Tip & How-To about Computers & Internet
How to make a another comment in FixYa ?
1. Login with username + password
2. Enter your text in the same question
3. [Add Comments] will send the text to the responder
Computers & Internet Logo
login to my gmail account
Signing in to your Gmail account gives you access to your email messages.
Gmail Web-based email functions as most email services do, with the option for users to send and receive email messages, store contacts and organize messages.
You can opt to store your Gmail login information when signing in so that you do not need to re-enter it each time you access your email.You can access your Gmail account on a computer or a mobile phone.
Open a Web browser window.
Click the address bar and enter "gmail.com." Press the "Enter" key.
Enter your Gmail username and password in the indicated fields.
Check the "Stay Signed In" box to save your username and password for future logins.
Click "Sign In" and wait for your Gmail account to load.
Mobile Phone
Press the "Menu" key on your mobile phone and click the "Browser" icon.
Click the Web address bar and enter "gmail.com."
Enter your Gmail username and password and click "Sign In."
Nov 16, 2013 | Computers & Internet
I forgot my username for textnow, can u send it to my email, jeremydzms@yahoo.com ?
Forgot your username?
If you've forgotten your username, and you're logged in on your device, you can follow these instructions to find it:
1. Click the "gears" icon to go to the Options menu.
2. Tap the "Account Info" section where you see your Textfree number
3. Your Username is the name just before the @textfree.us.
Once you found the username,
Enter username in Login screen and click the link "I forgot my password". So password will be sent to email id to followup for login.
Thanks
Thiyaga
Aug 14, 2011 | Enflick TextNow Free - Unlimited Texting...
i forgot my textnow username
Thanks
Thiyaga
Aug 07, 2011 | Enflick TextNow Free - Unlimited Texting...
email settings
you must have email account, also the POP address, and the SMTP with your username and password ready
Set up email account
1. Select Menu > Messaging > Email > Settings > New account > Add.
2. Enter a name for the email account, for example, Home or Office. Select OK.
3. Select Connect using > Edit and select the data account you created earlier to use with this email
account.
4. Select Email address > Edit. Enter your email address. Select OK.
5. Select Connection type > Edit. Select POP3 or IMAP4. POP3 is the most common.
6. Select Incoming server > Edit. Enter the name or the IP address for the incoming server. Select OK.
7. Select Username > Edit. Enter the incoming server username. Select OK.
8. Select Password > Edit. Enter the incoming server password and select OK. Leave this blank if you
want to be asked for the password each time you check new mail.
9. Select Outgoing server > Edit. Enter the name or the IP address of the SMTP server you use to send
email messages. Select OK.
10. Select Advanced settings.
11. Select Your name (not mandatory) > Edit. Enter your name and select OK. This will appear in outgoing
email messages.
12. Select Signature (not mandatory) > Edit. Create a signature to add to your email messages and
select OK.
13. Select Download S&R. Choose what to download when receiving new email messages:
• Subjects only – receive information such as sender and subject before downloading the whole email.
• Up to size limit – receive the whole email. Select Size limit to set the maximum size to download
when receiving new email messages.
• Subjects & text – Only for IMAP4 users. Receive the subject and text but not attached files.
14. Select Check interval (not mandatory). Choose how often you want the phone to connect to your
email server and check for incoming email messages.
15. Select Push email. Only for IMAP4 users. Select On for full email notification functionality or Off to
disable the functionality. See Using push email for full email notification functionality on page 7.
16. Select Allow connection > Edit. Select Any network or Home network.
17. Select Copy outgoing (not mandatory) > Edit. Select On if you want email messages sent from your
phone to be sent to an additional email address of your choice. This way your sent messages are
copied and can be saved for future reference.
18. Select Encryption > Edit. Choose whether your email messages should be encrypted.
19. Select Outgoing. username. If requested, select Edit enter the outgoing server username.
20. Select Outgoing. password. If requested, select Edit enter the outgoing server password.
21. Select Incoming port. If needed, change the port for the protocol you are using.
22. Select Outgoing port. If needed, change the port for the SMTP protocol.
and the other is
To write and send an email message
1. Select Menu > Messaging > Email > Write new.
2. Select To: to add recipients and select Add. There are three ways to add an intro sentence:
• Select Enter email address. to enter an email address.
• Select Contacts look-up to retrieve a recipient from Contacts.
• Select an email address from the last used recipients.
3. To add more recipients, select To: > Edit select Cc or Bcc and select recipients to add. When finished
selecting recipients select Done.
4. Select Subject: to write the subject.
5. Select Text: to write the text.
6. Select Attachments: and select the attachment to add. Add more attachments the same way.
7. Select Continue.
8. Select Send to send the message or More to view options.
To receive and read email messages
1. Select Menu > Messaging > Email > Inbox.
• Select Send&rec when the inbox is empty or
• Select More > Send & receive to download new messages.
2. Select a message and select View to read it.
To reply to an email message
1. Select Menu > Messaging > Email > Inbox. Select an email message in the inbox. Select More
> Reply and select:
• Yes – to include the original message in your reply or
• No – to exclude the original message.
2. Write your message select OK > Continue.
3. Select Send to send the message or More to view option
Mar 08, 2010 | Sony Ericsson W350A Cell Phone
138 people viewed this tip
David Payne
David Payne
