Tip & How-To about Lexmark T630 Laser Printer
I need Postscript drivers for Lexmark printer T630.
Hi.
This printer supports Postscript, PPDS, and PDF emulation only on systems up to Windows 2000, on Mac OS X up to 10.6, and on Solaris.
Windows 7and Vista are not fully compatible with this printer, and the printer will not have full functionalities on this systems.
If you have Win XP, Win dows Server 2003, Win 98, Win 2000 or Mac OS, then all you have got to do is installing full factory driver software.
If you have Windows 7 or Vista, then you should upgrade the printer to get full features. Lexmark has opted for not updating this printer software. Full software release for Windows Vista and Windows 7 does not exist.
The drivers and software for this printer can be downloaded from Lexmark website, using the links below:
Lexmark_AAG_WinXP_PS_Driver- Post script driver.
System PCL Driver for Microsoft Windows XP and Server 2003
System PCL Driver for Microsoft Windows 2000.
PCL6 driver for Microsoft Windows 95, 98 and Me.
Printing solution for Mac OS X v.10.6.
Print driver for Sun Solaris 10 x86 systems.
Network print support for Linux.
Here the full driver installation procedure : How to install a Lexmark printer without the driver and software disk.
The printer may still work on Vista and Windows 7 using the built in drivers, but it will have limited functionality. See: Windows 7 Information.
Regards.
Lexmark T630 Laser Printer Logo
I cannot install adobe pagemaker 7.0
Did you see the system requirements? Here's it - try to see if its fit to your system For
Windows
  • Intel® Pentium® processor
  • Microsoft® Windows NT® 4.0 with Service Pack 6, Windows® 2000 Professional with Service Pack 2, Windows XP Professional or Home Edition
  • 32MB of available RAM (48MB or more recommended)
  • 175MB of available hard-disk space for installation (200MB or more recommended)
  • Video card with 800x600 resolution and 8-bit/256 colors (24-bit, high-resolution display recommended)
  • CD-ROM drive
  • For Adobe® PostScript® printers: Adobe PostScript Level 2 or later
for Macintosh
  • PowerPC® processor
  • Mac OS 9.1 or Mac OS X (Classic mode only)
  • 30MB of available RAM (45MB recommended)
  • 150MB of available hard-disk space for installation (200MB recommended)
  • 800x600 monitor resolution with 8-bit/256 colors (24-bit, high-resolution screen display recommended)
  • CD-ROM drive
  • For Adobe PostScript printers: Adobe PostScript Level 2 or later
If you think your computer system got all of the above requirements, Perhaps there's a problem of your computer Operating System. Try reformatting it.
May 18, 2011 | Adobe PageMaker 7.0 for PC
is the Dell A940 compatible with imac computers?
Hello there!
As i know dell printers dont offer you ability to use them with mac computers, but i know that you could use your printer as a server from some windows os pc, and connect it with your imac computer, if you are able to do that here you go, detail instruction will be provided for you in next text lines.
This document gives a detailed explanation of how to set up an HP DeskJet 722C printer that is attached to a Windows XP computer so that the printer can be used by a Mac OS X computer on a local area network (LAN). If your printer is slightly different, or you have a different version of Windows, or you're using a different Unix than Mac OS X, you'll have to adapt these instructions with your own creativity.
Be aware that these procedures may not be necessary at all if the printer you have has Mac drivers, and other Microsoft incantations are working properly. You may be able to get off easy, but then, you probably wouldn't be searching the Internet looking for these instructions. Your mileage may vary.
Thanks to the detailed directions at http://pnm2ppa.sourceforge.net/PPA_networking/PPA_networking-4.html which gave me most of the information I needed to make these detailed instructions.
The process falls into these five general steps:
  1. On Windows: Make sure you have a working printer set up on your Windows XP computer (this is not covered here).
  2. On Windows: Install the software needed to emulate a Postscript printer and redirect printing ports
  3. On Windows: Set up an emulated Postscript printer on Windows XP that will actually print to the (probably non-Postscript) printer set up in step one.
  4. On Windows: Set up Unix LPR Printer Services on Windows XP that will point to the emulated Postscript printer in step three that in turn points to the real printer in step one.
  5. On Mac OS X: Set up an LPR over IP printer in Mac OS X pointing to your Windows XP computer.
What follows are some email messages that people have sent me about some problem they overcame that I did not encounter. I'm sorry I cannot "boil down" their advice, because I no longer have a PC, but here is what they have to say.
