Tip & How-To about Nokia N73 Cellular Phone
How to use the pencil key in nokia n70,73
1.Press and hold the pencil key.. and move towards those items using the navigation keys.. the marked items are highlighted with a tick beside.. you can send them or delete them
Nokia N73 Cellular Phone Logo
How do you reset the blackberry 9360
Restore factory default settings
When you restore the factory default settings, all personal settings are reset. Follow these instructions to restore the factory default settings.
All phone data will be deleted. Data on your SIM isn't deleted.
1. Find "Security Wipe"
Press the Menu key twice.
Scroll to Options and press the Navigation key.
Scroll to Security and press the Navigation key.
Scroll to Security Wipe and press the Navigation key.
2. Restore factory default settings
Highlight Emails, Contacts, etc., User Installed Applications or Media Card and press the Navigation key.
When the box next to the menu item is ticked (V), the selected data will be deleted.
Highlight the field at the bottom of the display and key in blackberry
Scroll to Wipe and press the Navigation key to restore the factory default settings.
Follow the instructions on the display
Oct 15, 2014 | Cell Phones
How to reset blackberry 9320 to factory settings
  • Press the Menu key twice.
  • Scroll to Options and press the Navigation key.
  • Scroll to Security and press the Navigation key.
  • Scroll to Security Wipe and press the Navigation key.
  • Highlight Emails, Contacts, etc., User Installed Applications or Media Card and press the Navigation key.
  • When the box next to the menu item is ticked (V), the selected data will be deleted.
  • Highlight the field at the bottom of the display and key in blackberry
  • Scroll to Wipe and press the Navigation key to restore the factory default settings.
  • Follow the instructions on the display to set up your phone and prepare it for use.
Jul 25, 2014 | Cell Phones
why won't the number 1,0 and space bar button work?
Have you tried a battery pull...... restart by removing the battery while your device is Powered On , try it and see if you're able to access your keyboard . you can try factory default to reset phone ...When you restore the factory default settings, all personal settings are reset. Follow these instructions to restore the factory default settings.
  • Highlight Emails, Contacts, etc., User Installed Applications or Media Cardand press the Navigation key.
May 13, 2014 | RIM Blackberry Curve 9320 Smartphone -...
how to reset samsung s w299
1 Find "Reset settings"
  • Press the Navigation key to access the main menu.
  • Scroll to Settings and press the Navigation key.
  • Scroll to Reset settings and press the Navigation key.
2 info.png Restore the factory default settings
  • Tick the required settings by pressing the Navigation key.
  • When the box next to a menu item is ticked (V), the setting will be reset.
  • Press Reset.
  • Press the Navigation key to confirm.
  • Key in the phone lock code and press the Navigation key.
  • If it is the first time you use the phone lock code:
  • Key in the phone lock code again and press the Navigation key.
  • The selected settings are reset.
3 Exit
  • Press Disconnect to return to stand-by mode.
Jun 25, 2011 | Cell Phones
How do I use a micro sd card to save photos?
Before doing the steps pls format the memory card first
To transfer pictures to memory card follow the steps below:
  1. Remove the memory card slot cover, located on the upper right side of the handset
  2. Insert a microSD memory card into the memory card slot, until it locks in place
  3. From the standby screen, press the left soft key for Menu
  4. Select My Stuff (7)
  5. Highlight Graphics, using the navigation keys
  6. Press the left soft key for Options
  7. Select Open (1)
  8. Highlight desired Photo, using the navigation keys
  9. Press the left soft key for Options
  10. Select either Move (4) or Copy (5)
  11. Select either Selected (1) or Multiple (2)
    • If Multiple, highlight each Photo, using the navigation keys
    • Press thecingular%20logo%20only.jpg key to check each Photo’s box
    • Press the left soft key for either Move or Copy
    • Highlight Memory Card, using the navigation keys
    • Press the left soft key for Select
    • Highlight the Graphics folder, using the navigation keys
    • Press the left soft key for Options
    • Select Paste to selected folder (2) to Move or Copy the Photos to the microSD memory card
  12. Highlight Memory Card, using the navigation keys
  13. Press the left soft key for Select
  14. Highlight the Graphics folder, using the navigation keys
  15. Press the left soft key for Options
  16. Select Paste to selected folder (2) to Move or Copy the Photos to the microSD memory card
  17. Remove the microSD memory card from the memory card slot
Oct 19, 2009 | Samsung SGH-A707 Cellular Phone
1,934 people viewed this tip
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
