Tip & How-To about Computers & Internet
How to obtain the latest Windows Vista service pack?
Introduction:
Windows Vista updates are distributed in service packs. Service packs
help keep Windows Vista current, and they can extend and update the
functionality of your computer. This article describes three
step-by-step methods that you can use to obtain the latest service
pack for Windows Vista. However, before you select the method that you
want to use, please make sure that the following conditions are true:
The service pack is not already installed on your computer.
You are logged on to your computer by using a user account that is a
computer administrator.
The computer on which you want to install the service pack is
connected to the Internet.
If you are not sure that all these conditions are true, please see the
"Before you try to download the latest Windows Vista service pack"
section. Otherwise, select the method that you want to use to download
and install the service pack.
Methods to download the latest service pack
Method 1: Turn on Automatic Updates (Recommended for most users)
Method 2: Check for updates on Windows Update (Same as Method 1 but
not automatic)
Method 3: Obtain the latest Windows Vista service pack from the
Microsoft Download Center (Good to use if the computer on which you
want to install the service pack is not connected to the Internet)
Important: Windows Update may not offer the latest Windows Vista
service pack to some users. This issue can occur for several reasons.
For a full list of causes and resolutions, click the following article
number to view the article in the Microsoft Knowledge Base:
948343 Windows Vista service packs are not available for installation
from Windows Update and are not offered by Automatic Updates
Computers & Internet Logo
network sharing center won't stay open
just been fixing a window vista laptop with problems
Microsoft stopped supporting windows vista years ago
no updates or upgrades
you are at base service pack one
and computer should have been updated to service pack 3 years ago
from service pack 3 a windows 10 upgrade is possible
try an ethernet or usb wifi connection .
.see if the computer will run the way you want it
any windows vista computer is a x32 bit system
with upgrades can run x64
x86 is the current
if you are running anything higher than 32 or x64 software the computer will be slow sometimes freeze or shut down
vista came out same time as and dial up internet
and early broad band
vista can run office 95 but windows 2000 is stable
May 29, 2016 | Microsoft Windows Vista Home Premium with...
pro tools m-powered problem
You may need to check to see which "service pack" you are currently on.
See below requirements:
System Software — Windows XP & Vista
  • Windows Vista Business or Ultimate Edition
    • 32-bit OS Installation Only
  • Windows XP Professional or Home Edition
    • With Windows XP Service Pack 2 or Service Pack 3
  • Not Supported:
    • Windows Vista 64-bit (any version)
    • Windows XP Professional x64 Edition
    • Windows XP Media Center Edition
    • Windows 98, Me, 2000, NT, 95, 3.1, DOS
  • Not Tested:
    • Windows Vista Home and Home Premium Edition
    • Although Windows Vista Home and Home Premium Edition have not been tested or qualified by Digidesign, there are currently no known issues with Vista Home and Home Premium 32-bit operating systems and Pro Tools M-Powered 7.4 compared to the supported Windows Vista Business or Ultimate Edition operating systems.
Windows Vista SP1
There are currently no known issues with Service Pack 1 for Windows Vista based on our initial limited testing and customer feedback. Although full qualification with all Digidesign products has not been completed, we do not recommend against updating to SP1, given the number of important overall system fixes in SP1. We do recommend that you backup your system and create a restore point before updating to SP1, should you encounter any problems after installing the update.
Sep 21, 2009 | Computers & Internet
WINDOWS UPDATE WILL NOT WORK IN WINDOWS VISTA HOME PREMIUM
Hey try to do this now
1: Open up "Control Panel" and navigate your way to "Programs and Features".
2: Click "View installed updates" on the left hand side.
3: Find the update KB929777 and uninstall it.
4: Attempt to install the update again in Windows Update
5: Once successful, restart your PC.
and if it works thats good but if it ddnt let me know plz
Dec 02, 2008 | Microsoft Windows Vista Home Premium with...
Service pack
Microsoft releases updates to Windows on a regular basis. That is what "Windows Update" is doing. These are patches to fix bugs, or vulnerabilities in the OS.
Occasionally, MS releases a major update to the OS. This update may add new features, or be a rewrite of an important component of the OS. These updates are called "Service Packs", and they are numbered.
The current version of XP is Service Pack 3, and if you haven't installed the update, it's a good idea for you to do so. The same for Win 2003 Service Pack 2.
ANY Windows machine you have should have the automatic updates turned on, to keep your system up to date.
Jul 20, 2008 | Microsoft Windows Server Standard 2003 for...
204 people viewed this tip
David Payne
David Payne
