Tip & How-To about Audio Players & Recorders
Convert MKV to vob or mp4 for playback on PS3 with your needed audio track
I'm trying to convert an MKV files to the format of vob or mp4 for playback on my PS3. The thing is that the mkv file contains two audio tracks, English and French. For some reason, the French track is the default track, but I can understand English only, so I have to look around the Internet for a program that allows me selecting English track as output audio track. After trying out couples of converters, finally I came across Pavtube MKV Converter in a forum, and found some good reviews on it. It really saved me a lot. Share it here, hope it is exactly what you are looking for. Please find a step-by-step instruction from my following contents.
First off, you can free download Pavtube MKV Converter here.
1. Launch Pavtube MKV Converter and click "Add" button to load MKV files
As soon as the file is loaded, you can double click the file name to preview the movie.
2. Click "Properties" icon to select your needed audio track
You are allowed to click on the drop-down menu of "Audio Stream ID" to see which one is your needed audio track. After your selection is done, do remember clicking "OK" button to save your choice.
3. Click on the pull down menu of "Format" to select mp4 or vob as output format for PS3
I chose "PS3 Video (720P) MPEG-4 (*.mp4)" for instance. To output vob files, you can select "VOB Format" firstly, and then select a format according to your own requirement.
4. Click "Settings" button to do advanced settings
If you want to adjust the video and audio parameters to achieve a special video and audio quality, you can click "Settings" button to adjust video and audio parameters like codec, image size, bit rate, etc to whatever you like. To get a smaller file size, you can select smaller values, but there will be some video loss to some extent; to get a better quality, you can select larger values, while the file size will be enlarged without doubt. That is to say you'd better make a good balance between the output file size and the file quality. If you are not good at it, you can totally skip this step, because the default settings can satisfy you needs basically.
5. Click "Convert" button to start converting mkv to mp4 or vob
Once finished, you can get the resulted files via clicking on "Open" button effortlessly. Now, it's time to enjoy the movie on your PS3 via your wide screen TV.
The end! Hope this helps.
For more: http://www.pavtube.com/guide/mkv-to-mp4.html
how can I play Canon's HD .MOV files on the PS3?
Hi van derb
You would need to convert MOV file into a format which PS3 understands.
This can easily be done with a simple conversion tool such as the 3herosoft PS3 Video Converter.
1) Download and install 3herosoft PS3 Video Converter. Once installation has completed, launch the program. Step
2 ) Click "File" and then "Add" from the top menu of the 3herosoft PS3 Video Converter program. Browse to the folder and location of your MOV file. Select the file that you want to convert to PS3 format and click "Open." Once selecting the file, it will be added to the conversion list. Step
3) Edit the file as desired. Modify fields under "General" in the upper left-hand corner of the program window. Changes can be made to video size, duration, frame rate, buffer size and more. Step
4) Click "Convert" button (red circle) to convert the MOV file into PS3 format. Locate the converted file and transfer it to your PS3 for playback.
You can download this software from following link. http://download.cnet.com/3herosoft-PS3-Video-Converter/3000-2194_4-10909133.html
Please rate, as this will help us know whether solution was helpful or we need to improve on it. If not resolved you may post a comment and let me know, so that I can research and provide you with a better solution. Thanks :)
Apr 28, 2010 | Sony Playstation 3 (PS3) Console
223 people viewed this tip
 Grubhead
Grubhead
