Tip & How-To about Computers & Internet
How to Enable Windows 7 to make a Remote Desktop Connection
1. Go to Control Panel>System>Advanced System Settings
2. Go to Remote tab.
3. Under Remote Assistance, put a check mark on Allow Remote Assistance connections to this computer.
Note: This automatically adds Remote Desktop exception to Windows Firewall.
4. Click on Apply.
1. Go to Start>All Programs>Accessories>Remote Desktop Connection
2. Enter the Computer Name or IP address of the computer you wish to connect to.
3. Click on Connect.
4. For more connection options, click on Options
Here you can save the connection profile, adjust display properties, run specified programs upon connection, adjust connection bandwidth, etc.
For more information on specific tabs, click on Help.
Computers & Internet Logo
How do you permanently remove a remote user from a hp laptop
it depends on what software you are using. usually ( if your using windows) you can find the remote assistance option in the control panel.
Gonna need more info. version of windows are you using?
*if you using windows 7
To disable remote assistance connections to your PC
  • Click on Start > Control Panel > System > Advanced System settings > Remote tab
  • Uncheck "Allow Remote Assistance connections to this computer".
Mar 06, 2016 | HP Computers & Internet
How can you stop people from using remote access from there PC to yours?
1. Right click on My Computer
2. Click Advanced System Settings
3. Chose Remote Tab
4. Check (Don't Allow Connections to this Computer)
And That' Is
Oct 10, 2013 | Computers & Internet
i get a message low memory how can i fix this dell inspiron 1525
In Windows XP
1.Click Start, and then click Control Panel.
2.Click Performance and Maintenance, and then click System.
3.On the Advanced tab, under Performance, click Settings.
4.On the Advanced tab, under Virtual memory, click Change.
5.Under Drive [Volume Label], click the drive that contains the paging file that you want to change.
6.Under Paging file size for selected drive, click to Custom size check box. You can enter the amount of memory you would like to reserve for Virtual memory by entering the initial and maximum size.
7.Click Set
Jul 21, 2010 | Dell Inspiron 1525 Notebook
How can I increase the memory for this computer
In Windows XP
7.Click Set
When you are prompted to restart the computer, click Yes.
Special Note: You should choose the same amount for the initial size and maximum size. This will Stop your CPU from constantly changing the paging file.
In Vista
1. Click Start button Picture of the Start button
2. Click Control Panel
3. Choose System and Maintenance and then click System.
4. In the left pane, click Advanced system settings.
5.On the Advanced tab, under Performance, click Settings.
6. Click the Advanced tab, and then, under Virtual memory, choose Change.
7. Click Custom to change the Initial size (MB) and Maximum size. See the hot tip above.
Remember to choose the drive you would like to use to increase the virtual memory. In most cases it usually your C: Drive. You can set the initial size and maximum size after clicking the Custom size check box.Remember its better to keep the Virtual memory values the same.
Also having enough available space is absolutely necessary for your virtual memory and RAM to function properly.
Jun 11, 2010 | Compaq Presario 700 470024-192 Notebook
all icons on my pc desktop are always in selected mode(these looks like when we select an icon to do something,that means these are shaded with blue color,but i can select 1 or more icons at a time as usual to do what i want)so i face no problem.but i want to get rid of this situation.when i was copying text from a web page on desktop,then i tried to paste on desktop.then it created.i forgot that which options i clicked how it created.plz help me.windows xp(professional sp-3) operating system
Hi
If you have any web content on your desktop, transparency won't work.
To check for web content: Display Properties>Desktop>Customize
Desktop>Web - make sure all checkboxes are clear.
then
1. Click on Start
1. Choose Control Panel
2. Click on System Icon
3. Choose the "Advanced" tab, click "Settings" under "Performance"
4. Under the "Visual Effects" tab I Chose (checked) Use Drop Shadows for Icon Labels
OR 1. Click Start, and then click Control Panel.
2. Click Performance and Maintenance, and then click System.
3. On the Advanced tab, click Settings under Performance.
4. Click to clear the Use drop shadows for icon labels on the desktop check box, click Apply, and then click OK two times.
5. Close Control Panel
May 10, 2010 | Microsoft Windows XP Professional SP3 Full...
201 people viewed this tip
David Payne
David Payne
