Tip & How-To about Computers & Internet
Select ur pci 2.0.................
Yes,whenever you ought to buy any graphics card i recommand u to buy the card of nvidia because above 30% of the games are being made under support of Nvidia and Voodo(but this is overtaken by anyother company) whter these cards are 500bucks more than the otther cards but they are very useful in running ur games like butter.
Computers & Internet Logo
nvidia geforce go 7150m graphic card not supporting aero why not?
Its an older card that was made before the aero translucency was introduced. You need a card that supports DirectX 10.0 or higher.
Buy a cheap NVidia card on ebay and download drivers for it from the nvidia website, then fit it.
Dec 07, 2013 | HP CTO nvidia Geforce (128 MB) Graphic...
My Nvidia GeForce FX 5500 / 256MB DDR / AGP 8x / DVI / VGA / TV-Out/ Video Card Graphic Card Crashes when I try playing games?
The graphic card usually crashes due to over heating. Keep the gpu cool. you may use a pedestal fan as well.
Mar 25, 2012 | Nvidia GeForce FX 5500 / 256MB DDR / AGP...
my motherboard was biostar nf61s.i want a new graphics card.i currently using nvidia 8400 gs it was not good to me.i want to buy a new nvidia 240gt.if it works fine?(and give hard ware installing instructions).
If you need a new card for gaming purpose please go for ati 5770 or nvidia 9800 gt as you will get a better gaming performance from both of these as compared to 240gt.
You may also have to upgrade your power supply unit as higher graphics card require more power.
Feb 25, 2011 | MSI Graphics Card - nVIDIA Geforce 7600GS...
i need Nvidia GeForce 6600 / 256MB DDR / AGP 8x / DVI / TV-OUT / Video Card Graphic Card how can i buy this item??
PC shops, online PC shops or even ebay.
Here's the URL to the Nvidia website, Click on the "BUY" tab at the top.
http://www.nvidia.co.uk/page/geforce_6600.html
Dec 02, 2010 | Nvidia GeForce 6600 Graphic Card
I have Nvidia Geforce 9500 GT graphics card ...I recently bought my system...4 GB corsair ram....1 TB hard disk...400 W Cooler master PSU...Classic intel H55 motherboard...Still when play Gta or NFS hot pursuit my system hangs ....what could be the reason...is it anything to do with my graphics card ...how can i solve this problem...
How can I state this politely?
The Nvidia GeForce 9500GT is a definite step up from using Integrated Graphics.
No debate needed there.
But it only has 32 Stream Processors.
Think of Stream Processors as a 'Graphics Information Highway'.
They are essentially the lanes of the highway.
The more lanes you have, the more graphics information can be transferred from the graphics card to the Processor, and vice-versa.
Having 32 Stream Processors is like having a 'Bottleneck' in the road.
Equate that to a roadblock put up for road construction, where 8 lanes are dwindled down to 1 lane.
Traffic slows down.
This is seen when using intense games. Frame rates drop down, the game freezes, and graphics are poor unless on low settings. (Or not at all)
Here, take a look at Evga's version of the Nvidia GeForce 9500GT graphics card.
Read the Specifications at the bottom, watch the video.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4111742&CatId=3669
However!
A decent graphics card shouldn't 'Break the Bank'.
You don't need a $500 graphics card to slam those games.
You might want to look into an Nvidia GeForce GT 240 graphics card.
96 Stream Processors.
512MB of DDR5 graphics ram memory. (That's DDR5)
550MHz Core Clock
1340MegaHertz Shader Clock
3588MHz Memory Clock
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5516908&CatId=3669
Better than that?
Nvidia GeForce GTS 450 Superclocked.
1024MB of DDR5 graphics ram memory.
192 Stream Processors.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6655890&CatId=3669
For the above two graphics cards you need a decent power supply.
IF, the power supply you have DOES produce an honest maximum wattage of 400 Watts,
AND has at least 30 Amps on the 12 volt power rail. (Or 12 volt power rails), you're okay.
I would recommend an OCZ StealthXStream 2 / 600 Watt power supply though, when you can afford it.
It can produce over 700 watts if kept at a temperature of 48.4 degrees Celsius.
(119.12 degrees Fahrenheit )
Has FOUR 12 volt power rails that can supply up to 18 Amps EACH.
(Total of 72 Amps)
Has all the power cables you'll need, plus ones for the above graphics cards.
(Can handle them with NO sweat)
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6491962&CatId=106
Not advertising for Tigerdirect. Just using them to show examples.
Regards,
joecoolvette
Nov 08, 2010 | Evga NVIDIA GeForce 9500GT,, PCI Express...
141 people viewed this tip
David Payne
David Payne
