Tip & How-To about Car Audio & Video
How to choose a car amplifier
I have seen several (ok, MANY) posts here lately, asking about how to choose an amplifier, with all sorts of "Is this good...?" types of questions.
Here is what I look at when choosing an amplifier, and in their order of preference:
1. Power. I know, this is where MOST people look first, but it's the very reason you are buying an amp, right? Also knowing Ohm's Law, and knowing that I will almost always load an amplifier with the maximum specified impedance (impedance - 4 ohms or higher, NOT load - 4 ohms or lower), I need to know exactly how much power I am looking at to start with. When loading an amp with a higher impedance, the amp will make less power, so I have to keep this spec in mind the whole time. My speakers are almost always chosen before I decide to start looking for an amplifier, I know the impedance and efficiency numbers when I start. This will help me decide how much power I need or want for that particular driver compliment. I will NEVER look at "Max Ratings". They are often worthless, generally overinflated, selling tools, designed by old-school, low-end amplifier companies, originally made to sell product. (You remember how it went (and still goes today)... This 800 watt amplifier is only 200 dollars, but the Nakamichi 160 watt monoblock is 1300 bux for the pair. Which were (are) YOU going to buy?) Ahhhh, the power of advertising... Classic Nakamichi, Alpine, Linear Power, Orion, Eclipse, etc., THEY never posted "Maximum Power" numbers, did they? Unfortunately, even the good products of today will state maximum power output, I just disregard the numbers posted.
2. Signal to noise ratio. This one I place a bit more weight on, especially when the amplifier is going to be used in a mid-bass (important), mid-range (more important) or highs (MOST important) application. The higher the better, and there is no exception to this rule for me. Amps with tube stages are typically less capable than their solid state stablemates in this area, but I do make exceptions for tube amps. It is NOT a terribly important spec for a bass amp, so when shopping for a bass amp, don't bother with this number. Dedicated bass amps, BTW, usually offer awful SNR numbers.
3. Efficiency. Here's where you will be able to tell a decent manufacturer from the ****. Let's say you are looking at an 250 watt (RMS) amplifier. The first physical thing I look at, is how big a fuse do they recommend (or what size fuse is in the end of the amp)? I know right now that 250 watts OUT will demand (and I use 50% efficiency to keep it simple) 500 watts in. 500 watts in, divided by the (car running) battery voltage (14.4v) is about 35A. If I look at the end of the amp, and see a 20A fuse, I'm walking away, as there is no way that amp can make 250 REAL watts, continuously. 14.4v times 20A, equals 280 watts in. 250 watts out, divided by 280 watts in, translates to an 89% efficiency. In a class A/B amp, this is an impossible number, and it even stretches the imagination for digital amps, as well. The theoretical MAXIMUM efficiency for class A/B is 66%, (95% for digital) so someone is lying. I don't care WHO the manufacturer is, if these numbers don't add up, I will start looking elsewhere... Now, if all the other specification look good, AND I can get in the vicinity of the RMS power I am looking for, I will buy an amp that's efficiency number might be stretching the truth a bit. My old Nak 160 watt monoblocks had 40A (that's 480 watts in - a 33% efficiency, people!) fuses in each one, and they ran hotter than a firecracker, even loaded at over 8 ohms. I liked that.
4. Terminals. A frequently overlooked part of an amp, this is a very important part of an amp to me. A car is a place frought with vibrations. A cheap or cheezy feeling connector in power or speaker terminals and most ESPECIALLY in the RCA inputs, will often cause problems in the future. Setscrews for power, quality terminal blocks for speaker outputs, and Tiffany style RCA connections (the type attached to the chassis, rather than a block of plastic soldered to the PC board.) The quality of the I/Os can be a direct indicator of the attention to detail paid to the rest of the piece. Translation? Overall Quality.
5. Heat sink. This one is simple. How does it look? I eventually chose Eclipse gear, because it looked like jewelry. Fine finish and appearance. Also, heatsink size and quality can be another indicator of quality of the amplifier as whole. A heavy heatsink will also provide better thermal stability, a nice thing in an amp.
6. Damping Factor. I used to place more emphasis on this spec, but my research recently (over the last few years, really) has, while not proven to me it is a useless spec, has not proven to me it is an extremely important spec. This is why this particular spec is a little further down the list. While I place a bit more emphasis on it for a bass or mid-bass amp, I, admittedly, place less weight here than I used to...
7. Price. Money rarely means much to me in an amp, (much like my computers - "Life's too short to build slow computers." - David Draper) it's something I am going to be keeping for a long time usually, so I will save if necessary to get EXACTLY (or close to) what I am looking for.
These are the things I look for when trying to decide on an amp. OBVIOUSLY, there are going to be VERY few amps on the market that will make me happy across the board, but then some of the physical characteristics listed above can be made to fit me and my desires with a little time, a couple extra bux, and some careful use of a soldering iron. All of the above things will cost more, but it will ADD more to the finished product as well...
Car Audio & Video Logo
i have several biostar k8m800-m7 installed with GeFORCE mx4000V 128mb and AMD Sempron which i purchased several years ago and they all work OK. during debugging works, i'm using one unit without any graphics card and it still works ok. however, lately, i planned to use again the graphics card but the unit does not beep, and it did not release any video signal.
Your motherboard did not post . When this happens nothing works. Your card is probably good.
But before we jump the gun, just make sure that it is not a power supply issue that is preventing startup. Try another known working supply to see if the mo bo works. If not, then it is a cmos issue
Sep 16, 2017 | Biostar K8M800-M7A Motherboard
I see someone asking about this amp running a single 15" sub, how about running 2 10" subs?
Do you know how many ohm's the two 10" subwoofers are ? That is important as there are many ways to wire multiple subs. If you dont know then post what make and model the subs are.
Post back and I will try to be of further assistance.
Thank you for choosing Fixya!
Feb 15, 2010 | Rockford Fosgate Punch 401S Car Audio...
connection failed
First check your broad band's signal status by opening a DOS command by choosing run in the start up menu. type cmd and then type ipconfig. Next exit and open control panel, choose internet connection then click. Disable first broadband connection and plug out broad band's power supply. After that reconnect altogether and open a web.
Jun 23, 2009 | Dell Dimension 3000 PC Desktop
Two Jamo MPA-101 amps not working
I can almost guarantee that you'll find bad electrolytic caps on the power supply board to be the cause of the problem. I've seen several of these with the same problem. The protect circuit stays latched due to excessive ripple.
Dec 16, 2008 | Jamo MPA201 2-Channel Amplifier
Stopped working
either your amp is blown which it very well could be. or your just hooking something up wrong in the wiring. make sure ur battery wire and small blue amp wire are secure with a good ground
Jul 11, 2008 | Rockford Fosgate Punch 300S Car Audio...
398 people viewed this tip
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
