Tip & How-To about Computers & Internet
My Hp dv6000 laptop battery is not working?
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Your battery is likely dead. Batteries over time lose their charge and eventually fail completely. I had a DV9000 laptop and after about a year or so it would report the battery was fully charged but it would only last 15 or so minutes before dying completely. Yours has probably met this fate.
Also, the HP DV6000 and DV9000 series of laptops (some batches) had defective batteries out of the box that there was a wide spread recall on (although HP did not publicize this much unfortunately so many that actually were affected never was notified of it, you might want to check HP's website to see if your products SKU was part of the recall.
But if your system is out of warranty they probably won't honor the recall at this point.
It might just be time for a new battery. HP DV6000 Battery
Computers & Internet Logo
My hp DV6000 stays charging at 86% and will not complete the charge.
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all.
OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time.
If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Jun 30, 2010 | HP Pavilion dv6000z Notebook
My HP DV6000 was stuck on 5% then I followed he advice of others on this website and removed the battery it then charged up to 28% and stopped. So I tried it again and it went up to 29% and stopped, so I uninstalled Microsoft ACPI and reintsalled it and it charged up to 30% and stopped. So now its stuck at 30%, any suggesstions?
If the laptop battery is 3 - 5 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time until they won't charge up at all.
Nov 12, 2009 | HP Pavilion dv6000z Notebook
My battery is at 0% and does not charge and whenever i take out the power chord my computer automatically turns off. Any help
here is a good resource I found:
Solution for HP Pavilion DV6000 Battery Not Charge
  • Reinstalling the power management software has just fixed it for me. Go to device manager and under batteries, unistall the Microsoft ACPI Compliant Control Method Battery. Go to Actions on the menu bar and select ’scan for hardware changes’. It will reinstall it and hopefully start charging immediately (mine did anyway).
  • If your HP Pavillion dv6000 has a battery that won’t charge yet still turns on when plugged in, turn off the laptop and remove the battery then wait for around 30 seconds, re-insert it and turn it back on, the charging update should say, plugged in, charging.
  • I made the bios update, and works for me. My Dv6000 battery problems were fixed. The battery led always blinking every time and the battery didn’t charge. Now it’s ok !
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us&lang=en&dlc=en&product=3245619
  • If it is still under warranty you can chat with an online hp tech who will check it out over the internet and send you a replacement for free. the dv 6000 laptops have a recall on a few problems and there is a bios update to fix it before it happens but will not correct it after the fact the recall on specific problems extends the warranty to 24 months http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us&lang=en&dlc=en&product=3245619 should get you to the warranty page.
  • Just got it to charge again.While the laptop is powered and in Windows XP, press and hold the POWER button until it dies. Then, remove the dv6000 laptop battery. Power it back up and enter Windows. Then, re-insert the battery.
  • So I always remove the Hp dv6000 battery after I have powered down the laptop, and I have not had any battery problems since then!
  • I had the same issue my fix was a new cmos battery that was only $10.00 and install updated bios software from HP
  • I had the dv6000 battery problem where it showed my battery NOT CHARGING. I took it apart because my QUICKPLAY would not work either and the QUICKPLAY lights stayed on even after I shut down the laptop. I found that the black ribbon cable on the right (the other looks the same but you can see it is for the power button) was slightly kiltered in the flat socket it goes to underneath the area where the quickplay button is. I straightened it out and made sure it was pushed all the way in and locked and put it all back together and everything worked perfectly after that. About a month before that my POWER and SOUND didn`t work. I did the same thing to fix those problems. MAKE SURE YOU HAVE THOSE CABLES EXACTLY RIGHT in there, IT MAY JUST BE YOUR PROBLEM TOO.
  • Some people dont realise that you should avoid short charges and discharges, if your batery does not go above 40% mabe its charge memory thinks its full. to fix this problem let the batery run fully down, then charge it all the way again. try it a few times if it doesnt work. and you have to go all the way, not let windows go into hibernation. to do that you need to get the batery low, then boot to some boot disk and let it sit till the batery dies.
  • HP has posted BIOS updates to address battery problems as well as the auto startup on some.If you will post the full model number,someone can help you find your driver/updates page.
Hope this helps, please rate! ^_^
Jun 23, 2009 | HP Pavilion dv6000z Notebook
143 people viewed this tip
David Payne
David Payne
