Tip & How-To about Computers & Internet
Film scanner maintenance
Film scanner is one of the sensitive machine, all consumables parts need to change regularly (logs needed) defend of how heavy you work load, when not in used be sure that all bulb, glass and fan is free from dust. moving parts and gear must be lubricate regularly, for the area that ac voltage fluctuate you need to used AVR to regulate ac voltage supply for scanner.
Computers & Internet Logo
How do i adjust the sensitivity of my touch pad for my Toshiba laptop PSLB8U-05202F
1.Turn on the computer and log into Windows as normal. Open the "Start" menu and click on the option labeled "Control Panel."
2.Double-click on the icon labeled "Mouse.". The "Mouse Properties" window will open. Navigate to the tab labeled "Device Settings." Click on the button labeled "Settings." A window labeled "Properties" will appear.
3.Examine the left panel of the "Properties" window and expand the option labeled "Sensitivity." Click on the option labeled "Touch Sensitivity."
4.Reduce the touch sensitivity setting by moving the slider to the right, towards the "Heavy Touch" label. Experiment with different levels of sensitivity until you find one suited to your needs.
5.Click on the button labeled "OK" to close the "Properties" window; repeat with the "Mouse" control panel. Your new touchpad sensitivity settings are now saved.
Sep 14, 2011 | Toshiba Satellite L305-S5908 Notebook
I need to find the plastic adapter which you can attach to the feed reel which changes the film from reg 8 to super 8
Super 8 and Regular 8mm are the same film, the difference being the way they were supplied to the consumer - 8mm was supplied loose on a reel, Super 8 was supplied in a pre-loaded cassette. Both can still be purchased new from B&H Photo and other dealers.
Jul 07, 2011 | Photography
Loading negative film in holder.
The button under the top door is for ejecting the film strip. To load negatives you just insert them until the machine recognizes them and then it will automatically load them.
Apr 12, 2009 | Epson Perfection 3590 Photo Flatbed...
how do i scan film on my scanner
You should be able to download the manual.
http://consumer.usa.canon.com/ir/controller?act=DownloadDetailAct&fcategoryid=351&modelid=10242
To scan film, you'll need to first remove the white cover on the underside of the scanner lid. That is where the backlight is. Also, you must be using the ScanGear driver and NOT the WIA driver. The WIA driver does not support film scanning. Locate your film guides. These are the templates that will hold the film and are placed on the scanner glass to be scanned. Lastly, there should be a Select Source option in the scanner driver that allows you to select Film as the source.
Hope this helps.
Jul 07, 2008 | Canon CanoScan 8400F Flatbed Scanner
cannot scan film and slides
Check the cable that connects to the lid of the scanner. If it is disconnected, you won't get the Film options.
Jan 21, 2008 | Canon CanoScan 8600F Flatbed Scanner
151 people viewed this tip
David Payne
David Payne
