Heaters Logo
Tip & How To about Heaters
Electric Water Heater Wiring Diagram
Posted by D. Floyd KolbD. Floyd Kolb on Saturday, March 27, 2010
If you are changing a water heater thermostat on your hot water heater, or would just like to troubleshoot your hot water heater, you may want to know how it is to be wired.
Here is a diagram of the way a normal electric hot water heater with two elements that run non-simultaneous will be wired. This means that only one element at a time will be working and have power going to it. The top element will heat water until it is heated to your set point and then it will switch the power to the lower element to heat the bottom of the tank. This gives you some hot water quickly, and then heats the rest of the tank.
For more information on how to troubleshoot electric hot water heaters you can check out this tip.
http://www.fixya.com/support/r4654730-electric_water_heater_not_working
http://www.fixya.com/support/r4656190-electric_hot_water_heater_temperature
Read more tips from D. Floyd Kolb
