Tip & How-To about Computers & Internet
Resetting a PC on the Domain
Re-Setting a PC on the Domain
  1. Log in as Administrator
  2. Rename PC – either with new PC ID, or by adding “A” to end of PC name
  3. Demote PC to a Workgroup, from the domain. Use the proper UserID and Password, as given to you by the System Administrator
  4. Restart
  5. Log in as Administrator
  6. Move PC back up to domain: na.proskauermain-domain.com. Use the proper UserID and Password, as given to you by the System Administrator again.
  7. Restart
  8. Log back in as User
  9. Restart and log back in as User a second time
Computers & Internet Logo
How do I change the name of my computer?
  1. Open System by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_47.png, clicking Control Panel, clicking System and Maintenance, and then clicking System.
  2. Under Computer name, domain, and workgroup settings, click Change settings. 18abb370-ac1e-4b6b-b663-e028a75bf05b_41.png If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. On the Computer Name tab, click Change.
  4. Under Computer name, delete the old computer name, type a new computer name, and then click OK. If your computer is part of a domain, you will be prompted to provide the name and password of an account with permission to rename the computer in the domain.
You can visit the below link for any further need
http://support.microsoft.com/kb/295017
May 25, 2012 | Computers & Internet
there is no room to enter a domain.
I'm assuming that the operating system is XP.
Log in to your account as you usually would. Right click on My Computer and select Properties from the list. Click on the Computer Name tab. Where it says "To rename this computer or join a domain" click on change. A new window will pop up so click on Workgroup. In the typing plane if it say's MSHOME, delete that and type WORKGROUP make sure you type it in uppercase (capital letters).
When you've done that click OK.
The computer will tell you that you have to restart the computer for the changes to take effect so please restart the computer.
Once the computer has restarted you can check if the domain has changed to WORKGROUP.
Please post back if you need anymore help.
Regards.
Oct 02, 2009 | Dell Inspiron 1420 Laptop
how do i change the configuration from domain to work group
even if you mistakenly joined a domain you can still log in through your existing id and password.
Once your press CTRL+ALT+DEL, you will see a login window with three fields namely: user id, password and Domain.
In the log in screen use the drop-down menu in front of Domain (which shows your new domain- most likey MSHome) and choose 'this computer'. After this, enter your old/existing user id and password and hit enter.
Please proceed to your system settings and change your domain back to Workgroup. Restart PC.
Sep 30, 2009 | Dell Inspiron 1420 Notebook
windows cannot connect domain either domain controller is down or otherwise unavailable or because your computer was not found
The resolution and workaround to solve the error is as below.
  1. Login to the Windows 2003 domain controller, and delete the computer account object from the Active Directory by using Microsoft Management Console (MMC) which you can always access from “Manage Your Server”.
  2. Log-in to the PC workstation as local administrator. If you cannot logon as local administrator, try to unplug the network cable and logon to the computer by using a domain administrator user that used to logon on the PC before, by using cached logon credentials feature.
  3. Go to Control Panel, then click on System icon, then go to Computer Name tab.
  4. Unjoin the computer from the domain by clicking on “Change”. You should see that Domain button is now selected. Remember your domain name in the text box. Select (Click) on “Workgroup” to remove the computer from the domain, and put any workgroup name in the text box (e.g. workgroup).
  5. Click OK to exit.
  6. Restart the computer (optional)
  7. Go back to the Control Panel, launch System properties and then go to Computer Name tab, and click on “Change”.
  8. Rejoin the domain by uncheck the Workgroup button and select (check) Domain button, and put in the domain name noted above into the text box.
  9. Click OK to exit.
  10. Reboot the PC.
This should solve the unable to logon to domain error, without changing or losing the user profiles on AD.
Dec 18, 2008 | Microsoft Windows Server Standard 2003 for...
211 people viewed this tip
David Payne
David Payne
