Tip & How-To about Office Equipment & Supplies
How to do Partial Reset for your HP AiO printer
(this includes the HP consumer printer only & does not apply for the commercial ones)
have you een changing with the settings till you found your self lost & can't operate your HP AiO?
you have the option to do a partial reset for your AiO printer which will restore it back to the factory defualt & give you the option to select the operating language & region.
in order to do that, follow these steps:
* unplug the electricity cable while the printer is ON (make sure that there're no jobs pending or working).
* press & hold "3 + #" and plug the cable back, keep holding the bottons till you see "PART RESET" on the screen.
* Select your language & press OK.
* Select your region & press OK.
Hoe kan ik mijn inkt niveau van printer Deskjet F380 op mijn laptop zien??? De printer zat vroeger aangesloten op een DELL met besturing voor XP. Maar ik heb nu een besturing op mijn laptop voor Windows 7 en scannen gaat ook al niet.
I downloaded the User guide from HP http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&lc=en&product=3390947
It gives very simple instructions for removing the rear access door (Follow the arrows beside the door and push the door to the right and pull out). I found a torn corner of crumpled paper in there. It also warns against pulling paper out the front which can damage the print mechanism.
Jan 22, 2014 | HP DeskJet F380 All-In-One Printer
Copier/Fax not printing
You have to change the setting from the control panel, go to Printer & Fax .. then properties.. open .. the settings and check if the background is selected or not then apply and then take a print.
Let me know if the problem persists we will investigate further.
Dont vote till you get the exact solution.
Oct 08, 2008 | HP OfficeJet J4580 All-In-One Laser...
HP Desk Jet 1125
just a revision level associated with a firmware upgrade. same device, basically..
Apr 25, 2008 | HP DeskJet 1125c InkJet Printer
Minolta printer werkt niet meer nadat klein onderdeeltje afbrak
Change the fuser unit upper fuser roller(including the heater lamp)and is worked 100%.
Jan 05, 2008 | Minolta EP1031/1031F CS/PRO Copier
234 people viewed this tip
k24674
