Tip & How-To about Cameras
How to edit MTS files on Mac
Video editing software on Mac like iMovie, Final Cut Express, and Final Cut Pro still have big troubles in recognizing footages shot by AVCHD camcorders. The problem is especially obvious for those people who do not have the latest version of these editors. Because these AVCHD cameras such as Canon HF S11, HF S200, JVC GZ-HD620, Panasonic AG-HMC40, etc. are all recording videos in the format of MTS or M2TS, which have not got native supports from the above mentioned Mac editors to full extent. To make MTS files possible for editing on Mac, here I would recommend you Pavtube MTS/M2TS Converter for Mac, which will convert MTS to MOV and other container formats that are accepted by often used Mac editors-iMovie, Final Cut Express, and Final Cut Pro. The application works well on Mac OS X and handles TS, TP, M2TS, M2T format as well. The following guide tells you how to convert MTS files to a workable format for editing on Mac step by step. If you are frustrated by the similar problem, please read on it to find out the solution.
1. Run Pavtube MTS/M2TS Converter for Mac and click "Add" button to load MTS files shot by your camcorder to this program.
2. Click on the drop-down menu of "Format" to select a compatible format for your iMovie, Final Cut Express, or Final Cut Pro. I select "MOV-QuickTime (*.mov)" as an example.
3. Click "Settings" button to adjust audio and video parameters
You are allowed to adjust audio and video parameters like codec name, bit rate, aspect ratio, frame rate, and audio channel in the following window. In principle, the larger input values, the larger file size, but accompanying with the better file quality; the smaller input value, the smaller file size, but accompanying with inferior file quality. That is to say, if you want to do advance settings, you’d better make a balance between the file size and the file quality.
4. Start converting MTS files
Once all the above settings are finished, you can click "Convert" button to start converting MTS/M2TS AVCHD files into iMovie, FCP or FCE supported format. The interface below will show you clearly about conversion progress, time elapse, left time, generated file size, and estimated file size.  After conversion is done, you can easily find out the output files for editing via clicking "Open" button.
The end! Hope this helps.
For more: http://www.pavtube.com/mts-converter-mac/
Cameras Logo
Convert AVCHD Files to Apple ProRes 422 for FCP with Best Camcorder Software for Mac Do you have problems of importing AVCHD 1080/60p, 1080/50p, 1080/60i MTS or M2TS files to Final Cut Pro and want to find camcorder software on Mac OS X to Transcode AVCHD files to Apple ProRes Codec for editing in FCP without rendering? As the best camcorder software on Mac OS X for Sony, Panasonic, Canon, JVC camcorders, Aunsoft Final Mate for Mac is featured with one most important feature for Mac users-help Convert AVCHD video footage to Final Cut Pro ProRes formats including Apple ProRes 422 Codec, Apple ProRes 422 HQ Codec, Apple ProRes 422 LT, Apple ProRes 422 Proxy, Apple ProRes 4444 Codec. With Final Mate for Mac as the default camcorder software on Mac, you can choose preferable format for editing on Final Cut Pro without rendering. Final Mate for Mac also support converting AVCHD files to Apple Intermediate Codec(AIC)for editing in Final Cut Express or iMovie. The guide will share with you a easy and fast method of Converting AVCHD files to Apple ProRes 422 with featured software for camcorder on Mac. 1.Run AVCHD to Apple ProRes Converter for Mac and add AVCHD files. Launch Aunsoft Final Mate for Mac and add AVCHD files to the program by clicking on "Add" button to browser AVCHD file path on your local Mac computer. Then all AVCHD MTS/M2TS clips will show in Resource Tab of Final Mate for Mac. 2.Join AVCHD files and choose Apple ProRes 422 as output option. Directly drag and drop AVCHD files from Resource Tab to Movies Tab or Timeline to create a new movie and join AVCHD files into one for converting to Apple ProRes 422 Codec. There will be a pop-out window during the process shown as following: Please choose "Create A Single Movie" to merge all AVCHD video footage into one movie. 3. Start converting AVCHD to Apple ProRes 422 Click on Export button and follow Export into Editor > Final Cut Pro > Apple ProRes 422 HQ(*.mov) format to choose your output format for converting AVCHD to FCP supported format. Confirm your settings and click ok to starting conversion. Minutes later, you can access combined Apple ProRes 422 MOV movie by clicking on "Browse for Export Path". Now you are able to edit AVCHD files on FCP without rendering with the help of Final Mate for Mac as the best camcorder software on Mac OS X.. Tip: If you use iMovie or Final Cut Express for AVCHD editing, you may be interested to know how to Convert AVCHD files to Apple Intermediate Codec for iMovie/FCE.
