Tip & How-To about Computers & Internet
How to fix your Asus Eee PC laptop screen when it is stuck sideways
When computer gets stuck sideways--SELECT VIEW-ROTATE VIEW--CLICK CLOCKWISE OR COUNTER CLOCKWISE and it goes back to the proper view.
Computers & Internet Logo
my acer screen is sideways. how do i fix it?
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures. Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees. Rotating the computer screen allows for more display options. For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display.
Windows XP/Vista Monitor Orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish.
Apr 11, 2013 | Acer Computers & Internet
there is a pdf article i need to read for a college class but the pdf is sideways and i am not sure how to rotate it. can you help me? MacBook pro
using Adobe Reader, there is a view tab at the top of the page (file / edit / view / window / help)
click view, then move to rotate view and click clockwise or counter clockwise, depending on which way you need to turn it.
Aug 22, 2011 | Computers & Internet
The screen on my acer laptop has turned upside down.. How can i turn the screen around?
I know how inconvenient working on your laptop the image in it is upside down. But don't worry I will help you with this concern.
I have a video tutorial that will walk you through on how to correct it or fix it.
Just click the link VideoTutorial so that you will directed on the video tutorial page. Once you get there, please wait to load the video completely, it takes quite while.
But if you want a written walk through, not a problem I will provide that.
Laptops are very customizable. There is a very handy technique that has been a feature on laptops for many years but is still not widely known. It comes in handy for a lot of reasons. For anyone who wants to relax and watch a movie on their laptop or read an ebook, the ability to rotate their laptop's screen from vertical to horizontal makes these activities so much easier. This explanation applies to Windows Vista and Windows 7.
1. Hold down the "Ctrl" and "Alt" keys and press the "Left Arrow" key. This will rotate your laptop screen view. Return to the standard screen orientation by holding down the "Ctrl" and "Alt" keys together and pressing the "Up Arrow" key. If you were unable to rotate your screen with "Ctrl + Alt + Left," go to step 2.
2. Right-click on the laptop's desktop and select "Personalize."
3. Find the "See Also" menu on the left side of the screen and click "Display."
4. Click on "Change Display Settings" and choose "Orientation" from the drop-down menu.
5. Choose from "Landscape," "Portrait," "Landscape (Flipped)," and "Portrait (Flipped)" from the box that appears. "Landscape" is the standard view. "Portrait" changes the view to sideways, leaning to the left. "Landscape (Flipped)" shows a sideways view leaning to the right. "Portrait (Flipped)" turns the screen upside down.
6.Click "Apply" and then click "OK." Your screen orientation is set to whatever version you like.
Proceed to play jokes on your friends by flipping their computer screens when they are not looking, then tell them "That's not good, dude."
I hope you find it very helpful. Thank you for using fixya.
Aug 13, 2011 | Acer Computers & Internet
how do I rotate my screen back to horizontal view?
press ctrl+alt+arrow(of that direction which u want to rotatae ur screen)
Feb 25, 2010 | HP DC170B Keyboard
15" Dell monitor
You have your video card set to rotate the screen after Windows loads.
Go into your display properties using it's control panel and look for the rotate section. Set it back to 0 degrees. Make sure you click apply and then OK, not just OK.
Apr 18, 2008 | Dell E151FP 15" Flat Panel LCD Monitor
295 people viewed this tip
David Payne
David Payne
