware Feature icon to start the firmware upgrade.
  9. After the firmware update is complete, you will receive a checkmark in the firmware box.
  10. Disconnect the MP610.
  11. Close the firmware update software.
  12. Turn on the 610 to confirm it starts up and the display reads 'COBY'.
  13. Plug it back into your computer and copy your music back on to it.
Coby MP-610  MP3 Player Logo
I need the firmware for my coby 610-2gb mp3 player but the content website is no longer available so where can I get it
610 firmware update MP3 & Digital Media Players ... - Fixya
www.fixya.com > Forum > Tags > 610 firmware update
Ask your 610 firmware update mp3 and digital media player questions. ... ...610 2GB, purchased year and a half ago, so when i found the new firmware update ... I haveupgraded firmware of my t.soniv 610 with sigmatel MSCNMMC ... firmware of yourCoby 610 MP3 Player will unfreeze it and help it act normally again.
Coby mp610 firmware update - Google Docs
https://docs.google.com/document/d/.../edit Google Docs, Sheets, and SlidesCoby mp610 mp3 player 2gb mp610 2g b h photo video. Firmware upgrades ... I lostmy cd for my coby mp610 4g so i can not syn fixya. Coby mp 610 4gb ...
Coby MP610-4G ' Owners Manual - ManualOwl.com
Jan 01, 2016 | Coby Audio Players & Recorders
How to UnFreeze your Coby 610 MP3 Player and Fix the 'File System Error'
THANK YOU FOR THE INFO. I tried all those steps. And is kept bouncing back with there is no UBS device. I tried over and over it was not recognizing my player. I had to bring it back to the store and just upgraded to MP620. I haven't had any problems yet .....Thanks again for the feedback.
Dec 31, 2009 | Coby MP-610 MP3 Player
my coby mp 610 turned of apparently while i was listening to it but the screen is still bright and it wont do anything now. How do i fix that?
Here are instructions for a solution to your Coby 610 MP3 player acting up.
Unpacking the zipfile from the Coby Website will give you a PDF file with instructions, and a program file to run.
Here are the steps:
You can refer to this Coby 610 solution here.
I hope that helps.
Jan 03, 2010 | Coby MP-610 MP3 Player
Videos and Mistake Format
I can help you with you Coby 610 mp3 player.
Replacing the firmware in your mp3 player will fix the file system error & have it working like new again.
Please try these steps to fix your Coby MP-610 MP3 Player.
I hope that helps.
___________________________
Unfreeze Coby 610
Aug 05, 2009 | Coby MP-610 MP3 Player
1,656 people viewed this tip
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
