Tip & How-To about Computers & Internet
How to Add a Computer Domain
A computer's domain is the specific network group to which it is assigned. The domain name determines which computers on the network can readily access the PC, as only computers assigned to the same domain will be able to interface with the computer without hassle. Adding the computer to a domain is done by changing the Workgroup setting within the operating system.
  1. Step 1 Right-click "My Computer" and select "Properties."
  2. Step 2 Click on "Advanced Settings" if you are using Vista or 7. Skip this step if you are using XP.
  3. Step 3 Click on the "Computer Name" tab.
  4. Step 4 Click the "Change" button.
  5. Step 5 Enter in the name of the domain to which the computer should be added into the "Workgroup" field. Press "OK."
Computers & Internet Logo
what is dns
DNS stands for Domain Name System. The Domain Name System (DNS) is a hierarchical distributed naming system for computers, services, or any resource connected to the Internet or a private network. It associates various information with domain names assigned to each of the participating entities. Most importantly, it translates domain names meaningful to humans into the numerical identifiers associated with networking equipment for the purpose of locating and addressing these devices worldwide.
Dec 13, 2011 | Sylvania G-Netbook
i have problem of local printer is connected to domain i cant shared this usb printer on other connceted same domain pcs Basically i have one usb printer and have 20 pcs all are in domain so i want to share that printe which is installed on one pcs.ok sir,
Well you install the printer on the PC required, then in the setup SHARE the printer. You must then install a printer in each one of the "Clients" when asked what sort, use NETWORKED printer and navigate to where ya Printer is on the network using the "Browse" and choose it, then ya good to go.
I have found a more detailed link for your Convience http://uis.georgetown.edu/software/documentation/winxp/winxp.network.printer.html
Jan 21, 2010 | Office Equipment & Supplies
may 2008 domain controller is up and running but i cannot join it with my windows 7 laptop, "domain path not found"
Ah this is an easy one, make sure the laptops MAC address (this can be found by going into the laptops command line and typing 'ipconfig /all') Then you need to go into Doman users and computers (active directory) and add that MAC address to the computers group.
If this doesn't work...make sure your laptop is connecting through the same network. use the cmd line tool Ipconfig /all to find out the ip address of your server and your laptop. If your laptop's default gateway doesn't match that of your server's...you could be cross networking. Try the "ping" command like this go to the command line on your laptop and type Ping <ip address for server> if you can ping it, you can connect with it....also check your group policy that enables wireless connections.
Dec 15, 2009 | Dell Dimension 3000 PC Desktop
Can't configure router for Domain name and DNS
dns= domain naming service or something alike...
you don't have normally to anything to your router other than allowing incoming traffic to port 80...once you do that, you should be all set..frrom your computer at home if you type your domain name, your pc actually goes to the internet clowd and accesses you new domain name based on the info gathered by dyndns...then comes back to the ip that your ISP assigned you and hits your webserver...
A couple things to consider;
keep an eye on the ip assigned to you by the ISP..if it changes by DHCP your webserver won't be seen by the outside..
on your side of the home network, assign a static ip address, don't use dhcp as well to avoid the same problem on the pc that you have the webserver. your router should allow you to allow traffic on port 80 to your webserver computer, which has the static IP...
if it does not, buy another one
Feb 07, 2009 | Buffalo Technology AirStation WBR2-G54S...
Difference between DNS and WINS
WINS is Windows Internet Naming Service, a system that determines the IP address associated with a particular network computer. This is called name resolution. WINS supports network client and server computers running Windowsand can provide name resolution for other computers with specialarrangements. Determining the IP address for a computer is a complexprocess when DHCPservers assign IP addresses dynamically. For example, it is possiblefor DHCP to assign a different IP address to a client each time themachine logs on to the network.
__________________________________________________
DNS, a.k.a Domain Name System is a database system thattranslates a computer's fully qualified domain name into anIP address.Networked computers use IP addresses to locate and connect to eachother, but IP addresses can be difficult for people to remember. Forexample, on the web, it's much easier to remember the domain namewww.amazon.com than it is to remember its correspondingIP address (207.171.166.48). DNS allows you to connect to anothernetworked computer or remote service by using its user-friendly domainname rather than its numerical IP address. Conversely, Reverse DNS(rDNS) translates an IP address into a domain name.
Jul 20, 2008 | Microsoft Windows Server Standard 2003 for...
185 people viewed this tip
David Payne
David Payne
