Tip & How-To about Microsoft Xbox 360 Console
Xbox 360 RROD E08 / error code 0020
X 360 RROD E08 / error code 0020x 360 RROD E08 / error code 0020x 360 RROD E08 / error code 0020
Microsoft Xbox 360 Console Logo
how to fix a xbox 360
RRoD is like a BSoD on Windows. It's a fatal error and a primary code. It doesn't tell you anything at this stage and the code is so generic, if can be anything from the PSU being faulty/not being connected to a specific component fault. You therefore need the Secondary Error Code (google it). If you get anything like 0102, 0020, 0110 then it's extremely possible the problem is with the GPU. Ignore any videos regarding heatguns, towel tricks or clamping / bolting. you'll just make it worse. The solder balls which attach the GPU to the main board need replacing. This is done by special equipment and is a proper fix, unlike the methods mentioned above. In extreme cases, the actual GPU needs to be replaced.
Aug 21, 2012 | Microsoft Xbox 360 Console
i have an issue with my 360 the power light on the power bar is red?i use my other 360 onit it works fine and turns on,but when i hook up the one 360 the light turns red and the xbox wont turn on at all?
problem with power port it should give 3 red lights and error code 0020 which is hardware fail of board ports and death of the xbox the port on the motherboard came loose never had that problem but no rrod thats new to me and i have had lots of problems with the **** boxs since they came out try adding pressur to the board above the port or call customer support 1-800-4my-xbox honestly sorry i could not help to much
Dec 14, 2010 | Microsoft Xbox 360 Console
My xbox has 3 flashing red lights on front. What does this mean
It means your system has the dreaded RROD Or Red Ring Of Death,
If you turn the system on and hold the sync button and then hit the eject button, You can find its code you will have to do it 4 times, 1 light means 1 2 lights means 2 3 Means 3 and 4 lights means 0.
You can usually get a code like 0020 0102 and so on, below is a link that will tell you what each error code means,
also look at the back of your system locate the manufacture date, If it's within 3 years of that date don't open the system call microsoft and have them fix it for free.
http://llamma.com/xbox360/repair/Xbox-360-error-codes.htm
Sep 10, 2010 | Microsoft Xbox 360 Console
Xbox 360 had 3ROD W/error code 0102 now its 0020
error code 0020 is a overheating error.You need to do the X-clamp fix.That should solve your problem.Did you use the Acrylic silver thermal paste?
Aug 31, 2009 | Microsoft Xbox 360 Console
i did the x clamp fix on my 360 now i have error code 0020
error code 0020 is currently unkown, however it is possibly overheating. and 0021 is caused by a timeout on the dvd drive or a GPU error, try re-heating the chips using a blow dryer on low heat for 10-15mins.
Dec 28, 2008 | Microsoft Xbox 360 Console
1,236 people viewed this tip
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
