Tip & How-To about Ovens
Oven Fault Codes for GE XL44 Oven
If you are having oven problems with your GE XL44 oven then you need to do a bit of oven troubleshooting. The first part of that problem is to know what the oven fault codes are trying to tell you.
The codes F0, F1, and F7 could either be a problem with the control or the keypad.
-to see what the problem is cause by, push clear/off on the keypad. Then disconnect the ribbon connector from the control. Wait at least 35 seconds to see if the code comes back. If the code comes back then the control is the problem. If the code does not come back, then replace the key panel.
F2 – This means there has been a problem with the temperature of your oven. It could be a cooling fan or air flow problem. Also could be that the oven got too hot in either a baking mode or a cleaning mode.
-check to make sure the contactor contacts are not welded together. If this happens the oven will always be putting out heat, even if turn off. The thermal switch may also have burnt out. If this switch is open then the fan may be bad, causing the thermal switch to activate. The thermistor that senses oven temperature may also bed bad or have a poor connection somewhere.
F3 and F4 - These are oven temperature sensor codes.
- check the sensor by removing power to the range and then removing the sensor. Check that the sensor reads approximately 1100 Ohms at 72 degrees F. Then check the oven sensor lead to make sure that it is not shorted out. Then check the terminals to make sure that you are getting good contact. If everything checks out okay, then replace the control.
F5 – This is a relay safety circuit failure code
-check the lock circuit for problems. Then check the thermistor for high resistance. Press clear/off on the key pad and reprogram the control. If the code is still there then replace the control.
The F5 code can also result from a short loss of power. If you had a power flicker then reset the control.
FC – This shows a problem with the door lock circuit. Check all the wires and the switches. Check the operation of all the switches.
FD – This is a problem with the meat probe. Check the probe wiring and the receptacle where the probe plugs in at. Resistance on the probe should be 30 to 50K ohms at 72 degrees F.
FF – This is a problem with the door motor safety circuit. To fix this the control will need to be replaced.
http://www.fixya.com/support/r4388324-oven_fault_codes_ge_xl44_oven
http://www.fixya.com/support/r4391163-range_stove_oven_door_glass_replacement
http://www.fixya.com/support/r4404788-electric_oven_problem_oven_will_not_shut
http://www.fixya.com/support/r4319588-electric_oven_problems_not_use_in
http://www.fixya.com/support/r4154940-fault_codes_admiral_range_stove_oven
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
Ovens Logo
ge xl44 gas range, oven will not come on. everthing else works fine
If you see the ignitor glowing down there that means power is getting to the oven circuit. You have a weak ignitor if that is the case. Sometimes you can bump it and make it work. Check out this video
Sillicone carbide ignitor operation
XL44 service manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 31, 2011 | GE Ovens
GE XL44 Gas Stove and Oven. Everything works normal except the oven which stopped working suddenly (no flame). Couldn't find the manual to check troubleshooting guide.
The oven uses a silicone carbide ignitor which requires 3.6 amps or better to open the gas safety valve.
If you don't see any glow from it then it is either blown or the gas valve has gone bad. If it is glowing but not real bright it probably is weak.
How it works: Silicone Carbide Ignition
XL44 gas stove manual
Jan 25, 2011 | GE Ovens
GE gas oven XL44 JGBP29GES1WW not enough heat
I suspect a faulty ignitor. It must draw a certain amount of amps to open the gas valve
XL44
Jun 09, 2010 | GE Ovens
GE XL44 gas oven
hi thanks for the question just because the igniter lights up doesn't mean its good, the gas will not light, if igniter isn,t hot enough. and a very common problem is that the igniter does come on, but not hot enough to ignite the gas . replace the igniter thanks the appliance doc
Jun 25, 2008 | GE JGRP17 Gas Single Oven
11,300 people viewed this tip
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
