Tip & How-To about Microsoft Word 2003 for PC
Key Combinations Do Not Work as Advertised!
Key Combinations Do Not Work As advertised!
If you get a call from a User that she/he is trying to use certain key combinations, or shortcut keys, in Word, but they are not working as they are supposed to work, this may resolve the problem.
In this screen shot, a bit more than half way down, there are two Word Perfect-related options, Help for WordPerfect Users, and Navigation keys for WordPerfect users.
If there is a check in either or both of these options, then normal key combinations, like Ctrl+Home, Ctrl+End, etc., will not function as expected. Ctrl+Home will bring up a GoTo Page dialog box.
Uncheck both options and normal functionality returns.
Microsoft Word 2003 for PC Logo
How to make a template (not line) shortcuts on Casio Classpad fx-CP400?
I suggest you play with key combinations (Shift + some key) to discover if there is any beautiful template that gets generated by it.
Dec 04, 2017 | Casio Office Equipment & Supplies
windows keyboard shortcut commands
There are many. Do a Google search for "Windows Key Combinations" and you should find several links to a list of the available commands. The "Windows Key" is that key between the Ctrl and Alt key on your keyboard that looks like a window with 4 panes in it. You hold down the Windows Key while pressing any one of several others, depending on what you want to do. afor example Holding down the Windows key and pressing R will open a "run" box. The Windows Key plus E will take you to "My Computer". the Windows key plus D will immediately take you to the Desktop, etc., and so forth.
Jul 14, 2014 | Microsoft Windows XP Professional
how i can enble function key
HP laptops have the ability to lock the blue special function keys on, making numerical data entry easier on laptop models that do not have the room for dedicated numerical keypads. Because the key combination to lock the function keys is so simple, however, it is easy for those who wouldn't normally use this ability to do so accidentally. When the function keys are locked, pressing certain keys will result in numbers being typed rather than letters. Unlock the function keys to alleviate this issue.
Press the "Fn" and "Num Lk" keys on the keyboard simultaneously. The "Number Lock" indicator light should turn off, indicating that the letter keys will once again type letters when pressed. This combination should work on the majority of recent HP laptops. If it does not, try one of the alternate key combinations in this article's remaining steps. Press the "Fn" and "F11" keys simultaneously, then attempt to type a letter. If the combination does not work, continue to the next step. Press the "Fn" and "Scroll Lock" keys simultaneously, then attempt to type a letter. Continue to the next step if this does not work. Press the "Fn," "Scroll Lock" and "F11" keys simultaneously.
Jan 16, 2013 | HP 4440s Probook
shortcuts have locked up on my pc
Conflicting Extensions
Add-ons, also called plug-ins or extensions, are mini-applications that attach themselves to independent software and add extra capabilities to the program.
Extensions can change a browser's interface, alter the behavior of existing operations, add new functions or install in-browser support for programs like Shockwave Flash or Adobe Reader.
Because these extensions make changes to the overall operation of a browser, they can also affect the shortcut keys.
Most browsers offer an option to run the application with add-ons disabled; if the shortcut keys work when extensions are turned off, one of the add-ons is at fault.
Key Reassignments
Programs like MapKeyboard, SharpKeys and KeyTweak can reassign the functions of each key on the laptop keyboard.
If the computer is running a non standard keyboard layout, certain keys might not behave or respond normally.
For example, if the "Ctrl" key has been disabled or is set to work like "Shift," shortcut keys won't work as expected because the keyboard is no longer using its default mapping.
If the keyboard layout has been changed in the Dell laptop, the registry will contain a Scancode Map entry in
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout or the language bar will show a keyboard language different from the default ("English (United States)," or "EN," for Dell laptops purchased in the U.S.).
Virus Infection
Malicious software can affect the function of peripheral components like the keyboard and mouse.
If the keyboard is exhibiting strange behavior for example, if certain keys do not respond or if keys output unexpected letters a virus is most likely the cause.
Running an anti malware software from within Safe Mode accessed by pressing "F8" on the Dell logo screen should remove any viruses interfering with keyboard response.
Browser Software
Upgrading or downgrading a browser on the PC can affect the Internet shortcut keys associated with that program, especially if the version removes a function that was once associated with a particular keyboard combination.
Alternatively, if you've switched to another browser, you might find that certain shortcuts that worked in the previous browser don't work in the new one.
For example, while "Shift-F10" opens a context menu in Internet Explorer, the same keyboard combination does nothing in Mozilla Firefox.
Hope this helps.
Nov 20, 2012 | ASUS Computers & Internet
how to create hot key
Right click the browser icon on your desktop and select properties.One of the tabs should say "Shortcut."
Under the shortcut tab is a text field called "Shortcut key."(1) Click on the field and then (2) press the key on your keyboard you want to associate with the shortcut.
Your shortcut key will be Crtl + Alt + Key.
This solution works for Windows. Some key combinations can not be used. You can find those here.
Feb 11, 2012 | Microsoft Computers & Internet
853 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
