Tip & How-To about Computers & Internet
Taking good care for your hard drive
Conduct a twice a year scan disk and every quarter for the defraging. This will save the Hard Disk Drive's life and the files for corrupting.
Computers & Internet Logo
my system is running slow
Slow computer If you have a virus program installed, it is most likely is running a scan on your hard disk. It can slow down your computer especially if you have a large hard drive. After scanning is completed then the computer will be faster.
To make your computer (hard disk) lean and mean, uninstall any programs you do not use.
Also you need to maintain your hard disk by running Disk Cleanup this will remove old temp files and old compressed files etc.
This will reduce the number of files the virus scanner has to scan. Plus running Defrag. this makes your files contiguous so the system can access files off the hard drive quicker because it does not work as hard.. Disk Cleanup and Defrag should be carried out at least once a month.
If you have 512Mb of RAM installed then installing more RAM will speed up your computer. After installing your graphics card, you may need to disable the built-in graphics card in the BIOS for the new graphics card to work properly.
Apr 22, 2013 | Computers & Internet
drive corrupted and unreadable.
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
hope this helps
Jan 29, 2011 | Western Digital My Passport Essential SE...
It says the drive is corrupted and unreadable.
hope this helps
Jan 05, 2011 | SimpleTech SimpleDrive Pininfarina 500GB...
My segate hard disk got corrpted . Want to recover my data
then run your antivirus program
hope this helps
Dec 30, 2010 | Seagate (ST3160827AS) 160 GB Hard Drive
it says that the disk has a few bad sectors.does that mean that i have to get a new one?
go to control panel administrive tools computer management you can right click on the drive select properties tools check now?tick in both boxes to scan for and attempt to repair/recover any bad sectors and automaticall fix any corrupt files
in xp
hope this helps
Dec 07, 2010 | Hitachi HTS541612J9SA00 120 GB SATA Hard...
230 people viewed this tip
David Payne
David Payne
