Tip & How-To about Plumbing
Empty Toilet a Bowl
Anytime you want to remove a toilet, you're usually facing the problem of how to get the water out of the bowl.
First, turn off the water
Flush, and hold the lever down until it has nothing more to drain out of the tank.
But then, you're still stuck with a full bowl of water.
Here's the trick
Fill a bucket with about 1 to 2 gallons of water.
Pour it fairly rapidly into the bowl all at once.
Because of siphon action, and nothing to refill, it will drain 90% of the water out of the bowl, leaving about a cup of water in the bowl.
If you have to have it completely empty, you can use a small hand pump, but in most cases, it's low enough for you to just carry out the way it is.
Plumbing Logo
kohler flush problems
If it has a power flush (i.e hole about 1" in size opposite side of flushing direction) that hole gets plugged by minerals from the hard water, when it does the flush will be much weaker. To clean it, use a bent coat hanger and ream out the deposits as far in as you can reach. Then turn off the water supply, flush the toilet, then quickly pour one pail full of water into the toilet to drop the water level to minimum. Get "Lime Away" at H/Depot, pour in 1 cup and let sit overnight to eat the remaining hard water deposits from the bowl and power flush. In morning turn on water flush a few times, should wok good as new. Repeat anytime hole starts to get plugged.
Aug 21, 2014 | Home
Toilet flushes but does not have the power to flush down waist
Aug 14, 2014 | Home
toilet wont flush
Jul 27, 2014 | Home
Aquia II Dual Flush Toilet: toilet after flush removes to much water from bowl...
Adjust the float on the Fluid-master a little higher if possible. This should allow more water to enter the bowl after the flush.
May 16, 2010 | Toto Aquia II Dual Flush Toilet
369 people viewed this tip
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
