Tip & How-To about Computers & Internet
Quoted from: http://www.daniusoft.com/convertdvd/dvd-to-wmv-hd.html
Backup DVD to WMV is common with arising portable multimedia players. Then how about DVD to WMV HD,
are you catching up with the new high definition trend? With more and
more people around talking about DVD to WMV HD encoder, do you curious
about what exactly is WMV HD, WMV HD encoder and why DVD to WMV HD?
What is WMV HD and what makes it different from WMV?
WMV
HD is Windows Media High Definition Video, and the difference between
WMV HD and WMV comes down to its video resolution. Standard definition
we usually see has at most 480 visible lines of detail, whereas high
definition video has as many as 1,080.
Standard Definition Video
480p and lower resolution
From 720p up to 1080p resolution for now
Useful Encoders needed for WMV HD
Windows Media Video HD (WMV HD) can be encoded
with a variety of programs such as Windows Media Encoder, Windows Movie
Maker, and Microsoft Expression Encoder. When encoding, it has been
recommended by these programs that you use the original file for best
results.
Free WMV HD Demos you can downlaod
WMV HD Content Showcase
is what Microsoft Windows Media provided for you to download high
definition video to have a try. FYI, Windows Media Audio and Video 9
Series is a breakthrough set of codecs that enables multichannel audio
and high definition (HD) video at resolutions up to 1080p.
Why should you convert DVD to WMV HD?
You
may complain that the video quality is not as clean as the original DVD
after ripping DVD to standard video. For an ordinary DVD movie is often
7-8 GB in size, if we convert them to standard video formats the size
would be hundreds of MB, so we have to face the problem that the code
compress process would destroy most of unimportant data and the video
quality get bad. Then what can we do to resolve this issue? The answer
is to convert DVD to WMV HD, for these HD videos are often bigger than
standard video and decrease the video damage. Thus, the WMV HD video
seems to be lossless compared with the original DVD.
How to convert DVD to WMV HD?
The self-explaining interface allows you to convert DVD to WMV HD within 4 easy steps.
Step 1: Download, install and launch DVD to WMV HD Converter - DVD Ripper software
Step 2: Load DVD, select output format and set destination folder
Click
''Load DVD' button to add the DVD file. You can also click 'Load File'
to add DVD/IFO from your hard disk. Then click "Profile" to select "HD
WMV Video" as the output format to keep the movies in high definition,
so you can play them via HD Media Player such as HDTV, Xbox 360, PS3,
etc.
Step 3: Set advanced settings
Click "Settings" to customize the parameters like Bit Rate, Video Size and Aspect Ratio, etc.
Step 4: Start to convert
Finally,
click "Start" button to start converting DVD to WMV HD. The output WMV
HD files can be found by clicking on the button "Find Target". After
that, you can copy these files via USB to your hard drives, and plug in
it to HD Media Player like HDTV, Xbox 360, PS3 to enjoy.
And you may see the edit part in this program, yes, it enables you to do simple editing if you need:
So just enjoy your WMV HD video with this DVD to WMV HD Converter.
Download Daniusoft DVD Ripper Now !
