Tip & How-To about Computers & Internet
SYSTEM RESTORE ON ANY WINDOWS OPERATING SYSTEM
System restore must be turn off ....on all windows operating system.then only the antivirus will work perfectly.....
Computers & Internet Logo
how+to+delete+remove+virus+manually
hi,
shut off system restore in system properties in control panel and then do a boot time scan of your antivirus. somewhere in your antivirus settings will be a boot time scan, which means the antivirus will run before windows starts, turn that on then reboot, let the antivirus clean it up. restart . turn restore back on, run checkdisk by right clicking your c drive in my computer navigate further untill you find checkdisk and run that to make sure your registry is OK.. download ad aware and spybot over up and above your antivirus and dont fileshare unless you know how to check the files before you download them..
jm
Apr 30, 2011 | Computers & Internet
my operating system is XP S3 Antivirus - Norton
that's common in norton that's why i'm not using it anymore,they are repeating scanning virus even you delete or remove..and they also hard to remove from your system..on my part i restore my system to when before i installed norton..so do the restoration system
Feb 14, 2011 | Microsoft Windows XP Professional
My Mcafee antivirus is not working and system has found errors. Also, Internet explorer is not opening. It has showing syntax errors and asking for sending reports. kindly suggest what to do?
This problem actually arises when some of your System Files get corrupted. Getting back your original setup is almost impossible. You have told that your antivirus is not working, so there is a very strong possibility that your system has got corrupted by the virus infection. Firstly, I recommend you to scan your system with a well-established antivirus.....likely AVG Antivirus (if you are using Pirated Windows Copy) or Microsoft Security Essentials (if you are using Original Windows Copy). If this antivirus shows viruses and you are unable to get back your original system files, then go for Windows Update (for Original Windows) and your files be restored. If this one also does not help you, then go for the System Restore option. This can help you to restore your files to a better condition. You can find System Restore in the All Programs>Accessories>System Tools>System Restore option. Let's hope that this will serve you well.
Feb 04, 2011 | Computers & Internet
OSD is popping up randomly these days hiding important/points control buttons etc while working reducing my productivity substantially. controls in OSD also not responding as required.Otherwise monitor is working perfectly alright even after 5-6 yrs working. Any solution please???
hi there, virus can change your windows set up, up to bios set up,even you have anti virus not all are blocked by antivirus.if still you have at least a normal windows right now and you can restore your system,go to the restore point system and restore your pc when this run and smoothly to take back your good operating system.but if at start it can't open windows re install your windows again to put back yo ur operating system.have a nice day fix my rate thanks
May 07, 2010 | Computers & Internet
how do i get rid of a W32.SillyFDC virus
The following instructions pertain to all current and recent Symantec antivirus products, including the Symantec AntiVirus and Norton AntiVirus product lines.
  1. Disable System Restore (Windows Me/XP).
  2. Update the virus definitions.
  3. Run a full system scan.
  4. Delete any values added to the registry.
For specific details on each of these steps, read the following instructions.
1. To disable System Restore (Windows Me/XP)
If you are running Windows Me or Windows XP, we recommend that you temporarily turn off System Restore. Windows Me/XP uses this feature, which is enabled by default, to restore the files on your computer in case they become damaged. If a virus, worm, or Trojan infects a computer, System Restore may back up the virus, worm, or Trojan on the computer.
Windows prevents outside programs, including antivirus programs, from modifying System Restore. Therefore, antivirus programs or tools cannot remove threats in the System Restore folder. As a result, System Restore has the potential of restoring an infected file on your computer, even after you have cleaned the infected files from all the other locations.
Also, a virus scan may detect a threat in the System Restore folder even though you have removed the threat.
For instructions on how to turn off System Restore, read your Windows documentation, or one of the following articles:
Note: When you are completely finished with the removal procedure and are satisfied that the threat has been removed, reenable System Restore by following the instructions in the aforementioned documents.
For additional information, and an alternative to disabling Windows Me System Restore, see the Microsoft Knowledge Base article: Antivirus Tools Cannot Clean Infected Files in the _Restore Folder (Article ID: Q263455).
2. To update the virus definitions
Symantec Security Response fully tests all the virus definitions for quality assurance before they are posted to our servers. There are two ways to obtain the most recent virus definitions:
  • Running LiveUpdate, which is the easiest way to obtain virus definitions.
    If you use Norton AntiVirus 2006, Symantec AntiVirus Corporate Edition 10.0, or newer products, LiveUpdate definitions are updated daily. These products include newer technology.
    If you use Norton AntiVirus 2005, Symantec AntiVirus Corporate Edition 9.0, or earlier products, LiveUpdate definitions are updated weekly. The exception is major outbreaks, when definitions are updated more often.
  • Downloading the definitions using the Intelligent Updater: The Intelligent Updater virus definitions are posted daily. You should download the definitions from the Symantec Security Response Web site and manually install them.
The latest Intelligent Updater virus definitions can be obtained here: Intelligent Updater virus definitions. For detailed instructions read the document: How to update virus definition files using the Intelligent Updater.
3. To run a full system scan
  1. Start your Symantec antivirus program and make sure that it is configured to scan all the files.
    For Norton AntiVirus consumer products: Read the document: How to configure Norton AntiVirus to scan all files.
    For Symantec AntiVirus Enterprise products: Read the document: How to verify that a Symantec Corporate antivirus product is set to scan all files.
  2. Run a full system scan.
  3. If any files are detected, follow the instructions displayed by your antivirus program.
  4. Delete the autorun.inf file from writeable removable devices, if necessary.
Important: If you are unable to start your Symantec antivirus product or the product reports that it cannot delete a detected file, you may need to stop the risk from running in order to remove it. To do this, run the scan in Safe mode. For instructions, read the document, How to start the computer in Safe Mode. Once you have restarted in Safe mode, run the scan again.
After the files are deleted, restart the computer in Normal mode and proceed with the next section.
Warning messages may be displayed when the computer is restarted, since the threat may not be fully removed at this point. You can ignore these messages and click OK. These messages will not appear when the computer is restarted after the removal instructions have been fully completed. The messages displayed may be similar to the following:
Title: [FILE PATH]
Message body: Windows cannot find [FILE NAME]. Make sure you typed the name correctly, and then try again. To search for a file, click the Start button, and then click Search.
4. To delete the value from the registry
Important: Symantec strongly recommends that you back up the registry before making any changes to it. Incorrect changes to the registry can result in permanent data loss or corrupted files. Modify the specified subkeys only. For instructions refer to the document: How to make a backup of the Windows registry.
  1. Click Start > Run.
  2. Type regedit
  3. Click OK.
    Note: If the registry editor fails to open the threat may have modified the registry to prevent access to the registry editor. Security Response has developed a tool to resolve this problem. Download and run this tool, and then continue with the removal.
  4. Navigate to the following registry subkeys:
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders
    HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Windows\"load"
  5. In the right pane, delete any values associated with the worm.
  6. Exit the Registry Editor.
Dec 18, 2008 | Microsoft Computers & Internet
129 people viewed this tip
David Payne
David Payne
