Tip & How-To about Audio Players & Recorders
This is a guide 1. How to add another comment in a question or answer in FixYa.
2. How to fill in a comment for the person who stated a solution in FixYa.
1.
Go to www.fixya.com .
Login with your FixYa username and password: Sign In in the page top. After a successful login, the Sign In mode will change to Sign Out.
Click My Profile in the page top for a list of your questions.
Select the required question or answer from the list.
Being logged in you are able to add a new comment in exact the same question or answer.
2.
Use the link in your mailbox of FixYa.com to go to your question and see the answer in internet explorer in FixYa.
To be able to add a comment, login with your FixYa username and password: Sign In in the page top.
After the login, the screen will view the question link from the mailbox again and the Sign In mode will show up as Sign Out.
Now you are able to add a new comment in exact the same question, for the person who posted the solution.
When this person is reading his/her mailbox as well, he or she is able to view your comment in FixYa and when willing to reply, he or she can write back an answer in your question.
Another mail will be posted in your mailbox with a link to the same question you've made from the start.
This way a dialog to the solution can be made between you and the person who answers, adding new comments in the same question.
How to I edit/update a resolution I already posted in fixya?
Hi Anita,
Please be advised that it is not currently an option to edit posts once they've been submitted.
If you would like to edit an answer, please contact us directly at http://www.fixya.com/contact and we will gladly assist.
Please know that you can also add any new or updated information to your answer in a form of a comment:
1. Sign in to your Fixya account
2. Click your Avatar on the top right and select "My Account"
3. Click on "My Answers" tab and locate the relevant answer
4. Select "Comment", enter your text and hit the green "Add Comment" button to submit
Dec 19, 2014 | FixYa Computers & Internet
How can I follow up on questions with Fixya.com
Hi Dave,
If you've received a request for more information or an answer to the question you mentioned, you are able to see and respond to the replies by doing any of the following:
If you received a request for more information about your question you can visit your question page and then right below your question there will be a link that will display the number of comments on your question. See image 1 below.
-image1:
Click the 1 comment link to display the comments on your question.
If your question has no comments you can click the more option and then click add a comment. See image 2 below:
- image2:
If you received an answer and would like to view the comments on the answer, the process is similar. Just visit your question page and in the answer there is a link to view comments. See image3 below:
-image3:
For example if you clicked on the 3 comments link you will see all the comments on the answer.
In all the cases these links will also allow you to comment or reply to a comment if needed.
Hope that helps, but please feel free to leave comment and I will be more than happy to help you troubleshoot more.
Dec 12, 2014 | FixYa Computers & Internet
How do u edit an answer once posted
Currently, you cannot edit an answer once it's been posted. What I normally do if I have a typo or incorrect information is add a comment to my solution with the correct info.
The person who posted a problem also gets notified there is a new comment on the website and via email.
Hope that helps!
Jul 23, 2012 | FixYa Computers & Internet
thanks for the answer,i didnt describe my question well, the saw will start full speed then it slows down followed by the breaker blowing
If you want same person to answer next question, then add a comment to that thread.
Adding comment will e-mail the expert.
If you are same guy I answered question for a few days ago, I cannot find original conversation.
1) breakers trip on heat. It takes a few moments for heat build-up to trip breaker.
Check nameplate on motor and compare with breaker amperage
Volts x amps = watts
http://waterheatertimer.org/Color-codewire.html
2) It could be motor bearing need lubrication.
Look for oil ports on each end of motor and use 3-in-1 oil.
Turn off saw and roll blade with hand to see if it rolls easy.
Check that belt is not binding or loose, or too tight.
3) If bearings are good, then motor is overheating and might need replacement.
Motors do not last forever, especially if they've been getting hot.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 08, 2011 | Garden
2,024 people viewed this tip
 Grubhead
Grubhead
