Tip & How-To about Audio Players & Recorders
How to hard reboot your ipod touch if it is locked
So if anyone has ever forgotten their ipod touch's passcode or somehow gets locked out and can't get back in even if you restart it, you can try the one and only solution, the hard reboot. It works great, except you will lose all data on the ipod touch. There are two ways to complete this task successfully, first of all you can use the first way i learned, which is: hold both the top screen lock button and the home button for about 8-10 seconds, and the slide to power off thing should pop up, don't slide it though. When you reach this point you release the top screen lock button but continue to hold the home button until the ipod turns off, then it won't turn back on until you plug it in to a computer and then restore it using itunes. The second way is a little bit easier, you just have to hold down the screen lock button and the home button at the same time for 30 seconds and this will do the same thing as the first method. Thanks for reading, I hope this helps :D
Shorter Simplified Version: Hold down sleep and home button until you see the restarting apple logo, then release the sleep button and continue holding the home button until it shows the sign to plug into your computer then restore.
itouch disabled
When your iPod Touch displays a message telling you to connect it to iTunes, it may be in recovery mode, or have been disconnected in the middle of an update.
To get rid of the screen, you must reset your device. If in passcode mode, an iPod Touch must be manually unlocked or fully restored to get back to the home screen.Forcing a Reboot
When your iPod Touch is stuck on a screen that is instructing you to connect with iTunes, a normal restart will probably not work, as the hard drive has become frozen.
You can still, however force the iPod to reboot using a process called resetting.
To reset an iPod Touch, hold down the "Sleep/Wake" and "Home" buttons at the same time until an Apple logo appears, indicating that the device is rebooting.
When an iPod Touch reboots, it always goes back to the lock screen. Passcode mode will still be enabled.
Unlocking With the Passcode
If you know the passcode for your iPod Touch, slide the "Slide to Unlock" arrow and then enter your code on the next screen.
Upon entering your password, you will be directed to the device's home screen. If you enter the wrong password too many times, it will become disabled temporarily.
The iPod Touch can also be set to erase all content after 10 incorrect passcode attempts if you previously enabled this feature, don't attempt more than 9 entries.
Unlocking Without Passcode If you have forgotten the passcode to your iPod Touch, the only way to unlock the device is by restoring it.
Restoring an iPod Touch returns it to the factory settings, meaning that any settings, applications or music you added to the iPod are removed.
Once the device is restored, you can re-add your downloads and other information using the backup copies in your computer iTunes program.
The passcode setting will be disabled unless you manually enable it again.
Consideration
If you don't have a backup of your music and applications in iTunes on your computer, you can also download another copy from the iTunes Store or App Store on your device after a restore.
Any photos that are deleted during restore, however, will be lost forever if a backup does not exist.
Always back up your information via sync on a regular basis to avoid this problem.
Nov 05, 2013 | Audio Players & Recorders
9c93a00208
If you own an iPod touch, you have the option to set a password, which Apple calls a passcode, to protect your data.
Anyone who attempts to access your iPod, after unlocking it or turning it on, will require the passcode to do so.
However, if you forget your passcode or incorrectly enter it, you will eventually see an alert that your iPod touch has become disabled.
To unlock your iPod touch after forgetting the passcode, and still access your content, you must connect it to the computer with which you last synced it.
Connect your iPod touch to the computer with which you last synced the music player.
Launch iTunes if it does not automatically open.
Select your iPod touch under the devices list, and click the "Summary" tab in iTunes.
Click "Restore" and, when prompted, click the "Back Up" button to save a back up of your iPod touch in iTunes.
Click "Restore" when prompted, after the back up saves. After restoring, click "Ok."
Choose the most recent back up from the drop down list on the "Set Up Your iPod" screen.
Click the "Continue" button to restore your iPod touch.
iOS: Forgotten passcode or device disabled after entering wrong passcode
http://support.apple.com/kb/ht1212
iTunes: Restoring iOS software
http://support.apple.com/kb/HT1414
Jun 10, 2013 | Apple iPod touch
forgot my ipod pascode lock
If you own an iPod touch, you have the option to set a password, which Apple calls a passcode, to protect your data. Anyone who attempts to access your iPod, after unlocking it or turning it on, will require the passcode to do so. However, if you forget your passcode or incorrectly enter it, you will eventually see an alert that your iPod touch has become disabled. To unlock your iPod touch after forgetting the passcode, and still access your content, you must connect it to the computer with which you last synced it.
Connect your iPod touch to the computer with which you last synced the music player. Launch iTunes if it does not automatically open. Select your iPod touch under the devices list, and click the "Summary" tab in iTunes. Click "Restore" and, when prompted, click the "Back Up" button to save a back up of your iPod touch in iTunes. Click "Restore" when prompted, after the back up saves. After restoring, click "Ok." Choose the most recent back up from the drop down list on the "Set Up Your iPod" screen. Click the "Continue" button to restore your iPod touch.
http://support.apple.com/kb/ht1212 iTunes: Restoring iOS software http://support.apple.com/kb/HT1414
Apr 08, 2013 | Apple iPod touch
How to restore your ipod through itunes if its disabled and you dont remember your four digit passcode
You can reset it using iTunes. Open iTunes, plug the iPod in using USB, then turn of the iPod, once it's off hold down the home and lock buttons for 10 seconds, then release the lock button while continuing to hold the home button. After a few seconds iTunes should detect the iPod. Then you should be able to restore the iPod back to factory defaults. Even if you've forgotten the passcode.
Nov 21, 2011 | Apple iPod touch
Ipod touch 16gb, passcode forgotten screen reads disabled.
well you can conpleatly restore it by no luging it in and holding the power buton for 3 seconds then with out leting go of the power buton hold the home buton for 10 seconds then let go of the power buton and just hold the home buton for a further 30 seconds.....
after you have done this plug it in to your computer with iTunes allready running and a icon should say unresponcive ipod or somethin along those lines just click RESTORE
hope this helps
dale gough
Jul 21, 2009 | Apple iPod touch
221 people viewed this tip
 Grubhead
Grubhead
