Tip & How-To about Computers & Internet
Alternate way of networking a Windows7/Vista system to a Windows XP systems's shared printer.
If you have tried the normal printer wizard process and were unable to get a printer to function, then verify the network name of the computer that has the shared printer and the share name of the printer, then follow these steps. Worked for Me.
Windows 7
Go to CONTROL PANEL. Choose DEVICES and PRINTERS. The choose ADD PRINTER.
Choose ADD A LOCAL PRINTER. Click on CREATE A NEW PORT. Select in the drop down box, LOCAL PORT. Click NEXT.
A dialogue box will appear asking you to enter a port name. Type in: \\computername\printername
In Vista
Go to CONTROL PANEL. Choose PRINTER. The choose ADD PRINTER.
Computers & Internet Logo
I've reinstalled my kodak all in one printer and it wont connect to the wireless network and says it cant find it. I've done everything
If the "Access is denied" error is showing up on the computer, just go through the steps to fix the error. First, open the Printer Wizard through the Control Panel. Select the 'Add printer Wizard', then click 'Add a local printer' and then click 'Create a new port'. Make sure that local port is there in the list and then click 'Next'. In the Port name dialog box, type computer name and printer name and then click 'Ok'. Complete the wizard steps to finish the process.
Jan 24, 2011 | Kodak Office Equipment & Supplies
I set it up for wireless printing and can find it on the network
If the "Access is denied" error is showing up on the computer, just go through the steps to fix the error. First, open the Printer Wizard through the Control Panel. Select the 'Add printer Wizard', then click 'Add a local printer' and then click 'Create a new port'. Make sure that local port is there in the list and then click 'Next'. In the Port name dialog box, type computer name and printer name and then click 'Ok'. Complete the wizard steps to finish the process.get more information and help from wireless printer problems .
Dec 26, 2010 | Lexmark X4650 InkJet Printer
Brand new Brother MFC-685CW won't print via wireless
First, I would recommend NOT trying to manually install this printer by using the add printer wizard in windows and selecting the the port and drivers to use. I would use the install cd to set this all up, it makes setting up this printer MUCH easier. If you are unable to use the install cd then get the IP address for the printer from your router admin page then with the printer "installed" go into the printer properties, go into the port, add a port, and instead of using a printer name just type the IP address for the printer in. Also for any networked printer make sure you don't have a firewall blocking it (this would include making sure that if the printer requires a port opened in the router that all requests for that port are routed to the IP address of the printer).
May 09, 2008 | Office Equipment & Supplies
I am trying to share a printer.
Are they both under the same network? Can the pc find the laptop under network connections and vice versa? If not, then right-click my computer, go to properties, go to the tab 'Computer Name' click on the button change, and make it part of a workgroup of your choice of name. Do this for both making them part of the SAME workgroup.
Then, make your printer shared under that workgroup.
Mar 30, 2008 | Linksys Wireless-G Broadband Router
132 people viewed this tip
David Payne
David Payne
