Tip & How-To about Computers & Internet
Turning off the Windows Autorun Feature on DVD/CD's
1) Click Start, Run and enter GPEDIT.MSC
2) Go to Computer Configuration, Administrative Templates, System.
3) Locate the entry for Turn autoplay off and modify it.
Computers & Internet Logo
system restore has been turned off by group policy
1. Click Start, Run and type regedit.exe and press Enter
2. Navigate to the following key:
HKEY_LOCAL_MACHINE \ Software \ Policies \ Microsoft \ Windows NT \ SystemRestore
In the right-pane:
  • Delete the value DisableConfig
  • Delete the value DisableSR
3. Exit the Registry Editor.
In Windows XP Professional, you can accomplish the above using Group Policy Editor as well.
1. Click Start, Run and type GPEDIT.MSC
2. Navigate to this path:
-> Computer Configuration
--> Administrative Templates
---> System
----> System Restore
3. Set Turn off System Restore to Not Configured
4. Set Turn off Configuration to Not Configured
Nov 24, 2009 | HP Pavilion dv1000 Notebook
my system restore has been turned off by a group policy "whatever that means"
Resolution 1. Click Start, Run and type regedit.exe and press Enter
In the right-pane:
---> System
For standalone Windows Vista systems, use these steps:
Using the Group Policy Editor
If your edition of Windows Vista includes the Group Policy Editor snap-in (gpedit.msc), follow these steps:
1. Click Start, type gpedit.msc and press ENTER
2. Go to the following branch:
Computer Configuration | Administrative Templates | System | System Restore 3. Double-click Turn off Configuration and set it to Not configured.
Note: If the above setting is already set to Not configured, set it to Enabled and click Apply. Then revert back the setting to Not configured, and click Apply, OK.
4. Exit the Group Policy Editor.
Using the Registry Editor
1. Click Start, type regedit.exe and press ENTER
HKEY_LOCAL_MACHINE \ Software \ Policies \ Microsoft \ Windows NT \ SystemRestore 3. In the right-pane, delete the value named DisableConfig
4. Exit the Registry Editor.
If you set the Turn of configuration option to Enabled, the option to configure System Restore on the Configuration Interface disappears. If the Turn off Configuration setting is disabled, the configuration interface is still visible, but all System Restore configuration defaults are enforced, and the Create button is grayed out. If you set it to Not configured, the configuration interface for System Restore remains, and the user has the ability to configure System Restore.
regards
iversh
if you felt i ve spent my time for answering your query.... kindly rate the service very helpful
Aug 30, 2009 | HP Compaq Presario SR2013WM (RE468AA#ABA)...
want to unable Autoplay option
go to start menu then u see run.
type in run "gpedit.msc"
then enter and u can see group policy editor.
then go to user configuration -administrative templates - system then u can find in right window
"turn off autoplay" doubler cl kit and disable it.
Jun 02, 2009 | Microsoft Windows XP Professional SP2
Auto Play
* Click Start
* Click Run
* Enter GPEDIT.MSC
Group Policy mmc will popup. On left panel:
* Double-click Computer Configuration to open submenu
* Double-click Administrative Templates to open submenu
* Double-click System to open submenu
* Double-click Turn autoplay off option which will be near the bottom of the list in the right panel.
The default is the Not configured. Set it to Enabled."
May 05, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
119 people viewed this tip
David Payne
David Payne
