Tip & How-To about Computers & Internet
How to make ur pen drive long lasting
1. try to always keep ur pen drive mouth cover with the cab when nt in use, in order to prevent the steel surface to get rust.
2. always try to delete the files inside the pen drive than formatting, in order to nt decrease the volume the size of the pen drive.
3. dnt use pen drive when it is vry hot, in order to prevent it frm getting damaged.
For more tips, vote me
Computers & Internet Logo
my 30400040 is rusting to pieces and is only 3
the casing sould have a long warranty but the burners and the cook surfaces do not
you must keep them oiled with veggie oil after cleaning to prevent corrosion
i keep a pump bottle with oil for this reason
Jun 25, 2009 | Ducane 30400040 Stainless Steel Grill
Unable to open Pendrive
Your pen drive is infected by a virus/worm. I have two solutions for this -   > If you have WinRAR software, just open up the pen drive using this and delete "autorun.inf" from it.  OR  > Use any good antivirus software and scan your pen drive, and disinfect the pen drive from any virus/worms. Remove your pen drive, and insert it again. It'll work fine.
Dec 25, 2008 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
How can I delete write-protected files in pen drive
my multi-card (SD) kingston 2 GB is unable to copy , delete and format. It is always say that your multi-card is write-protect. I try to delete some file on it. It is able to delete but i reconnect to my PC,it shows my previous deleting files. why? If you have time , help me please.
Aug 07, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
rust stains appeared all over the outside of the stainless steel front of over, air outlet and splash back. What would have caused this and how can we fix this problem?
If I understand your question, your stainless steel surfaces have rusted. Correct?
Contrary to popular belief, stainless steel CAN rust under the right circumstances.
I won't go into what may have caused this problem, but I will hopefully help you solve it and prevent future rusting.
Usually it is only surface rust and not deep pitting of the steel.
Surface rust can usually be removed with a product like Soft Scrub cleanser or liquid Meguiar's Car Cleaner Wax.
Apply a small amount of either product to a clean cloth and rub over the rust until it is removed.
Wait until the product dries and buff with a clean cloth.
If you have a brushed stainless steel surface, you will want to rub in the same direction of the "grain".
One benefit of the wax is that it will protect the surface from future rusting.
If the rust cannot be removed in this manner, a more aggressive approach is required. Do NOT use the following procedure if you have a smooth stainless steel surface, only if you have the brushed surface..
Use a non-metallic scuff pad, such as a 3M Green Scouring Pad and rub in the direction of the brushed stainless steel grain.
This process should remove all surface rust and even some minor scratches. You can use the pad dry or better yet, with a liquid wax as a lubricant.
Never use steel wool!
It will only leave small particles of steel imbedded in the surface. The condition will look worse when the particles themselves rust!
I cannot be held responsible for any damages that may occur from the above procedure. But, it has worked fine for me whenever I have implimented it on dozens of similar surfaces.
Good Luck!
Mar 05, 2008 | Kitchen Ranges
stainless steel is rusty/blotchy
Jenn Air makes great products, don't blame them. Your type of stainless steel is a consumer grade that has less nickel-chromium in the mix making it affordable to the consumer. The surface needs to be "pacified", DeBruce Polish will REMOVE THE RUST and PACIFY the surface. We get Debruce Polish at debrucepolish.com.
Jan 02, 2008 | Jenn-Air 24 in. JDB1100AWS Built-in...
157 people viewed this tip
David Payne
David Payne