Apr 17, 2010 | Dell 942 All-In-One InkJet Printer
problem is when i am installing the hp lj 3055 at step 4 it stop the installation and shows the error " Either you are in safe mode or microsoft installer is not installed properly." then it generate error log and stop the installation. Devendra
Hi kakurawat: Do you meet these minimum system requirements? Minimum system requirements ● Windows® 2000 ● Windows XP ● Windows Millennium Edition (Me) ● Windows Server 2000 ● Windows 98 ● Mac OS X V10.3 and later ● 128 MB RAM for Windows operating systems ● 32 MB RAM for Macintosh operating systems ● 250 MB hard-disk space (full installation) ● CD-ROM drive ● USB port Printer drivers The all-in-one comes with software that allows the computer to communicate with the all-in-one (by using a printer language). This software is called a printer driver. Printer drivers provide access to allin- one features, such as printing on custom-sized paper, resizing documents, and inserting watermarks. Supported printer drivers The following printer drivers are provided for the all-in-one. If the printer driver that you want is not on the all-in-one CD or is not available on www.hp.com, contact the manufacturer or distributor of the program that you are using, and request a driver for the all-in-one. NOTE The most recent drivers are available at www.hp.com. Depending on the configuration of Windows-based computers, the installation program for the all-in-one software automatically checks the computer for Internet access in order to obtain the latest drivers. Operating system1 Fax driver PCL 6 printer driver PCL 5 printer driver PS printer driver PPD2 printer driver Microsoft® Windows® 98 Windows Millennium Edition (Me) Windows 2000 Windows XP Windows Server 2003 Mac OS X V10.3 and Mac OS X V10.4 1 Not all all-in-one features are available from all drivers or operating systems. See the context-sensitive help in the printer driver for available features. 2 A Macintosh printer driver and the necessary PostScript (PS) Printer Description files (PPDs) are included with the all-in-one. Additional drivers The following drivers are not included on the CD, but are available from the Internet. ● UNIX® model scripts ● Linux drivers ● Windows XP 64-bit drivers You can obtain Model Scripts for UNIX and Linux by downloading them from the Internet or by requesting them from an HP-authorized service or support provider. For Linux support see www.hp.com/go/linux. For UNIX support see www.hp.com/go/jetdirectunix_software. Typical installation The following software is included with a typical installation: ● HP ToolboxFX ● HP LaserJet Fax setup utility ● HP LaserJet Scan program and driver ● HP LaserJet Fax ● Readiris OCR (not installed with other software; separate installation is required) ● Printer drivers (PCL 6, PCL 5e, PostScript® Level 2 emulation [PS]) ● HP Director (Macintosh) ● HP All-in-One Setup Assistant (Macintosh) Minimum installation The following software is included with a minimum installation: ● PCL 6 printer driver ● HP LaserJet Scan program and driver ● HP LaserJet Fax setup utility NOTE Minimum installation supports faxing from the control panel. Hope this helps
Jun 04, 2009 | HP LaserJet 3055 All-In-One Printer
I need to install HP deskjet 6940 on my Powerbook G4. I am operating on MAX OSX 10.4.6
If your printer does not appear in the Printer pop-up menu, find and install the appropriate driver. Check any CD-ROM discs included with the printer, or the website of your printer's manufacturer. Only users with an administrator account can install software.
Tip: You can also open the Printer List window from Printer Center (Mac OS X 10.2.8 or earlier) or the Printer Setup Utility (Mac OS X 10.3 Panther, or later).
Check the Printer menu again after installing the software. If the printer does not appear, you may need to do this:
  1. Make sure the printer is connected to your computer, plugged in, and turned on.
  2. For Mac OS X 10.2.8 or earlier, from the Printer menu in the print dialog choose Edit Printer List. The Printer List window appears.
  3. For Mac OS X 10.3 or later, choose Show Printer List from the View menu. The Printer List window appears.
  4. Click the Add Printer button.
  5. Choose USB from the first pop-up menu.
  6. Select your printer from the list.
  7. Click Add.
  8. Close the Printer List window.
How to add a network printer (AppleTalk or LPR)
Adding an AppleTalk or LPR network printer is very similar to adding a USB printer. In Step 4 above, you would choose AppleTalk or "LPR Printers using IP" from the pop-up menu. From there, the setup differs slightly.
AppleTalk printer
  • AppleTalk must be enabled in Network preferences.
  • If your network uses AppleTalk zones, choose one from a second pop-up menu that appears.
  • Make sure to avoid potential issues with AppleTalk multi-homing.
LPR printer
  • You must enter the printer's IP address or DNS name.
  • If you're printing to a queue, deselect the checkbox for "Use Default Queue on Server", then type the queue's name. If not, leave the checkbox selected.
  • You can select your printer from the Printer Model menu or leave it at Generic. In essence, are selecting a PPD file.
Question mark appears, or trouble finding a printer?
If you can't find the printer you want to add in the list of connection methods, make sure you're choosing the right connection type for your printer. Some printers may use custom input-output modules, such as "Epson AppleTalk". You may need to select one of these custom options in order to add your printer. If there's a question mark on the printer's icon, or Print Center or Print Setup Utility lists it as unsupported, check for an updated software version at the manufacturer's website, or the Mac OS X downloads page.
Tip for software installation
Your printer may appear in the printer list before manufacturer-required software is installed. If you have such a printer, remove the printer from your printer list before installing the software. Add the printer back to the list after you've installed the software.
Printers whose drivers or PPDs are included with Mac OS X
Additional Information See these articles for lists of printer drivers and PPD files included with Mac OS X:
25587: Mac OS X 10.3: Included PPDs for PostScript Printers
25588: Mac OS X 10.3: Raster (Inkjet) Printer Drivers Included
107001: Mac OS X 10.2: Included Ink Jet Printer Drivers
107002: Mac OS X 10.2: Included PPDs and Use of PostScript Printers
106490: Mac OS X 10.1: Many Third-Party Ink Jet Printer Drivers Are Included
106516: Mac OS X 10.1: Includes PPDs for Many PostScript Printers
Jul 10, 2008 | HP Office Equipment & Supplies
Phaser 7700 Mac System 10.4
I was using that printer with OS X 10.4 and I think the problem comes from the communication between the Mac and the printer. Is there anything wrong? I don't think that the problem has any relation with the ppd. I use OS X 10.5 today and I also have no problem. I'm using drivers which came with the printer.
Sep 21, 2007 | Xerox Phaser 7700 Laser Printer
2,584 people viewed this tip
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