Jun 28, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Transfer/Convert Sony HDR-CX150 AVCHD MTS Movie to Apple ProRes for Final Cut Pro on Mac Sony Handycam HDR-CX150 is listed as one of the best home movie camcorders by Lori Grunin, senior editor from CNET.com. However, people are not giving a high credit for this camcorder. Just like Lori puts it in her review for Sony CX150: "Its small size and attractive price might draw you to the Sony Handycam HDR-CX150, but this bare-bones camcorder just barely delivers on the promise of HD quality." For many Mac users, editing AVCHD footage on Final Cut Pro is not very pleasant with many problems & frustration, though Final Cut Pro 6.0.1 claims to give native AVCHD support. In the guide, I will share with you how to batch convert AVCHD MTS/M2TS videos to Apple ProRes format for smooth editing in FCP without rendering. Featured Camcorder Software for Mac OS X - Aunsoft Final Mate for Mac Aunsoft Final Mate for Mac, a useful camcorder software program for Mac OS X, make it easy to capture AVCHD videos from camcorder, edit in Timeline for joining/cutting/splitting MTS/M2TS files, AVCHD lossless output for HD memories on TV, export to Final Cut or iMovie with provided Apple ProRes codecs & Apple Intermediate Codec, or share the fun online. Highlights of Aunsoft Final Mate for Mac - Full HD support for AVCHD, TOD, MOD camcorders - Support merging/spitting AVCHD without conversion - Convert camcorder footage to Apple ProRes, AIC, Avid DNxHD Codec How to Transfer/Convert Sony CX150 AVCHD to Apple ProRes on Mac OS X Learn how to convert AVCHD MTS or M2TS files to Apple ProRes codec via Aunsoft Final Mate for Mac with Sony CX150 as an example in the guide. Step 1. Import AVCHD MTS from CX150 to program. There are two ways to import AVCHD videos to Aunsoft Final Mate for Mac. - Capture AVCHD videos from CX150 camcorder If you choose to import videos directly from camcorder to the program, first of all, please turn on Sony CX150 and connect it to your Mac via USB cable. Launch Aunsoft Final Mate for Mac and follow camcorder wizard to import videos to the program. Imported Sony mts files will be shown on Camcorder Tab of the program. - Import AVCHD videos from computer If you have already transferred video footage from camcorder to your computer, you can browse the file path through "Add" icon. Then all AVCHD videos in the folder will show in Resource Tab of Aunsoft Final Mate for Mac. Step 2. Join MTS clips into one for conversion. In order to join AVCHD mts clips of Sony CX150 into a complete movie, all you have to do is to drag & drop AVCHD videos from Camcorder Tab or Resource Tab to Movies Tab. During the process, a pop-out window will show as below: Choose "Create A Single Movie" to merge Sony CX160 MTS clips into one movie. Step 3. Convert AVCHD Movie to Apple ProRes. Click on Export and then choose "Export into Editor". In the panel, please follow Final Cut Pro > Apple ProRes 422 to confirm your output format to Convert Sony CX160V AVCHD Movie to FCP ProRes format. Step 4. Transfer output ProRes MOV to Final Cut Pro. Import exported ProRes MOV movie from Aunsoft Final Mate for Mac to Final Cut Pro and start your smooth editing without rendering. If you love video making on Mac OSX, Aunsoft Final Mate is highly recommended as a practical Camcorder Software on Mac. Tip: You may also want to know how to convert AVCHD to Apple Intermediate Codec for iMovie/FCE or merge AVCHD without re-encoding to preserve original quality. Tags: best camcorder software for Mac OS X, Convert MTS/M2TS to Apple ProRes, AVCHD Joiner/Converter on Mac, Convert AVCHD to Apple ProRes 422 HQ
164 people viewed this tip
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
