Tip & How-To about Heating & Cooling
Thermostat installation
1. Make sure you buy the correct thermostat for your application. 2. Always turn off power to unit before installation. You will blow fuse or a transformer.3. Mark all wires when you take them loose from old thermostat.4. On some thermostats you will have RH and RC you must place jumper between them to get heat and cool to work.....
Heating & Cooling Logo
dryer had built up lint,blew fuse,now will blow fuse after cleaning and replacing vent hose
if its heated electrically, not by gas,then it sounds like the heating element has shorted to the case and this would blow the breaker
Jul 28, 2010 | Amana NDE2335AY Electric Dryer
the fuse on the control board keeps blowing and cannot find the problem
CHECK FOR A SHORT SUCH AS A WIRE TOUCHING ANOTHER WIRE OR THE BOARD TOUCHING METAL. MAKE SURE FUSE IS CORRECT AMP. ALSO TURN POWER OFF AT THE OUTDOOR UNIT AND CHECK TO MAKE SURE THERMOSTAT WIRES ARE NOT TOUCHING. IF NONE OF THESE SUGGESTIONS WORK THEN CHANGE YOUR THERMOSTAT. THIS SHOULD SOLVE YOUR PROBLEM.
Apr 13, 2010 | Heating & Cooling
air conditioner not blowing cold air & dispenser for water not recieving
UNIT NEEDS CHARGING WITH FREON AND CHECK TO MAKE
SURE THERMOSTAT IS ON AUTO AND COOL...CHECK OUTDOOR UNIT WITH POWER OFF FOR BAD CAPACITOR, LOOSE THERMOSTAT WIRES, BURNT WIRES AT CONTACTS AND COMPRESSOR, MAKE SURE OUTDOOR FAN MOTOR IS RUNNING
MAKE SURE ALL INDOOR BREAKERS ARE ON...MAKE SURE OUTDOOR UNIT IS GETTING CORRECT VOLTAGE...CHECK INDOOR FUSES AND WIRES FOR PROPER TERMINAL PLACEMENT ON THERMOSTAT AND AT BOARD...CHECK FILTER , PLENUM FOR BLOCKAGE...DO SIMPLEST THINGS 1ST..
Apr 05, 2010 | Heating & Cooling
Error Message C3451
It is a fuser error.
Try resetting. To reset a Rank A error follow these steps:
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
If the error recurrs then do the following:
1 Check the Fusing Unit for correct installation (whether it is secured in position).
2 Check the Fusing Unit, PWB-M and PU1 for proper connection and correct or change as necessary.
3 Change Fusing Unit
4 Change PWB-M
5 Change PU1
Oct 02, 2007 | Konica Minolta bizhub C250 All-In-One...
125 people viewed this tip
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
