Tip & How-To about Plumbing
How to check for a leak in the water pipe of your building.
First you must ask your self, well water or city water? Well Water , first turn all plumbing off, no sinks showers dish washers running ext. Second sit and wait by the pressure tank, watch the gage if it drops and the well pump kicks on you have a leak.When doing this it make take a while of sitting their and watching depending on how small the leak is.
City Water First thing turn all plumbing off, no sinks showers dish washers running ext. second watch the water meter, if it moves then u have a leak, the smaller the leak the less it will move and the longer you will have to sit and watch.
Toilets have fill valves that fill the tank up after each flush, and a flapper that allows the water to drain. these parts go bad over time and should be checked once a year you insure you aren't wasting water and money.
Plumbing Logo
does shower / tub drain into black water tank
Would depend on the plumbing, but usually yes. Only toilet water doesn't.
If you have access to the black water tank, you can put dye in the shower, and then test it.
Jul 07, 2016 | Home
I JUST INSTALLED A TITAN N-120 TANKLESS HOT WATER HEATER AND IT WORKS FINE FOR ALL THE SINKS BUT IT IS NOT PROVIDING HOT WATER TO THE SHOWER AND THE WATER FLOW HAS DIMINISHED IN THE SHOWER AS WELL.
It's doubtful your water heater unit is the problem. There is simply no reason for it to only work on sinks unless some how the pipe size was drastically reduced coming out of the unit so sinks got plenty of hot water but the shower does not. Take a second look at the installation. The pipe should not be less than 1/2" coming out. If that's OK then consider a clog or valve problem.
May 18, 2015 | Titan SCR2 N-120 - 11.8 KW Tankless Water...
dishes not dry enough & leak of water at sink vent device
HEATED DRY.Turns the drying heater on for fast drying.
ENERGY SAVER (no heat boost). Turns the drying heater off to save energy. Dishes will dry naturally over a longer period such as overnight. lf you need your dishes sooner, open the dishwasher door after the cycle is complete to reduce the natural drying time. Use of this option reduces the electrical energy used by this model approximately 7%. A rinse agent makes water flow off dishes quicker than usual. This lessens water spotting and makes drying faster, too.
Make sure inlet water temperature is correct.(SeePage6.)
Unload the bottom rack first.Water from dishes in the top rack may be spilling in to the
bottom rack.
Check for improper loading.Dishes shouldn’t nest together. Avoid overloading. Check the rinse agent dispenser to see that it’s not empty.
Inlet temperature....Good Dish washing starts with hot water, To get dishes clean and dry,you will need hot water.To help you get
water of the proper temperature, your dish washer automatically heats the water in the wash cycle. For good washing and drying , the entering water must be at least 120°E To prevent dish damage,
inlet water should not exceed 150”F. How to test water temperature: Check the water temperature inside your dishwasher with a candy or meat thermometer. Let the dishwasher run through
one fill and pump out cycle, then let the dishwasher fill with water
the second time. When you hear the water stop filling, unlatch the door and slowly open it. Measure the temperature of the water in the bottom of the tub this way: Remove the silverware basket and
place a candy or meat thermometer in the water towards the middle of the tub. If the temperature is less than 120”F,you will not get good washing results. Higher water temperature is needed to dissolve grease and activate powder detergents. If the unit is a long way from the DW you may need to let the water run in the sink until hot before starting the DW....or if is a cold day and water has not been used in a while the pipes could be cold....also if you have just used the hot water ( washer, shower...etc) give it time to recover first before using DW....All of the above mentioned material is straight out of the Users guide...but you may have an element that is going out also...so check the temp of your water and open it during the drying cycle to see if it is hot or at least warm inside...if not your element may need to be replaced...
I hope this helps...have a great day & good luck...please rate my effort.... the Fang.
Jan 06, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
dishes not getting clean
when your dishwasher was reinstalled was the discharge hose loop up high behind dishwasher to prevent the water from draining? Also make sure that there is air gap where the hose ties into the drain.
Nov 22, 2006 | Kenmore 18 in. 14432 / 14439 Built-in...
337 people viewed this tip
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
