Tip & How-To about Plumbing
Choosing a good toilet
Tired of that old(or new) toilet plugging up every time the cat or other small child uses it? Time to choose a new one that will actually work.
Many manufacturers of toilets like to live off their name brand. Name brand does not mean the toilet is any good. How well a toilet works is really a function of design.
Two factors are most important when choosing a functional toilet.
1. Trap size - The bigger the trap size the more toys it will flush at one time.
2. Trap shape - You can see the trap shape/design on the rear side of the bowl. It generally resembles a snake in shape. The problem is that the engineers haven't realized that solids do not make 90degree turns very easily. If you go to your local plumbing store and study all the trap designs you will see some very creative designs that go up and then straight down to the floor and then make a 90 degree turn to run to another 90 degree turn that goes straight down. Avoid this design like the plague. Choose designs that have wide sweeping turns.
If your toilet has a wide sweeping trap design with no sharp turns and it somehow gets plugged - take a wild guess how hard it will be to plunge? yeah its very easy compared to dead end 90 degree trap designs.
I actually broke a blood vessel in my hand trying to plunge one of those 90 degree turn toilets. I wonder if I can sue for personal injury, mental distress etc.
I have been teaching folks the "common sense about toilet design" ever since.
Try it. You will thank me.
*A few extra notes about toilet design. Most engineers seem to be more interested in designing toilets to use very little water. This is apparently a big enough deal that functionality doesn't matter. However if you design a toilet to use only 1 gallon of water versus 1.8 per flush but you have to flush it 4 times while plunging it to actually get it to work, what have you saved?
Plumbing Logo
We have a 'low volume water' new toilet. It became badly plugged with solid waste, and we cannot unplug it with a plunger, as we used to with our old 'high volume' toilet. What can we do, short of calling a plumber?
the actually make a plunger for the low volume toilets. your old plunger will not work very well. the bowl has a much more drastic slope to it. your best bet is to buy a new plunger and a cheap auger for it.. some of them work well, some never will.
Dec 10, 2010 | Kohler Home
American Standard Cadet 3 - bowl water slowly drains
try putting some food coloring in it to see if it's leaking anywhere. the coloring will help you identify where it's leaking
Aug 21, 2009 | American Standard Cadet 3 Right Height...
dropped phone in toilet. please please please help. i need my ph.
http://www.fixya.com/support/r3771170-phone_water_damage
Apr 24, 2009 | Motorola Mobility RAZR V3
hole in back of toilet (stool) leaks water.
The hole your refering to is common in the manufacturing of toilets and is generally filled before it leaves the manufacturing. I have repaired several toilets, new toilets, all American Standard, using a good grade of epoxy - not silicone. I used West System epoxy as this is made for marine projects and surprisingly states "toilet repair" as one of the uses of their product. I'd suggest carefully chipping the smooth porcelan around the hole to give the epoxy something to grip. Use a knife or screwdriver to gently chip the edges and make sure the area is dry. Press the epoxy into the hole and give it enough time to cure before putting it back in service. Of course, if the toilet is less than a month old I suggest returning it and getting a new toilet.
Jan 13, 2009 | American Standard 2002.014 - Champion4...
269 people viewed this tip
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
