Tip & How-To about Heating & Cooling
Honeywell electronic programmable thermostats
When working with Honeywell you can got o their site and find your model number so we can help you on thermostats they normally don't give you help except on how to program the timer but with model information our techs including me can help you diagnose your problem. In the U.S. you have to be a licensed AC tech to do repairs or get support.
http://www.hvacgiant.com/dept/thermostats/category/?catid=543
Heating & Cooling Logo
Why does fan not cycle off on heat cycle for TH5220D1029 thermostat
1) normally you must to exchange by new batteries with the same types alkalines FULL charges.
1a) see if there are some wires loose and tight it
2) reset and program it again , follow the instr. manual if you do not have download from Honeywell from section support give the number, model and do it.go to http://yourhome.honeywell.com/home/
God bless you
Oct 08, 2012 | Honeywell Th5220d1029 Non-programmable...
We had a Honey Thermostat model # TH4110D1007 installed in our house, our technician did not leave an instruction manual with it and we don't know how to run it, can we get a website to download a manual. Thankyou, Judy
yes just go to honeywell site. The address is inside the thermostat. Just pull the front part of the thermostat off and read the lable inside. Hope this helps.
Sep 06, 2011 | Honeywell Heating & Cooling
honeywell thermostat manual
The model number is going to be on the thermostat. It is not unusual for the number to be on the back of the stat, meaning you may have to take it off the wall. It could also be found betweenthe base ans the stat.
Once you have the model number googel "Honeywell XXX" with XXX being the stat model number. If you can't find the stat, you can go to the Honeywell web site and do a search, matching your stat, by the pictures and functions. It is a bit tedious, but it works.
Jul 22, 2010 | Honeywell Programmable Thermostat Heater
I need a copy of the operting instructions for
you can call honeywell at 1-800-345-6770 the number you gave me does not show up, normally the part number is on the back of the plate. You can check there web site here.
http://www51.honeywell.com/honeywell/contacts.html
Feb 15, 2010 | Honeywell Programmable Thermostat Heater
problem with Honeywell RTH230B Thermostat
Sounds like you have it wired wrong..   Pop the top off and give me to color of the wires and tell me which letter each color wire is on.. that will tell us right away if you have it wired wrong
May 27, 2008 | Honeywell Programmable Thermostat Heater
129 people viewed this tip
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
