Tip & How-To about Office Equipment & Supplies
How to solving an Epson Printer "problem"
I thought the other day that a lot of people may be interested in having access to the vast pool of knowledge that myself and my staff dispense on a daily basis to my customers. As a nationwide supplier of printing consumables we often get asked by customers about related problems they are having with there printers, and obviously we gladly help out anyone we can as opposed to customers having to call expensive manufacturers help lines at premium rate call tariffs.
A favourite question we get asked is "I have just gone to print something off on my Epson Inkjet printer and it will not print", I then ask the customer how they have done this and have they changed any printer settings or installed new software recently. The answer is usually no I have not changed any settings or installed any thing. Our next question is "What are the lights /buttons on the front of the printer doing?" The common answer is, "they are all flashing at once, even if I switch the printer off at the socket and switch it on again".
We now know what the problem is! There is I believe a method built into an Epson printer that counts the amount of printing you have done, a bit like a car speedo measures the mileage you have done, but unlike a car where when you hit a certain mileage a light or warning will come up at worst and tell you the car needs a service. The Epson printer just stops dead and all the lights flash, if you dig a little deeper into your instruction manual/disc it tells you to call the Epson help line, who then tell you the printer needs a service at your local Epson dealers. I duly took my faithful C82 epson printer to my local Epson service centre; very help full and who charged me and gave me back a printer that worked.
This intrigued me so I asked a couple of my computer tech customers if they could shed any light on the matter, and they both confirmed my suspicions. You plug in the correct software and reset the counter. It is nothing to do with your computer, your printer, your brand of inkjet cartridges or your computer. It is simply Epson's way of getting you to their service centre.
So if you come to print with your Epson inkjet printer and it will not, and then proceeds to flash all of its lights at you. You now know what to do, unlike quite a few of my customers including my self, who spent hours reinstalling software, trying new sets of cartridges, both genuine Epson cartridge and the more popular compatible ones. I hope this saves some one some grief and frustration.
i need to unsubscribe urgently from are you interested i have no idea how did i even appear on that site it just appears recently in my facebook please help
Go to the account menu at the top right hand side of your profile screen. Select the privacy setting options. At the bottom left you will see Apps and websites. Click on edit your settings. A list of applications will then appear, On the right you will see edit your settings. click on this and you will see a list of the apps that have been granted access to your account. click on the offending app and you will see options to cancel access to your profile and the various permission it has been granted. Be careful on Facebook because there are lots of tricky ways for app developers to get you to give access to your profile without your knowledge. Hope this helps. Be Blessed Kidromulous
Mar 07, 2011 | Facebook Apps
the filter wasn't changed for a couple of weeks and lots of leaves fell in our pool, I changed the filter put more salt but the pool water is getting greener and greener every day, what can I do? Intex Krystal clear, salt water CG-56601. I thought of shocking it but don't want to put chlorine in as daughter is allergic to it.
Shock your pool ... take it to about 20 ppm and run the filter 24 hours a day. Brush the sides. When the pressure goes up 10 lbs over fresh start pressure, backwash or clean your cart as appropriate. Is your salt cell calling for more salt? Salt is persistent in the water (like CAL, salt doesn't just go away. The only way you loose either is by splash out and/or backwash.) If you dont know the level and your cell will not tell you, get tghe level checked at your pool place. You should have around 3200 ppm salt. Dont expect your salt system to keep up with the green stuff when the green stuff is established. You MUST use dry or liquid CL to overcome. You MUST brush the pool sides and bottom. You must run the filter 24 hours.
Between the green stuff and the sun, the CL your cell is making is consumed almost as fast as you make it.
Get your Cyanuric acid level to 80 ppm.
I hope this helps you ... Thanks for your interest in FixYa.com
Jul 31, 2010 | Intex Krystal Clear Model 635 Pool Filter...
pool heater trouble
LO would be low water pressure. You may want to have a pro look at the heater only because it can be dangerous to work on it with out the proper knowledge.
Jul 03, 2017 | Hayward 250kbtu Ng Pool Heater - Inground
How much is a used Sharp AR-157E copier worth (in good working condition and about 5 years old)?
If him to do get prettier preventive maintenance and put(deliver) the new grosses a photo and teflon, new starter, rollers of the seizure of the paper, $500 possible offer, able gross without change not more 100. My opinion such, do not interest the devices old, only if cheaply. The Expenseses on their reconstruction dispense vastly and preferred to take new, either as car. Solve
Sep 23, 2009 | Sharp AR-157E Copier
183 people viewed this tip
k24674
jasbo
jasbo
