Tip & How-To about Microsoft Windows Vista Ultimate Edition
The DVD disc drive icon has dissapeared from my computer.
Try first disconnecting power cable for ten minutes, if computer is a laptop also remove the battery at the same time. This will
If there is a disk inside the DVD drive, remove the disk.
Try doing a system restore, here you get instructions for XP, Vista is similar: How to perform System Restore on Windows...
If all this does not work open the BIOS setting menu at startup and check if the DVD is detected.
In BIOS also ensure that the optical driver is not manually disabled, and that SATA port (if using serial ATA DVD) or PATA channel (if using IDE) is not disabled.
If DVD is not detected in Bios, and the DVD and/or PATA/SATA channel/port are not disabled, then you need to replace the DVD drive unit.
In that case check the DVD drive data and power connection. Eventually try extracting the DVD drive and putting it back in place.
IF DVD is detected in bios, then the problem is a corrupted Windows registry.
In that case go to Start menu, open the Run dialog box, and type Regedit in the Run box.
The registry editor will open.
lick the Start button, press run and type regedit.
Before doing the procedure, save a copy of the registry. Click File, then Export using the menu at the top of the Registry Editor Window:
  1. In the Registry Editor window open the HKEY_LOCAL_MACHINE folder.
  2. In the HKEY_LOCAL_MACHINE folder, open System.
  3. In System open CurrentControlSet folder
  4. Open Control folder.
  5. Open Class folder.
  6. In the Class folder open the folder {4D36E965-E325-11CE-BFC1-08002BE10318} .
  7. In the right panel click to select UpperFilters registry entry.
  8. Delete the UpperFilters registry entry from folder .
  9. Click Yes when asked to confirm delete.
  10. In the right panel select LowerFilters.
  11. Delete LowerFilters registry entry.
  12. Click Yes when asked to confirm delete.
  13. Close Regedit.
  14. Restart the computer.
Microsoft Windows Vista Ultimate Edition Logo
BIOS PASSWORD??? HELP!!!
Try typing "Biostar" in as the password. If that doesn't work, we have another option.
The first step would be to try removing the CMOS battery (the coin shaped battery inside the computer that keeps the clock working). Disconnect the laptop from any power source (AC adapter), and remove the main laptop battery. Third, you will have to remove the bottom plate of the Toughbook. Search YouTube for a disassembly video for your model of tough book. Once you've removed the bottom plate, you should be able to see the internal components. Connected to the system board by two wires will be the CMOS battery. After disconnecting the CMOS battery (carefully!), hold down the power button on the laptop for about ten seconds, then let the computer sit for a few minutes to ensure that it is completely devoid of power. You will then need to reinstall the laptop battery (the main, brick-shaped one — not the CMOS) and boot up the laptop. If all goes according to plan, you should be able to access the BIOS and turn off or remove the bios password. Now you can reassemble your Toughbook. Power off, remove the battery, reconnect the CMOS battery, and reattach the rear plate, and you're good to go!
Nov 22, 2017 | Panasonic Computers & Internet
We changed the battery in the 97 lumina and now the MFG alarm system is in a mode where we cannot get the car to start
Disconnect negative battery cable. With key still turned on hook the cable back up. Try starting car. If that doesn't work turn key on for ten minutes. Than try cranking it. Turn it on and off three different times with the ten minute intervals. After that if car doesn't start than leave the key on for thirty minutes than try cranking it. This should work.
Jan 06, 2011 | 1997 Chevrolet Lumina
My Gateway 7510GX shuts down after ten minutes. I
i think there are two causes for this reason.1/ ur processer fan is not working properly. at that time u should get this message as thearmal heat. then ur computer shutdown. 2/ setting of power option my be fixed 10 minnutes. we should kee poweroption always never shutdown.
Jun 11, 2009 | Gateway 7510GX Notebook
I can't get my songs onto my iPod Nano
The Ipod or the USB cable may be defective.
Try first connecting the Ipod to a different computer to test it, or using a different data cable.
If Ipod works, then do the following.
Unplug computer power cable, and if it is a laptop or a macbook also remove battery for ten minutes. This will get rid of elecrostatic charges on USB connectors.
If that does not work try reinstalling Itunes, this will synch the Ipod again with the computer.
May 01, 2009 | Apple iPod nano
Hi! I'm getting the following message on my computer screen: Error Number : 306 A communication error has occurred. Make sure that the printer is plugged in, powered-on, and properly connected to your computer. Then try printing again. But everything is plugged in properly. I just printed something, then one minute later when I went to print something else, it wouldn't let me! Please help!!
Do the following:
Try a different usb cable.
Plug the cable into a different USB port.
Try disconnecting printer power cable for ten minutes.
Unplug computer power cord for ten minutes and restart.
Reinstall printer drivers.
If that all did not work, test the printer on a different computer, to find out if it is faulty or not.
Sep 19, 2008 | Canon Office Equipment & Supplies
767 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
