Tip & How-To about Dryers
Electric dryer will not work at all?
If the electric dryer does not work at all then there are some possibilities that have to be checked to confirm the fault.
1) Check whether you are getting power to the dryer from electric out let to which the dryer is connected. The power problem can also occur if the fuse is blown or the circuit breaker is got tripped.
2) Other possibility for dryer not working is the blown thermal fuse. The thermal fuse is located to the exhaust duct inside the back cover panel. This fuse blows out if the dryer gets overheated or any short circuit occurs in the house when dryer is in working.
3) One more reason for dryer not working at all is the fault in the door switch. The dryer will not start working till the door is closed. But if the door switch or the door-switch actuator is got cracked or worn out or loose then door will not get closed properly and dryer will not work. In this case check the door switch/actuator and replace it if required.
4) But if all the above mentioned possibilities checks out OK, and still the same problem, then there is a fault in the wiring. Check the main power cord of the dryer which you connect in the electric out let. If the power wire is got internally burned out or got cut in between the dryer will not get power and will not work.
This will help. Thanks.
Dryers Logo
dryer constantly turns to 20 minutes no matter what it is turns to
Possible fault in the program controller unit, it can be related to a memory failure. Switch off power for some time and try again to confirm this fault.
Aug 22, 2013 | Siemens WT79020EU Electric Dryer
if the dryer shut in 10 to 15 minuts
Possible that there is overload and it can trip the motor. You need to observe this to confirm. Also check for free movement of the rotor and the motor drive.
Finally a fault on the timer can also cause this issue and you need to clarify further.
Nov 07, 2011 | LG DLE2532W Electric Dryer
Control panel lights are on, but when you push the on button, nothing happens.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 30, 2010 | Maytag Neptune MDE5500AY Electric Dryer
224 people viewed this tip
Top Dryers Experts
