Tip & How-To about Computers & Internet
Laptop (and PC) overheating
If you have gas heat. dust, smoke, use perfumes, have pets, cook or generally live at all you have all the factors that will cause your laptop to overheat. When it overheats it will run slow or you can have a lot of blue screens or unpredictable performance or issues. In other words it gets very annoying. What happens is that the dust is pulled inside and sticks to the cooling parts. The cooking oil vapor or perfume oils make them stick even more. So eventually this dust starts to form enough of a layer (and it isn't that much of one) to insulate the cooling parts from the cooling air and the result is it overheats. So instead of getting a new laptop or spending $50 to get it cleaned every 6 month to a year here is what you do. The bottom of your laptop should never feel hot and the air coming out should never feel more than slightly over room temp. If either seem warmer time to clean. How often you clean depends on your house. It may be every few months to every year or longer.
You need a can of compressed air usually sold at computer shops as keyboard cleaners. You need a few thin pieces of something like wire. You really want something stiff and preferably something plastic but wire will work. Remove the battery and set it aside. turn the laptop upside down and place on the table (outside is good if it turns out to be really bad). Look for the cooling fan. You will see the blades hidden under a grill. You then insert a wire into each fan. This will stop the fan from spinning when you blow air across it. The air can spin it faster than it should and cause bearing damage. Use the compressed air and blow air in from the exits first. The will loosen things. Then blow in over the fan. You just need to give it a few seconds each way. Don't be surprised if all the dust you see is a small puff and that's it. It takes very little to cause some laptops to overheat. As an example of how little if you have ever seen a smoker puff out that is way more than what you will see. Take the stop wires out of the fans put the battery back in and you are done. You should immediately notice the difference in temperature.
Computers & Internet Logo
creating soot in house
Sooting is general caused by incomplete combustion. Which, most of the time is caused by a dust, lint and/or pet hair build up in the heater. It clogs the burners , as well as the air intakes. Thoroughly cleaning the interior of the heater and it's inner workings will generally solve the problem. Also, an less frequent ... low gas pressure to the heater can cause sooting. Burning scented candles while the heater is in operation contributes greatly to the soot problem and indoor air pollution.
The above should help you to further troubleshoot and solve the soot problem.
Apr 26, 2011 | Williams (5009622) Ceramic Gas Wall...
MY LAPTOP BECOMES EXCESSIVLY HOT AND CUTS OUT. ITS SITTING ON 2 USB FANS YET THIS MAKES LITTLE DIFFERENCE TO THE OVERHEATING. IN ADDITION TO THIS IT FREEZES AND THE ONLY WAY TO CORRECT IT IS TO HOLD THE POWER BUTTON TILL IT TURNS OFF.
Hi. Your laptop is experiencing overheating issues. This happens when the built in fans no longer have a functioning airflow. Collected dust may be closing the air vents and that is why even the laptop coolant do little help. I would recommend bringing you laptop to a local tech to have it cleaned including testing of internal parts. Thanks.
Feb 16, 2011 | Computers & Internet
After being on all day tv shuts off momentarily and then comes back on. Intermittent problem.
Intermittent power problems are a total pain to nail down so Unfortunately the best advice I can give might narrow it down a little. I would look at two things that I've seen cause this.
One is the TV is simply overheating. Due to the way they are designed they pack a lot of electronics into a tight container and there isn't that much airflow. So what can happen is dust will collect inside and cause it to get hotter than normal. If you have laptops or desktop computers they have the same problems. If you have gas heat, smoke, have pets, use a lot of perfumes or the TV is near the kitchen this makes it worse.
You can use compressed air to blow out the TV and see if this help. You won't get more than a good puff of dust but that's all it takes. Do this once a year and you should be fine.
Unfortunately the other problem is usually capacitors in the power section going out on you. They overheat and cause the power section to reset or restart, This requires a repair shop to fix. Check your warranty to see if you can get it fixed for free. If not you need to check out if any shops will fix it. As a word of caution check out the cost of a new replacement before getting it fixed. You might find that the shop will charge enough that a new TV is not much more than the repair bill. Sometimes its a cheap fix but...
Aug 05, 2009 | JVC Televison & Video
cpu heat
Overheating is a common problem with laptops, and usually a bit of preventative maintenance is all it takes to keep it alive. The bearings on those fans are pretty durable, however dust (and especially pet hair) can build up and slow it down. The motor may still be good, its just that the fan blades are stuck.
Blow some air in the vent OPPOSITE the direction of normal air flow (In most cases it sucks from the bottom and blows out the back/side) and if you see dust bunnies, your doing good. Be THROUGH! Especially if you smoke in your house, this causes the dust to become brown and sticky. = )
Good Luck!
Oct 27, 2008 | Computers & Internet
Satelittle A75-S229 shut off
This is a oh-so-common problem for the Satelite A70/75 and it usually is caused by one of two things. If you google "Toshiba Satelite heatsink overheating" and/or "Toshiba Satelite DC plug" you will get a very extensive list of options to repair the problem.
This should take care of the problem and if it doesn't please let me know - it will mean I have something new to look forward to!
MJA
Aug 27, 2008 | Toshiba Satellite A75-S229 Notebook
231 people viewed this tip
David Payne
David Payne
