Tip & How-To about Audio Players & Recorders
DVD Player Quick Connect Tips
There has been a lot of confusion lately about how best to connect your new DVD or Blueray player to your TV set. For many this has been a nightmare since the introduction of the new Component and HDMI versions of Higher Priced DVD and Blueray disc players.
Remember that your new Blueray player will play DVD's as well as Blueray Disc format movies.
For the common connection that most people use, there are only 3 wires to consider. Yellow for Video, Red and White for Stereo. Always use the line out jacks on the back of the player to connect to the TV. Use the Line in (Video In) jacks on the TV set.
The only thing to remember here is to match the colors exactly and select the video source from your TV remote control. If all those numbers and buttons are confusing to you, just memorize where your Source button is on the remote, and choose one input at a time until your DVD welcome screen appears.
The next higher quality Video source will be the component Video outputs on your DVD or BlueRay player. These will be Red, Green And Blue.
Also note that you will need a red/white audio cable for sound with these connections since the component outputs only transmit Video.
You will be able to see the audio connectors close to the red blue and green component outputs on most players. All connectors on your player will be outputs, unless you bought a DVD recorder and player.
We will reference only the player type at this time.
As mentioned before, you only need to match the wires from the DVD or BlueRay output to the exact input connectors on your TV, but now the audio connectors need to be used as well.
Component to component cables/
Stereo Audio Cables/
Use your source selector on the remote as before to View your movie.
The easiest connector to hit the market so far is the HDMI version, which combines the Video signal as well as the audio signal into a single manageable cable. If your TV set doesn't have this connector you will need to use one of the above methods to connect your system.
To use the HDMI you need only plug it in to the connector designed for its use on both the TV as well as the player.
There is very little chance you will connect this to the wrong port, but just in case your HDMI TV and DVD/Blueray player are equipped with an Optional USB port, you should read the panel closely to be sure you have the right port. Remember, these connectors should never be forced on. If they are too tight to connect, you may have chosen the USB port by mistake.
Thats my Tip o the Day
Please Vote for this Tip if you found it helpful.
Bob S.
how to connect netflix with sony blueray disc player?
Switch on the blueray player. Switch on your TV set. Connect your blueray player to the TV with an appropriate cable. Press HOME on the blueray player. Navigate with the blueray player remote control to NETFLIX and press OK. After a few seconds NETFLIX should start.
Jun 22, 2014 | Netflix
trying to hook it to dvd blueray and hd cable need help diagraph confusing
If you're using HDMI cable there's not much of confusion, out from the Blue player and plug it in to the TV
Jun 05, 2010 | Samsung 40 in. Flat-Panel LCD HDTV
We have a SAnyo HDTV LCD Model DP19649 and can't
I have a sanyo dp-19649 tv and it's hooked up to a panasonic sound bar model# sc-htb10,and it's hooked up to a sony blueray dvd player. the sony player works on the sound bar but the tv doesn't.
Nov 12, 2009 | Sanyo Televison & Video
I have a new 52" Samsung HD TV with a new Sony Blue Ray player and a Shaw PVR cable box all connected with HDMI cabes. I also have a older digital RCA model RTDVD1 sound system with no HDMI connection and no component connection. It does however have a digital optical connection and a coaix connection as well as the standard RCA in/out connections. We had the sound system working well on our old TV and VCR players but I am not sure how to hook it up with these new components. How is the best way to set this sound system so that I get the Dolby Surround Sound when watching movies on TV or on the Blue Ray DVD?
I have the same situation....what I have done is connected my Blue ray to the TV via the HDMI connection and the audio to the RTDVD1 via an Optical cable. I find this is the best connection and sound reproduction so far. The input of the RTDVD is the SAT/Optical input and then switch the source to SAT/OPT. You will have to make adjustments in the BlueRay player's audio setup to enable the 5.1 DB digital sound etc.
Jan 24, 2009 | RCA RTDVD1 System
No connection/ no signal
Either the new BlueRay player is defective, the HDMI port on the player is defective, or the port on your set is defective.
Try connecting it with component RGB/AV cables, or S-Video/AV cables and see if everything works. If so, then you know that it is either the port on the BlueRay, or the port on the TV set.
To test the HDMI port on your TV, you will need another HDMI device to try.
Jerry G.
Aug 13, 2008 | Sony BDP-S300 Blu-Ray Disc Player
236 people viewed this tip
 Grubhead
Grubhead
