Tip & How-To about Cameras
How to convert MVI to AVI file for edit in Pinnacle Studio?
Some Canon digital still cameras (Powershot A75, A63, S410 etc), are capable of shooting a limited amount of video, since there is no tape, it is saved as an MVI file format. However, the MVI file format is not compatible with other programs. Even windows media player refuse to play MVI file. Besides, editing software like Pinnacle Studio and Windows movie maker do not work with the format. Because of this, the files need to be converted to a format that is more widely used, such as AVI so that these videos shot with still camera can be played and edited as easily as other common videos. This guide is to tell how to do that.
Software you'll Need: Pavtube Video Converter
Step 1. Download Pavtube Video Converter, and follow the prompts to install the program. Click "Finish" when the installation is complete, and Pavtube Video Converter will launch automatically.
Step 2. Click “Add” to load MVI files or directly drag the files into file list. By default, the files are selected. If you would like to join all the selected files together, check the box of Merge into one. You could view the files in preview window, simply highlight the file and click play button.
Step 3. Click “Format” bar to determine output format. Follow Common Video-> AVI Video (*.avi)/ DivX AVI(*.avi). Click “Settings” if you’d like to customize advanced audio and video parameters like Video Codec, aspect ratio, bit rate, frame rate, Audio codec, sampling rate, bit rate, channels. Do not forget to click “OK” to confirm your settings. Then type in a desired output location in the "Output" box.
Step 4. Click "Convert” to start converting MVI files to AVI. You could set auto shutdown in progress window or leave it there and come back later. After conversion you could edit the converted video in Pinnacle Studio, and make a film out of it or burn it onto DVD.
Learn more: http://www.pavtube.com/guide/convert-mvi-to-avi-for-edit-in-pinnacle-studio.html
Cameras Logo
canon has a blank screen won't shoot a picture or video
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Dec 07, 2009 | Canon PowerShot A75 Digital Camera
in shooting mode lcd displays no image. Happened
Applicable cameras include: A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Nov 29, 2009 | Canon PowerShot A75 Digital Camera
have canon Powershot A75 3.2 Mega pixel camera .. Now it is having display issue. Once i open my camera lens come out power come but unable to see the image in lcd to shoot.. Can you assist
First try pressing the DISPLAY button. If that doesn't fix it then this sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Apr 16, 2009 | Canon PowerShot A75 Digital Camera
Canon PowerShot A75 is shooting "blanks"
Its matter of bad CCD Imager in camera so you don't see any live image on lcd to take snap.
CCD Imager needs to be replaced in Canon A75 camera.
Canon will repair A75 for CCD Imager problem free of cost as per announced scheme.
Click Canon CCD Imager Advisory for details, how to get free repair facility.
Good luck.
Dec 26, 2008 | Canon PowerShot A75 Digital Camera
canon powershot S400 LCD screen image jumbled
This sounds like it might be a defective CCD imager. This will get worse with time, and the pictures may be jumbled next. Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
Jan 21, 2008 | Canon PowerShot A75 Digital Camera
187 people viewed this tip
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
