Tip & How-To about Televison & Video
Lamp Time Reset for Samsung TVs
This is a quick reference guide to show you how to reset your
Samsung DLP TV’s lamp hour meter or hour counter.
Resetting the counter is a very simple procedure.
Begin with the TV powered off
Point your remote towards your TV
Press:
Mute + 1 + 8 + 2 + Power
Your TV set should now say “Loading Factory”
Browse down to “Option” then press Enter
(or the right cursor button)
NOTE:
The Mute+1+8+2 buttons needs to be pressed down consecutively and fairly quickly. If your TV does not enter the service menu after using this combination, you can substitute MENU instead of MUTE. I think that’s a better way to do it.. Also, the right cursor arrow also acts as the ENTER button, so try it if you’re having difficulty with the ENTER button
To exit the service menu, hit press the EXIT button or just turn off your
TV (remember not to turn on your TV immediately afterward!)
Televison & Video Logo
I have a Samsung DLP HLS 5086 W that is shutting down after a couple of minutes. The color wheel and lamp were both replaced a little over a year ago. The lamp is a Phillips, and the color wheel is OEM. I am getting all 3 lights on the front panel, and when they disappear I hear a high pitched "buzz" or "whine" intermittently for lack of a better description of the sound. Any thoughts?
Hope this helps:
Resetting the counter Once you have installed your OEM replacement lamp, resetting the counter is a very simple procedure:
• Begin with the TV powered off.
• Point your remote towards your TV.
• Press:
• Menu + 1 + 8 + 2 + Power.
• Your TV set should now say "Loading Factory".
• Browse down to "Option" then press Enter (or the right cursor button).
To exit the service menu, hit press the EXIT button or just turn off your TV (remember not to turn on your TV immediately afterward!).
NOTE: The Mute+1+8+2 buttons needs to be pressed down consecutively and fairly quickly. If your TV does not enter the service menu after using this combination, you can substitute MENU instead of MUTE. This seems to work for some sets. Also, the right cursor arrow also acts as the ENTER button, so try it if you're having difficulty with the ENTER button.
Resetting Your Samsung DLP Lamp Hour Meter Counter or Lamp Timer DLP Lamp...
Jan 14, 2015 | Samsung Televison & Video
where is the lamp reset switch
lamp reset is in the service menu of the tv.
If you do this follow the instructions & DO NOT MAKE ANY OTHER ADJUSTS AS YOU CAN GET THE TV WHERE IT WILL NOT OPERATE
website: http://www.fixyourdlp.com/2007/02/15/resetting-your-samsung-dlp-lamp-hour-meter-counter-or-lamp-timer/
Jun 01, 2014 | Samsung Televison & Video
how do I reset lamp time in Samsung DLP TV- Model HL-R6768W?
Try this link for details.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Apr 23, 2014 | Televison & Video
installed new lamp/how to reset the lamp hour meter on samsung (HL-S4666W)
Here is the procedure for resetting the lamp timer.
This is a quick reference guide to show you how to reset your Samsung DLP TV’s lamp hour meter or hour counter. Resetting the counter is a very simple procedure.
Press:
Mute + 1 + 8 + 2 + Power.
Your TV set should now say “Loading Factory”.
Browse down to “Option” then press Enter (or the right cursor button).
NOTE: The Mute+1+8+2 buttons needs to be pressed down consecutively and fairly quickly. If your TV does not enter the service menu after using this combination, you can substitute MENU instead of MUTE. This seems to work for some sets. Also, the right cursor arrow also acts as the ENTER button, so try it if you’re having difficulty with the ENTER button.
To exit the service menu, hit press the EXIT button or just turn off your TV (remember not to turn on your TV immediately afterwards!).
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
Jun 01, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
275 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
